Color vs Mono
FiZzZmaxchessKapil K.andrea tasselli
38 replies1.8k views
Thoughts?
Multiple choice poll 131 votes
22% (29 votes)
78% (102 votes)
schmaks avatar
I am getting close to upgrading my camera from a DSLR to a ZWO camera, but am torn between color and mono (with SHO filters / wheel). I live in a boatel 7, so I am very tempted by the narrowband imaging though I understand it requires a bit more patience and time to get enough light for images.
Thoughts?
I currently shoot with a 430mm refractor.
HR_Maurer avatar
Hi Schmaks,
i live in a Bortle-7 region, too.
In my last home, i had a relatively dark garden, amid loads of bushes and trees. Low local stray light. From there i also captured RGB.
In my actual home, even if it is further toward the outskirts, i can only use RGB for comparably bright objects. It was a good place before they built the house. Now there are a lot of large windows with good vistas above me (i'm at grond level), and why would you shut your blinds if there is nobody looking in?
That's why i voted for mono. You can still complement your frames with DSLR frames if you want.
CS Horst
Concise Supportive
Philip Gelsheimer avatar
Hi Schmaks,
I made my switch from DSLR two year ago. I went with a OSC camera and found it was not the greatest in my Bortle 7/8 skies. Once I added an L-Enhance dual-narrowband filter I found I could take much nicer images of nebulas.  Downside is that exposures are longer than if you had a mono camera. Upside is your image capture and processing is less complex than mono.
That said, two years have passed and now I am evaluating which mono camera I should get. Light pollution will only get worse and fellow imagers near me have switched to mono claiming a night & day difference. Their images prove it is more than talk.
My plan is to use my OSC on my travel scope (where I will have dark skies) and use mono in my backyard on my pier.
Good luck!
- Phil
Paolo avatar
Same boat as you! I live a B7 zone and am shooting with a stock DSLR.
I have thought long enough about this choice, and I've finally decided to take the mono route.
Now I'm just waiting to have enough money smile
I guess I'll start "cheap" with just an L and 5nm Ha filter (Chroma).
Michael avatar
I'll begin saying I joined the hobby roughly 8 months ago now or so. I'm located in about a bortle 8 area.
I went with a DSLR when I started.  That quickly changed into an OSC cooled camera (183mc pro) for my Redcat 51. I did use an L-enhance the majority of the time and didn't have too many complaints overall.   After 2 months and plenty of research I jumped into the deep water and went with a 7 slot wheel, Astronomik LRGB and 6nm Ha, SII and OIII 36mm filters and the 183mm pro camera (mono).  I haven't been able to get too many complete images yet as the clouds have been dreadful (and good ole galaxy season is with us) but I can confidently say I will not go back to OSC from home for nebulae ever.
Don't overthink the whole mono thing, it's a transition that isn't that difficult but it will require more integration time so if you're cloudy 300 nights a year you might rethink it!
Alex avatar
I bought a DSLR in January this year.  At the end of the week I will be 4 months into the hobby.  I just got my ASI6200MM last week.  I'm in Bortle 6 with Bortle 7 light domes north and south of me.  I only got to use it a little bit (25 minutes RGB and 30 minutes L) on one night, but I have to say I was amazed at what I got.  There were also really bad clouds in every RGB sub that the filters more or less ignored (note that clouds would ruin L and some others, but RGB wasn't affected too badly, but I'm also not a purist and take what I can get for "clear" skies).  I already had the ZWO drivers and all the ASCOM platform/drivers because of my ASI120MM Mini guide camera.  After installing the filters in the wheel and some cable management literally the only two changes for me were: needing to use LiveView in APT to focus instead of the LiveView on my DSLR and clicking a button to "connect" the filter wheel to APT to change filters from my laptop between sets of subs.
Here's a comparison of the Leo Triplets using my DSLR on a good night vs. very little data with the mono camera on a bad night:
Leo Triplets First Light with ASI6200MM - 25 Minutes Each of LRGB Data
Leo Triplet Wide Field
Howard Richard avatar
I have gone from a DSLR to OSC ZWO cameras. I am struggling with PixInsight just like everybody else. OSC cameras are capable creating very nice images.  I have no experience with Mono so I can only say that if you stay with OSC you will have lots of room for improvement. However, if you go mono, narrowband imaging in heavily light polluted areas is the great equalizer.
