How do you capture your RGB subs?
14 replies448 views
Michael Bate avatar
I recently moved into mono imaging and have done a couple of LRGB and HaRGB images so far but still learning the most effective acquisition techniques.
I've read there's two school of thought on RBG capture, grouping subs together (i.e. shoot all R, shoot all G, shoot all B) or shooting sequentially (switch through R, G, B filter each sub). I group my subs and get the argument that doing it this way may result in different filter gradients over the course of a session that may cause problems post processing.
I like the sound of sequential RGB imaging HOWEVER i use NINA and dont want to have to add each sub as an individual sequence item as it seems a waste of time unless there's a quick way to do it? For example, a 100 subs would need setting up as a 100 sequence items in NINA so it knows to change after each individual sub vs just 3 items for the grouped approach, 1 line setup for each filter.
What's everyones thoughts?
Thanks.
robonrome avatar
Hi Michael, I'm pretty much a noob on this myself but will be interested to hear from this thread what others do…I hadn't really thought of the gradient issue.
I use NINA as well and what I do may be a bit of a compomise between doing each filter for a single block or cycling R,G,B (or in my case Ha, OIII, SII).
What I do is blocks of between an hour and two hours per filter (typically 300s subs) depending on sky time with most targets over 2 to 4 nights. I use the filter change to trigger re-focus in this approach as well which also helps keep up with temperature focus fluctuations. For full night imaging this usually means two blocks of images from each filter per night.
I feel this gives a good balance, and if I can only get a single night I have enough of each filter to get an image done up and maybe give me a clue whether I need to run more on one or other filter in subsequent nights.
No doubt there'll be better more technically rational approaches but this is mine :-)
Helpful Respectful Engaging
Alex avatar
Hello Michael, I can't really offer any advice either, but like robonrome, I am interested in hearing what folks with more experience have to say.  Last night was actually first light for me with my new monochrome camera, and conditions were bad.  I only managed to get 6 L subs and 5 each of RGB at 300s.  Clouds started rolling in after I got my L subs, so I wanted to switch to the RGB to see if I could even get an image put together.
You raise some interesting questions regarding gradients.  I only did what I did so I could have an image.  I have never used a dedicated camera before, so last night was all sorts of learning experiences for me, although everything more or less went off without a hitch.  I use APT, and it seems like I could setup a sequence fairly easily, but I need to try it.
I typically can only image until 1 or 2 in the morning, since I live in southern Louisiana, and there is usually so much moisture in the air in the early morning that you can't see anything.  I might try to do 1 hour of each filter moving forward.
Great questions and timing for me just starting out with mono.
Clear Skies,
Alex
Respectful Supportive
Michael Bate avatar
Good to hear it's not just me with these questions! Thanks for sharing your approaches, i tend to shoot a couple of hours of each filter too but was reading some other techniques which peaked my interest.
While i love astrophotography because nothing is ever straight forward and everything is a challnge, it's also a curse at the same time!
Lynn K avatar
I started with Mono and Maxim DL in 2006.   Maxim (expensive) automatically runs all filter sequence through a sequential process.   If one want to image filter separately, one needs to simply  un-check all other filters boxes in the filter sequence set up.   I like the sequential process for the issue you raised.  That way I know the LRGB or RGB subs have equal seeing/transparency, etc.
However I don't run the Ha, OIII or SII through a sequential process.  That is because the filters demand different focusing.  I use Astrodons Ha-5nm, OIII-3nm and SII - 5nm.  But I image with fairly fast optics.  A Tak FSQ106ED at F3.6.  Imaging at longer focal lengths will  be more forgiving of focal differences.  I have never taken the time to set up focus corrections for each filter.  Also, I can image under the moon with Ha, but can't with the OIII.
The only other acquisition software I'm familiar with is Sequence Generator Pro (Free or reasonably priced).  It will run through a list of filter sequence one sequence at a time.  If you were to set up 5 red, 5 green, 5 blue the set up another 5 red, 5 green, 5 blur and so on.  It will run through them in a 1st to last sequence process.   That will take a little time to set up, but once set up can be save for latter sessions.  Maxim will also save filter set up sequences. as many as you want.  As well as multi filter wheel set ups.
Lynn K
Michael Gorman avatar
I've found it best to focus on filter changes, so I prefer to shoot in groups, otherwise you'd add a ton of focus time to the whole shoot losing possible exposure time.
Michael J. Mangieri avatar
I find that the gradients have never been a problem for me and have always been able to handle them in post-processing. Adjusting the focus for each filter wastes a whole lot of precious time when imaging.
