Skywatcher quattro 10" on Sky-Watcher EQ6-R Pro. Who's doing that?
Michael W. DeanMarc-Antonio Fischer
28 replies1.2k views
Michael W. Dean avatar
I know that with a camera, guide scope, coma corrector, focuser, adapters, etc it's close to the 20 kilo / 44 pound weight capacity limit for visual, and above the 3/4 of the capacity that you're supposed to do for astrophotography.
Yet I see a bunch of people here doing it, and getting great photos.
Ever have issues using it for astrophotography? Have any tips?
I have enough counterweights and the counterweight extender, and can balance it well.
I've got a poured concrete floor in a roll-off roof observatory. I've been using that mount with lighter scopes for about 18 months with good results. Just got the 10 inch Quattro. Have it set up but still waiting on a few things, plus cloudy skies, haven't had a chance to use it. But I'm wondering if I should have gotten the 8 inch model instead.
Any input welcome from people running both (or running an similarly big heavy scope on this mount.)
Thank you.
Reg Pratt avatar
You can't just consider the weight of the payload. You also have to consider the size of the payload. Larger scopes create more momentum when they move making them heavier than their dead weight. That being said, with no wind the eq6 will guide pretty good but it wont take much more than a breeze before you start losing subs because your image scale will not be very forgiving. Speaking from experience, I current have a 10" on a CEM70 and will be upgrading it asap. If you have decent wind protection it would work but you would still be exceeding the mounts intended payload capacity.
Helpful Insightful Respectful
Salvatore Iovene avatar
A lot of people have this combination, and actually the EQ6-R Pro is the most used mount with that telescope on AstroBin:
Hopefully some of them will be able to address your concerns! In any case, the numbers above are probably a good indication that this combo should work.
Well Written Concise
Salvatore Iovene:
Wow! MOST used with. Amazing.
Ok, not as worried now. Though will likely be at the long end of what someone said, "Reflectors are run by duct tape and hope."
I'm up for a challenge.
It's only 217 images tho, so I guess  not *that* many users? I would ask around. If you search on AstroBin you should be able to find those images and contact the photographers.
Salvatore Iovene:
Thank you.
I left comments for a few I really liked asking for tips, but decided that or contacting all 12 or 20 of them might be spam, so stopped and did this forum post.
MWD
Marc-Antonio Fischer avatar
Michael W. Dean:
Thank you.
Ive even used the Skywatcher 300 quattro with the eq6r pretty well😂 wind is just a problem. You can check out my images with it if you want
Marc-Antonio Fischer:
Wow! That's gotta be breaking some law of god and man and physics. lol. Amazing.
And you've got some tiny targets looking good.
Did you hypertune the mount? Anything special you'd recommend? How much wind before you don't bother shooting, any at all? Do you have something to block wind?
Thank you!
Michael
Michael W. Dean:
Thank you!
Michael
Thanks
I just adjusted the backlash. I got guiding with 0.6-0.8 depending on seeing.
I got a tiny observatory that blocks a lil bit. I would say about 10-15kmh i notice a lot of movement
Marc Fischer:
Thanks !
Excellent.
One thing someone suggested was replacing the stock thin Vixen plate with wider D plate. Makes sense. I was thinking that Vixen "wasn't up to the task."    So I just now ordered a more robust Celestron universal D plate, was suggested on the phone from Starizona, the place I bought the scope.
=16pxExcellent.
Oh you mean a Losmandyrail instead of this tiny vixen prismrail? Thats a good idea. Next time you can order at Teleskop-Express and ask for "Marc Fischer"
CCDMike avatar
I use this combination but with a CF-Tube.
But I know some others here with the steel Tube and eben on a NEQ-6.
Balance is most important and it will work out very well👍
Mike
Blaine Gibby avatar
I use the Quattro 250 on the EQ6. I bought extra counter weights so that I don't have to use the extension bar. Guiding is fine, I can get as low as 0.4-0.6 range depending on seeing and wind. Wind is the biggest issue, mainly due to the size of the Quattro 250. I haven't made any adjustments to the mount.
