How do I clean H-Alpha Filter?
9 replies430 views
Alien_Enthusiast avatar
Hi Dear AstroBinners,
Quick question
how do I safely clear my 1.25 H Alpha filter?
I tried using Air-Blower to blow off the dust, but some of it is still there and doesnt seem to be bothered by it.
Would it be safe to use a telescope brush? Maybe just spray it with glasses cleaning spray and then wipe the dust off?
Just want to make sure I dont damage/scratch it.
I will attach a few images of the filter and the brush I have.
You just don't. It isn't going to affect your images so let it be. Besides, that brush is too hard, you'd need a much softer one (and more expensive too).
Mike H - Sky View Observatory avatar
smile
Mike
Maged avatar
In your case the filter looks good. To remove the dust you can use a blower that comes with camera lens cleaning kit.
Unless you have something like grease on the filter it's best not to clean it. But if you must then you can submerge the filter in a bawl of distilled water (not tab or mineral water) after adding like two drops of dish washing soap in the distilled water.  Leave it there for few hours then holding the filter from its sides shake it a bit in the water then remove it from the bawl and pure some distilled water on it to wash it from any residues on both sides then leave it standing on it's side to dry (not in a flat position so the water can slide away from the filter).
That's the safest way.
Again your filter looks good, Just a blower will do the job.
Got it! Thanks for informing me. Glad I didnt do anything yet smile I guess I'll just leave it be
Lynn K avatar
I clean my filter often.  Most filter manufactures, such as Astrodon, claim their coating are tuff enough to resist scratching during cleaning for numerous cleanings.   If they don't, don't buy that brand.   The particles you refer to are adhered to the surface  and will take water moistening to loosen them.  You do not want to use abrasive action to clean the filter surface such as rubbing.  Dry particles can scratch the coatings.   There are a number of lens cleaning products on the market and home made recipes.  Celestron use to recommend a homemade recipe to clean their optics.  Most will be a combination of mostly distilled water, 91% Isopropyl Alcohol and a vey small part of mild detergent.  I prefer Orion of California lens cleaner.  A very small drop on a COTTON "Q" tip will be best.  Apply the cleaner with one side, flip and gently rolling the Q Tip between your fingers, start to dry the surface.  the surface will fog up.  Throw the 1st Q Tip away.  Using another Q Tip repeat rolling the Q Tip stim between you fingers.  The fogging will take some time to completely remove. Flip the Q Tip and continue till completely dry.  Now blow off and cotton fibers with a Bulb blower.  Screw  the filter into the carousel.  Blow all dust off of every filter, are clean if necessary.  Be sure to examine both side of the filter carousel and blow all dust off, then put the carousel in to the holder and close quickly.
If one does this properly and does not expose the filter wheel opening to dust contamination, taking new flats should not be necessary for each session.
I use a similar process on my $8K AP130GTX  and Tak FSQ106ED.  Except I use 100% cotton balls.  If you live in a highly wooded area, as I do, and image in the spring.  You had better damn well clean the pollen off you optics.  That stuff will adhere to the surface.   And some trees put out sap droplets.
Lynn Krizan
padiac avatar
I've been using camera sensor clean kit. Usually the first time I use one swab with cleaner to clean the grease and dust.  Before it completely dries out, I will use another dry swab for cleaning the water stains. However, if it is a dust spot only, I would not bother about it because this is just too normal to have them on the filter or sensor unless you never touch your filter wheel and stuff.
Jeffery Richards avatar
Astrodon (actually Farpoint) has a YouTube video on how to clean their filters.
https://youtu.be/t5NAIbV1l8o?si=lOvZyeWW730bVfvx
Well written
HR_Maurer avatar
I would recommend not touching the surface. Try to blow off the dust, using oil-free dry air. Even if there should be a SiO2 protection cap, if the dust is hard it can scratch the surface when manually wiping it off.
Another method would be wet cleaning using distilled water. For best results, remove the filter mount. Use nitrile gloves. However, i wouldnt recommend this if there is only small contamination. A method often used in optical manufacturing is, to vertically drag it out of the water bath very slowly, utilizing capillary forces fo remove dust. If the surface is hydrophobic, you can do it slowly without teating apart the water film. I couldnt do it at home, though.
Dont use ultrasonic cleaning, because ultrasonic produces micro cavities which, when collapsing, damage the surface microscopically.
Barrington Russell avatar
Honestly I wash mine once a year under the kitchen tap.
Telescope Mirror Cleaning
Just sharing my success with what is probably a 'cheats' way of cleaning my 8" GSO Classical Cassegrain primary & secondary mirrors. The larger size of the 8" telescope tube allowed me to get away with it. Instead of the recomme...
Discusses safe cleaning methods for telescope optical components and filters.
Aug 10, 2025
Advice on duo-band filter selection for astrophotography setup
Hi, I am looking to expand my astrophotography setup with a duo-band filter. Well, possibly two depend on how the pricing goes. I’m looking to have my feel-pinions validated and possibly a correction from someone who knows what they’re talking about....
Covers filter selection and maintenance for astrophotography equipment setup.
Aug 31, 2025
