Coma corrector over correcting at 55mm back focus (Maxfield 0.95x)
2 replies120 views
Reab avatar
Hello,
Recently I bought TS Maxfield 0.95x coma corrector for my 130PDS newt.
It seemed like the best budget option for my setup, that would give me satisfactory results.
Additionally I got a bit lucky to find mentioned cc, open-box on sale on Telescope express at small discount.
The issue that I'm having is at 55mm back focus (recommended by manufacturer) I get massive over correction of coma.
The optical train is Nikon D3500 (46.5mm for all F-mount Nikons), T2 adapter (8.5mm) for Nikon (adding up to 55mm total from sensor to cc).
From that point of 55mm back focus, adding space gradually all the way until I couldn't reach focus coma remained over corrected.
And at no point did I encounter under correction (even under 55mm of back focus).
Keep in mind focus position shouldn't change much with this cc, as far as I understood it from description.
I hope that I can resolve this, is it a faulty unit?
I doesn't feel right that the over correction is so big at 55mm.
Hopefully someone with experience can help me decide how to proceed.
I'm very sad/frustrated with fighting the equipment.
Thank you for reading, hope you are having a great day and thanks in advance.
Here's the raw frame: https://drive.google.com/file/d/1jPCy5R834sd0GgIP52QzzYSZ4MsdjvTF/view?usp=sharing
Helpful Respectful Engaging
It is likely a faulty unit flogged off to the unsuspecting customers. I'd wager that the internal spacing is wrong but that shouldn't stop you in returning the unit pronto. The cc should work well, as shown by the picture below (if you discount the slight tilt toward the upper left corner), shot with a D5100 and a 6" f/4 newt:
Reab avatar
Thank you for input!
Those are the pictures that made me go for this CC, even at f4 it performs great.
I will be e-mailing customer support, and most likely requesting a different unit.
Hopefully we can arrange an exchange of this faulty unit for a non defective one.
You can imagine how many times I rechecked all the details thinking I didn't do proper research before buying, so thanks again you made me feel sane again smile
ZWO OAG, ZWO helical focuser, ZWO EFW 8 filter wheel, ASI290MM mini guide camera and ASI1600MM Pro imaging camera
Just wondered whether anyone is using the above combination and how it is working for them when connecting to a coma corrector with 55mm back focus? I believe that it would work as follows: * The OAG would connect to the coma corrector directly * I&#...
Directly addresses coma corrector performance at 55mm back focus specification.
Apr 12, 2022
What would you recommend as an Astrophotography starter kit?
My wife bought me a Skywatcher 200PDS on an HEQ5 Pro mount a few years back as a way for me to get into astrophotography. In hindsight, I would actually recommend: * 150PDS with coma corrector * EQ6R Pro mount Why? * The 150PDS is a great balance bet...
Directly relevant; discusses coma corrector issues with similar Newtonian telescope setup.
Apr 27, 2022
Review of Askar SQA 55 after 6ix month use
Summarize the advantages and disadvantages of SQA 55 Advantages No coma, no back focal length problem, and the surrounding stars are very round. As long as you can focus, you don't have to worry about the BFL like other comma correctors. The 2-in...
Alternative coma corrector option with different back focal length characteristics.
Jul 14, 2025