Brian Boyle avatar
I started this hobby 12 months ago (albeit from.a career in astronomy - mostly spectroscopy).  I started with a DSLR and moved to an ZWO OSC when I got frustrated with the lack of red response in my DSLR.  However I now have a mono camera, and I use that pretty much all the time now.  I am happy with my NB, LRGB attempts so far - not up to the level of many here, but only a month in, I am getting some reasonable images.  Most importantly, I don't find it that much different/most time consuming than processing OSC.
For me the advantages are NB options, greater creativity/flexibility/fun with colour palettes and higher efficiency with RGB (plus L) imaging.  I found the learning curve from OSC to LRGB or NB imaging not too bad, and there are some great tutorials out there (I used Keller's and Bracken's book s- invaluable reference sources, no need to struggle with PI using them).
Now, I live in Bortle 3 - and still find mono useful.  Living in Bortle 7, I would have gone for mono straight away.  Imaging will take longer, but I usually pick my objects so my scope can run all night unattended (I have an ASIAir, which even coordinates the meridian flip for me).    Just starting out, you will have plenty of objects to choose from.  For me, it also means I can observe in much brighter moon with NB.  The SNR is reduced compared to dark nights, but not swamped.
My only frustration is that my ASI 1600MM is much smaller than my ASI 2400MC, and I wish I had simply gone for the ASI6200MM at the start (anyone want to swap an ASI6200MM for an ASI6200MC?).
The only down side for mono imaging is the cost of the filter wheel and filters.  But it is a good investment.
You don't say what refractor you have, but I would go for the biggest sensor that covers the corrected field.  The new APS-C sized ASI2400MM looks great.  I would advise against an ASI1600MM.  It is now quite old technology and has a weird "gravitational lens" halo around bright stars (particularly [OIII]).  As for filters, you very much get what you pay for.  I use ZWO filters, and might move to Optolong/Bayer.  But I cant afford/justify Astrodons.
Hope this helps
Nicole & Ryan avatar
We, as well, have been at the hobby for about a year, and still am currently using the DSLR we started with.  The choice was one of the compromises of starting from scratch.  We were in those, "here is what we want" and "here is what we would actually be pleased with" conflictions but ultimately (mainly due to all the fine imagers on here) found comfort in the DSLRs ability (and sale price).  On that note though, "here is what we want" always seems to be that of mono with filtration.  If (when smile )  we get a new one, it will be of the monochromatic flavor!
N&R
Jérémie avatar
FiZzZ avatar
New in the field also here smile
I had a period with a Nikon D5600, but very soon realized that cooled monochromatic was my target, so i purchased a ASI294MM.
Besides the extra cost for filters, filter wheel and extended capture + processing time (just for LRGB), everything will ultimately deliver a better result.
You have much more control on what you image and how you process it.
One suggestion:  get parfocal filters to avoid the pain to re-focus (so take flats) among each filter smile
Helpful Concise Supportive
HR_Maurer avatar
after reading some of the comments above, i want to mention one thing:
If you just started imaging with a DSLR, you might first want to improve your skills with that. Before buying a 6k$ camera with filter wheel and stuff. Otherwise you wont be able to benefit a lot from the new equipment. And if you can get the same camera in an updated version, but for less money one year later, you might regret your overhasty investment.
of course! However, you'll have to re-focus anyway. At least in my experience. My rigs are not completely free of chromatic aberration (i'm ignoring that for my flats. Sometimes even use the same flat for different filters )
CS Hoschie
FiZzZ avatar
I have Baader LRGB and they they work quite flawlessly...of course once you tune their position in the filter wheel as they are par focal, but they do not all screw in the FW in the same way
Arun H avatar
I have a 2600MCPro and a a 1600 MM will full filter set. The MC Pro is very very capable. But it cannot replace a mono camera with filters. The big difference is the ability to take true luminance with the mono - the MCPro cannot match this for detail. And of course, the ability to do true narrowband with 3 nm filters.
