Help with first acquisition in many years.
2 replies60 views
jpk1018jk avatar
First light with new ZWO Asi 294mc and Takahashi Toa-130, and would like it if someone could tell me what causes the 1. center circle artifact and 2. what's causing the stars to have the center bar looking artifact. This is my first light and it's only around 40min of exposure. I did darks and flats only but was also wondering why the starlink satellite trail in the upper left was still visible. Thanks for any help I haven't done this since around 2010 and have a lot to re-learn.
There is just not enough information for a sensible answer I'm afraid. When, where, how long and how much. And then we would need to see the raw lights, the master dark and flat, what processing has been used and what program has been used and why colour is notably assent in a OSC image. This just for starters. The most likely explanation but in no way the only one possible is that the spot in the centre of the image is due to bad flat-fielding and the bar is due to thermals in the lens' cell.
Helpful Insightful
Lynn K avatar
I agree with Andrea.  Hard to tell.  I agree the darker center is a flat calibration issue.    The star trail was not totally eliminated because the stacking software averaged it in and did not see it as an outlier.  What method did use to stack, average, median combine, signa clip etc..?  I have had star spikes using a refractor.  It is usually caused by the optics.  It usually indicates something in the light path. A single element will cause spikes on both sides.  Some optics or spaced using small rectangular spacers.  They can intrude into the optical path.  I had an W.O.  & TMB refractors with that issue.
Lynn K.
What On Earth Did I End Up Capturing Here?
Hi Folks, I was imaging remotely at a dark site about 30 minutes from my house. When I started processing the results, I noticed a single frame that had the strangest pattern that I can't quite figure out. The target is the Iris Nebula, and just ...
Circular artifacts in first light images; may explain center circle artifact issue.
Sep 27, 2022
Comet shaped stars / stars with tails
Hello, I see this issue from time to time and I've never been able to fully put my finger on what it is. Maybe someone here could help me shed light on the cause for these odd looking stars. Some notes: It's consistent throughout the frame. T...
Star artifacts with center bars; directly addresses diffraction spike/artifact problem.
Feb 28, 2023