I don't use astrobin much for uploading images but below was taken with the Quattro 250 and EQ6
https://www.astrobin.com/yx0axf/B/
Matthew Proulx avatar
You should be alright if you have no wind.  Newts are sails. I was using a 10" RC for the last 4 months which totaled to 46lbs on an EQ6 but I was on a pier in a roll off roof.
Really the biggest thing is gonna be wind. The EQ6 Can handle a lot more than people give it credit for but it wont beat the wind especially on a tripod.
Steel or carbon fiber? (I bet CF 300 weighs as much as a Steel 250 though)
Mike
Thank you.
What's the weight of the CF Quattro 250P  10"?
I can't even find a canonical weight for the steel version.
I see 36.5 lbs some places and 33 pounds others. I'm assuming the heavier one is with the optical guide scope (which I'm certainly not using) but can't be sure. I'll probably just weigh mine.
Matthew Proulx:
Thank you.
Are you using a tripod? I have a RORO but am using the stock EQ6 tripod. Poured concrete floor though.
https://www.astrobin.com/5vxztw/
Michael W. Dean:
I use the normal skywatcher 300 quattro, so no carbon.
Marc Fischer:
Wow!
Your photos are so good.
What collimation laser or system are you using?
Michael W. Dean:
Matthew Proulx:
Thank you.
No, I have a 12" concrete pier. I just switched out to a CQ350 that replaced my EQ8. The eq6 was a temp.
Matthew Proulx:
Michael W. Dean:
Matthew Proulx:
Thank you.
Thank you.
How do you like the CQ350 ?
What do you use to collimate?
Michael W. Dean:
Matthew Proulx:
Michael W. Dean:
Matthew Proulx:
Thank you.
Thank you.
CQ350 is on par with the EQ6 for performance. I like it, gets .3-4" guiding same as the EQ6 was. A lot heavier and larger, can stand up to the wind. Works in -20 (unlike the EQ8) I use a cheshire to collimate Newts and then finish on stars. RCs I always collimate on stars. Nothing can beat a star collimation.
Concise
Matthew Proulx:
Thank you.
When I finally get a better mount, it will be a choice between that one and Losmandy G11G. Similar price, similar reputation.
Yours says 70 pounds capacity, Losmandy says 60 pounds, but I wonder if they're more similar than it seems. I think sometimes stated absolute capacities are brought down a bit to manage expectations.
Also, some people on this thread have shown that the stated capacity of the Sky-Watcher EQ6-R Pro is not hard and fast, and can be exceeded by a bit if you don't use it in any wind.
Is your Cheshire just a Cheshire cap, or the longer thing with the 45 degree side opening that looks like a laser collimater without the laser?
Michael W. Dean:
Marc Fischer:
Wow!
Thank you
I am using the ocal pro and for comacorrector the nexus starizona (f3 with it) so 300/900mm
Michael W. Dean:
Marc Fischer:
Wow!
Thank you
I got the Coma Corrector for this scope and plan to get the Nexus this summer.
Do you know if the ones for the 250 work on the 300 if I ever update mount and scope?
Travel rig advice: AM3N with Redcat 61 and ASI 2600mc Air
Hi all, I am putting together a travel (air travel) rig with a Redcat 61, ASI 2600mc air, EAF, and AM3N. I think this mount is adequate, although I see many people using an AM5 for this class of telescope. It seems to me this rig is the perfect use c...
Travel rig discusses weight capacity concerns with similar mount and camera setup.
Dec 16, 2025
az gti eq mode advice
does anyone have any recommendations on how I should go about adding counterweights as I don't know what rod I should use and it's dimensions and I also don't know how heavy the counterweights should be and what model counterweights I sho...
Directly addresses counterweight selection and configuration for equatorial mounts.
Jun 20, 2025