Edit : Would completely agree with Die Launische Diva's post below about the importance of dark skies for true broadband imaging. A DSLR  at a Bortle 2-4 site will outperform a mono camera at a Bortle 6 site for the same imaging time. I've seen this personally. I was able to get more detail on M42 with a simple 7D mark II DSLR and 400mm lens stopped down to f/7.1 in less time from a Bortle 2/3 site than with a mono+filters from a Bortle 6 site with an 80mm f/6 Stellarvue. The ability to drive to a dark sky site, regardless of equipment, will make an enormous difference - this point cannot be overstated.
Die Launische Diva avatar
This.
At least three factors affects image quality: Processing skills/Sky quality/ Equipment. If I were you, I would invest in a trip in a darker place and I would image again a recently imaged object, to see how the sky quality impacts the end result. I would image again something recent in order to be confident about my processing and equipment setup skills. If my skills are fine, this investment should reveal that indeed the sky quality is the problem.
Any astrophotography setup is already complicated, and many things can go wrong. It also includes us, as processors, along with the software we use for the data reduction and the post-processing. By adding a filter wheel and a set of narrow-band filters you add more complexity and make things even harder to troubleshoot. So actually this is not a question of color vs. mono, but a question of finding the weakest link in your image production workflow and investing on hardening that link. This process is easier when the setup is simpler, and when the processor has accepted that he might be one of the weakest links. The latter is very hard — so hard that people are willing to spend more and more money on new gear, instead of trying to be more honest to themselves.
Die Launische Diva:
I couldn't agree more. I have been in this hobby for over 20 years and I am still the weakest link. Spending more money on stuff isn't going to buy the needed skills.
On the subject matter I moved from mono/LRGB on to OSC (dedicated, not DSLR) and I am very definitely NOT looking back. And I am most definitely NOT blessed with dark skies. Mostly Bortle 6, rarely if ever 5 and more time than I wish between 7 and 8. And I make my own Bortle 8 imaging run when I shot with the Full Moon. RGB, not NB. Well, with a decent LP filter but this is par for course.  And I expect being not the only one. DSLRs have a lot to go for them and more importantly even decent/good ones won't bust the bank.
I can see I might eventually buy a Mono camera with a smallish sensor  to use with my existing filters for high resolution stuff. And I mean really high resolution not just high image scale. Nights for this don't come very often in my neck in the woods.
Michael Gorman avatar
I love mono Narrowband. That said you'll want either color or RGB filters for some objects. Reflection nebula and Galaxies for instance usually aren't the best targets for Narrowband. Emission nebula however are amazing.
Concise
maxchess avatar
Read this thread for a data driven comparison of OSC vs Mono. https://www.cloudynights.com/topic/682340-monochrome-vs-one-shot-color-%E2%80%93-by-the-numbers-please/
For both OSC & Mono  cooled cameras will get you more accurate darks that you only need to shot once per exposure time.
Also it depends on which OSC. I upgraded my DSLR to an ASI294MC_Pro, so colour & cooled with a decent size sensor and a Pixel size of 4.63  (which is a critical factor).  The improvements were huge. It is way more sensitive and of course does not need to be astro modified.  In bortle 5 skies or worse you need an LP filter. I use the Optolong L_Pro.  For targets with nebulosity use a triband filter like the Optolong LEnhance.
You need to match your pixel size with your scope, but 4.63 is a good balance for long & short focal lengths. If you are going to shoot mainly wide angle (less than 400 FL) then get a smaller pixels.
The difference (not advantage) between the OSC and Mono is not mainly about number of photons collected or about detail (see the link) .  If you want to more photons get a faster scope (or a longer FL + a reducer)
OSC are more time efficient, in that if you only get a few hours between clouds then you can use what you have. If you shot LRGB  you run the risk of abandoning a set and running out of time.  Plus you spend less on equipment and don't have to worry about refocusing between filters or collecting separate flats and darkflats.  But you can't do narrow band properly (although you can do pseudo NB).
Mono Can do everything an OSC can do but is more expensive and requires more time and planning. Plus you can do Narrowband and Hubble Palette and all that good stuff.
After 2 years with my OSC on an F7 refractor and a C8 in the cloud affected UK , my next step is an  F2 RASA. That will get me over 10 times more photons,  so I can get the equivalent of  4 hours integration time in 24 minutes and will not support a filter wheel, so ideal for my OSC.
