Need help with OAG optical train setup
2 replies78 views
Scott Badger avatar
I’m adding auto-guiding for the first time (OAG – ZWO) and have already had a couple optical train derailments and hoping for some help getting back on track. Right off the bat, I managed to bind a couple of the extension tubes and ruin both trying to separate them (it was the 5mm and variable, so next to nothing to grab on to). In the process, though, I also discovered a severe vignetting issue (see pics below) that I'm assuming? is because the ID of the new parts is a lot less than what I was using before (1.5” at the back of the scope vs 2.5” through to the camera connection). More than a little confused by the cacophony of thread sizes, types and configurations, since I had M48 connections I had ordered M48 parts….. I now believe I need M68 parts, or a custom part, but before I make another obvious blunder I wanted make sure….
Here’s my pre-OAG optical train:
SCT(C9.25 edge) > T-adapter(3.3in to M48 - ID 2.5in) > t-ring(M48 )> DSLR(Canon 5d IV, full frame)
OAG/M48 train:
SCT > Celestron adapter plate(3.3in to 2in - ID - 1.5in) > Adapter(2in to M48 – ID 1.61in) > Extender/spacers(M48 to M48 – ID 1.79in)  > OAG(M48 to M48 )  > t-ring(M48 ) > DSLR
Proposed OAG/M68 train:
SCT > Adapter(3.3in to M68 – ID 2.6in) > Extender/spacers(M68 to M68 – ID 2.44in) > Adapter (M68 to M48 ) > OAG(M48 to M48 )> t-ring(M48 )> DSLR
Proposed OAG/custom part train:
SCT > Custom T-adapter(3.3in to M48 – ID 2.5in) > spacers (if necessary) > OAG(M48 to M48 ) > t-ring(M48 ) > DSLR
So, my questions are:
- Am I correct that it's the ID reduction  causing the issue? I've already overlooked something obvious, so better than even odds I’m doing it again......
- Are M68 parts the way to go, reducing to M48 at the OAG connection (still closer to the scope than without the OAG, but as far as I can get)?
- My OAG is M48. There’s a ZWO M68 OAG, but is the OAG far enough away from the back of the scope that the ID reduction at that point doesn’t matter (it’ll reduce to M48 on the other side of the OAG to fit the camera t-ring anyhow)?
- Since the various M68 parts needed add up to more than a PreciseParts custom piece ($425 vs $339), any reason not to get a single part from PP?
- If I get a custom piece, should I have it made a couple mm short to give myself some leeway and dial it in with spacers?
On the plus side, I used what I have to try some actual guiding last night and I was able to find a star, successfully calibrate and start guiding! Stuff like this never works for me the first time!….or the second, or third…. Also learned a valuable lesson. I was so amazed that I was actually guiding that I just watched PHD2 do its thing on my laptop for a while, and then it started losing the star. At first briefly, and then for longer and longer periods. So, I started playing with the settings trying to figure what was going on and am embarrassed to say how long it took before I finally looked up to see an overcast sky….. So the lesson -- look up, dummy!
Scott
Without OAG and wider ID train (the images are of a slightly out of focus overcast sky)
With OAG and M48 parts
HR_Maurer avatar
Hi Scott,
if i get you right, ID is the inner diameter?
What i can see from your sky flats, is an increase of vignetting in the corners. The vignette on the bottom edge must be due to your DSLR's mirror assembly.
Where in relation to those images is the prism of the OAG located?
However, it doesnt look like the prism is causing any significant vignette. Since your OAG is M48 threaded, M48 should be good. The vignette might indeed be due to some narrower parts in your image train. 1.5" seems a bit small for me, with a full frame sensor attached. I guess this might be your bottleneck.
CS Horst
Helpful Insightful Respectful
Scott Badger avatar
Thsnks Horst! Yes, sorry, iD is inner diameter. I Believe you’re right that the vignetting on the bottom has to do with the camera itself. It’s there with and without the OAG assembly.
I think the prism was at about 11 o’clock when i took the image but pretty sure it’s not showing because it was before and I moved it up and out of the frame.
Other than the refuction in ID, one other possible issue maybe is that the finish on the inside of the Blue Fireball extension tubes I got is anything but non-reflective. Not nurled and, inexplicably, the same high gloss finish as the outside….Don’t know if its attributing to the vignetting, but can’t be helpful….
cheers,
Scott
Sw esprit 100ed flattener distance
Hi i want some help to find the right distance. I use QHY9 + Starlight xpress FW+ OAG Starlight. The optical window from qhy9 removed. Someone with the same setup for help!!! thanks
Author has OAG setup questions; candidate discusses OAG optical train configuration.
Sep 8, 2019
Tilt with Skywatcher 200PDS
The 200PDS has a focusser tube, with an adapter ring at the camera end that is larger in diameter than the rest of the tube. This is also true of the compression ring replacement I have bought which also has 2 screws 120 degrees apart to secure the c...
Discusses focuser adapter diameter issues causing vignetting problems.
Aug 16, 2022
Find the good backfocus with my 200/800 SkyWatcher
Hello guys, I have a Newtonian SkyWatcher 200 Quattro P (200/800) with the SkyWatcher Coma Corrector GPU 4-lenses and ZWO ASI 1600 MMC Pro. Filters are ZWO LRGB SHO 31mm with 1.9mm of thickness. However, I'm getting some troubles in order to find...
Addresses backfocus and optical train setup with similar equipment.
Nov 24, 2022
The Miserable State of Opto-Mechanical Design in the World of Amateur Astronomy Gear
A new affliction has recently washed over the world of astro-imaging—namely: sensor tilt. Everywhere I look, sensor tilt is either screwing up an imaging system or it’s being blamed for screwing up an imaging system. And that has led to fixes such as...
Covers opto-mechanical design issues affecting imaging quality.
Sep 12, 2022
Hello from southern Delaware, USA
Hi everyone! I have been an on/off amateur astronomer for decades; after entirely too many off years, I jumped back in a couple years ago. Last fall I decided to take up astrophotography…so down the rabbit hole I went and there has been no look...
Technical astrophotography processing and equipment setup guidance relevant to learning.
Sep 14, 2019
