Guide setup
5 replies104 views
Bruce Donzanti avatar
I normally guide with the OAG from my C11 but at times it does not behave. So, I am looking for a guide scope and bracket for my Tak FSQ-85EDX. In addition to the notched-out area that is provided, I do have two rings where a dovetail plate can be placed for a guide scope with a bracket. Any suggestions?
Jay Hovnanian avatar
Hey Bruce, The ADM line of MDS accessories is what I use, exclusively.  Anthony has a wide selection of bars, brackets and rings (if necessary) you can choose from.  The are about as spatially minimal as I have seen / excellent quality.  Well wishes,  Jay
Jay Hovnanian:
Thanks, Jay.  I actually have an ADM dove plate but it is too heavy.  However, I will check back with them to see what other options they have that would be lighter and easier to manage from the top of my observatory.
Dale Penkala avatar
Do you have a/the finder foot/bracket to hold your finder scope for this setup? If so you could put that on and use a 50-60mm guide scope. Thats what I use on my Esprit100.
Dale
Concise
MDS series.  It is all small and lightweight.  That is why I use this series specifically.
Thanks again, Jay 👍👍👍
Looking for a small (60-110 mm) refractor to piggyback on a C11" for Imaging
I currently have a Stellarvue 80mm apo triplet (old version) piggybacked on a C11" EdgeHD to image from my observatory. I am not pleased with its performance, so I am looking for a new scope to replace it and pair it with my ASI2600mm. Weight is...
Guide scope setup for C11; author uses C11 and needs autofocuser guidance.
Aug 10, 2022
Fornax LighTrack II setup advice
Hello all, I bought a Fornax LighTrack II used for about 370€. It's just the tracking arm so that gave me room to improvise how I would like to have my rig set up and I've come to this final configuration. However, I am very open to any suggestions. ...
Guide scope bracket setup for refractor telescope similar to author's needs.
Jan 10, 2026
Round stars using a guidescope at 1000mm - possible?
Hi All, I recently bought a ZWO FF130 to supplement my great little FF65. Normally with the smaller scope I’ve been getting good guiding with the ZWO 30F4/ASI120mm combo of between 0.5”—0.8” RMS. This is all sitting on an AM5N/TC40 (with weights in t...
Guide scope selection and setup for achieving round stars during guiding.
Feb 5, 2026