When that route is exhausted I may go for mono + filter wheel. I may also trade in my automatic car for a stick shift and abandon my MP3 files for vinyl all of which are superior under particular conditions.
Max
If you are implying that by decreasing the focal ratio you collect more photons you would be quite wrong. The only thing that changes is how you spread them around.  BTW, I didn't know that they made 25" RASAs. That must a view to behold...
Otherwise, I'd agree on what you wrote 101%.
Uros Gorjanc avatar
After 13yrs of DSLR usage my upgrade to mono dedicated astro cam was obvious decision.
Sean van Drogen avatar
Have been at this hobby for just a little over a year and switched from OSC to Mono after about 4 months.  I also live in a bortle 8/9 area so the SHO is what really attracted me. The LRGB has been a much tougher journey I must say lots to learn about optimal exposure time and minimum total exposure time to get a workable image or even colour out of one of those but was also unlucky with the weather here. Getting the hang of the processing is also on a whole different world have not read so many books since i was at University smile
maxchess avatar
I should have been clearer I was comparing an  F7 scope to an F2 scope both with the same focal length and therefore much different apertures. Of course in practise an 400mm FL refractor will be more like f5.8  so the practical multiple is likely to be around 8.5.  However although a  25" RASA is a trifle on the large side, an 11" RASA is on my radar at F2.2 , FL=620  and refractors with that Focal Length are around F7 (ED80 is F7.5) so we're back up there spending our money to get 10-12 x light gathering ability rather than 0.5 by spending it on a mono camera. But as I said earlier it depends on what you are trying to achieve.  I want to get the most RGB photons in my weather limited conditions.
You would of course get a similar effect with a fast Newtonian, but they have their own issues.
If however you do know someone who has a 25" RASA for sale, I have a bridge I could swap it for.
Agreed on the swap. I have roman antiquities to trade for, in case the buyer isn't interest in bridges. The focus depth at f/2.2 is tiny (less than 5 microns) so that puts a major strain on the focusing system (I guess that means even more money). I would have been happier at f/3 for that size, gives a bit more oomph. But then pixel scale could be make those errors more forgiving. Me, not interested in small FL as an upgrade path but there we are.  To each his/her/their own. One day my 12" f/4 will be on-line and we'll see what that will take me to. I'm not going back to mono for sure. Life is too short for that (if you live in the UK anyways).
Olly Barrett avatar
Hi…
I live in a Bortal 4 area and have just moved on from using a 127MAK for planetary, with an OSC camera, to imaging DSOs…
I faced the same choice but went for mono (ASI1600mm Pro) in the end and have actually found the processing to be straightforward…
So, for me, mono is a no-brainier on all accounts and especially in high Bortal areas.
FiZzZ avatar
I don’t know if it goes by personality, but OSC offers overall less control of what you are doing…
so (for example)it does not attract me and I deem the “extra” work (and cost) to run a mono as a totally beneficial one.
is true that exposing with multiple filters expands the possibility of something going not so straight… but generally your whole routine then adapts to something different than OSC, and so these risks get somehow “minimized”…
one night can be affected by clouds, so some batch can become useless ?
yes… but rarely you will aim to a “one night” picture with mono… is more probable that you will gather data over several sessions as your “mono mindset” dictates so… while your “OSC mindset” aims more to have full data images in less time…
I’m not saying one is better than the other… also because I get hugely pwned by DSLR pictures that to me are unreachable smile
I just think is very much related to your mindset … (and narrowbanding smile )
Narrowband filters - Nm choice
Since getting such a positive response from my "Jump in" question, I've been reading as much as I can on narrowband astrophotography. Now I have to choose among several filters - 3nm, 5nm, 6nm etc. I understand that in more light pollut...
Directly addresses narrowband filter selection and imaging techniques.
Mar 2, 2023
Imaging Time -- OSC filters vs. Sky Quality
I currently use an L-Enhance filter from a sky on the darker end of a Bortle 6 (~19.4 SQM); Bortle 5 is just a mile or so away. My most used local sites are in the 20.7 - 21.3 range. If I recall correctly, requisite imaging time is proportional to 2....
Compares imaging time requirements for different filter types in light-polluted skies.
Apr 21, 2023