Well written
Björn Arnold avatar
I recommend shooting each filter in a row. You will also make the experience that you might need to shoot over several nights to capture all the data.
Furthermore, you also don't have to shoot RGB in that very sequence. Depending on the situation, it could be worth a try to change the sequence (shoot B first then G and then R):
Case 1: target starts low in the sky, shoot B and G as this filters (city) light pollution which is strongest at low altitudes. Shoot the R when the traget is high.
Case 2: bright moon rising. When the moon is still below horizon, shoot B and G first. Moonlight behaves like sunlight and when the moon rises the light is scattered in the atmosphere, giving it its blue color. If you have capture B and G the effect is a bit less. Of course, angular distance to the moon matters a lot.
Case 3: Here, when it's summer, nights become pretty short. If a target is high but I haven't achieved astronomical darkness yet, I shoot the R. While the horizon still glows in faint red, the sky above mostly sends the blue light that is scattered. Hence, the R is filtering out most of the sunlight. When it's finally dark, I take the B and G filters.
I haven't discussed this with many other photographers but I've seen (or at least believe it) a difference in the subs.
Björn
Helpful Insightful Engaging
David Redwine avatar
I use flat plans in APT to shoot the filters sequentially.  I use the  filter offsets I have measured as the ASCOM filter offsets for the plan.
Jérémie avatar
In my experience : gradients are to be managed on a per master basis, so there is no obvious reason to shoot your subs sequentially. If you want a very nice image at the end, you will need to spend some time tweaking it in Pixinsight or Photoshop removing the gradient carefully anyway on each channel.
What would drive my choice is « flats » : if you are asking yourself what is best between shooting your filters by group or sequentially to get the best image or less troubles during post processing, just think about what would happen if there is a slight shift in your filter wheel each time it turns… dust (static dust, not the one that moves during the night) wouldn’t be at the same place on each of your subs of the same filter, and when you take your flats at the end of the night, they won’t correct every subs.
That happended to me the first time I tried to shoot sequentially (you have that option on the Asiair Pro : just a button and it execute your plan sequentially instead of grouping each subs per filter). I know that defeats the purpose of having a filter wheel, at least a « cheap » one, but I lost a night due to that problem… (well, I cheated by offseting the flat in Photoshop, but the results are not very good when eyeballing the alignement of dust donuts…smile.
So if you go that way, maybe clean your filters well before the night (vignetting is less sensible to that if your sensor is small compared to filters).
Now what I do is at most 2 filters per night when going fully automated : I take the flats of the first filter before triggering the session, and takes the flats of the second filter in the morning. If I need to do more filters in the night, well, I wake up and take flats before turning the wheel :-)
And of course, you can always try to automatize taking the flats (flat panel on the side of the telescope and your mount automatically aim it before coming back to the target)
Or you buy a nice filter wheel…
Ruediger avatar
Hello,
I hope I got your question correctly....
This is quite easy to realize in NINA (nightly build is required (!)) and advanced sequencer. You can use the loop condition.
I combine for my "one-Night-Projects" horizontal and vertical plans. That is a combination of shooting one filter all subs then move to next and shooting one sub per filter and loop that. By combining the the 2 approaches I equalize seeing effects during the night and also ensure that I have data from each filter in case clouds roll in and I loose some hours.
Please find below an example of a sequence. The clue is the loop condition for the imaging block. If you have question feel free to ask.
Remarks:
1. Do not get confused by the red exclamation marks. I have no gear connected when taking the screen shot. That causes the exclamation marks.
2. I have injected two AF to make sure that Lum is always best focused
3. I shoot until dawn (in this case nautical, since I needed all data for my M51)
4. I have a trigger to check HFR to ensure to compensate temperature if required.
Michael Bate avatar
Some really interesting thoughts from everyone , thanks for sharing. I currently don't have an AF (on my long list of buys) and probably won't be investing in one soon given i just bought a new cooled cam & filters so sounds like continuing to shoot in groups is my best bet. My post processing skills are average and i'm trialing using Gradient Xterminator to manage my gradients (i'm in bortle 5 but have a large light pollution glow to the north from a large town).
Ruediger
This is also super helpful, i don't use the nightly builds just the stable release version so didn't realise there was a loop condition option
Björn Arnold:
Björn
Also a very good point i haven't considered, i always just ran RGB (then L) in that order without considering where the target is and the conditions of the sky.
I've obviously still got a million and one things to learn
FiZzZ avatar
I use astroimager from Cloudmakers.
has control of focuser, filter wheel and camera in a single nice and clear interface.
As a Mac user is really a good (and stable) solution.
advantages of the cloudmakers suite, which include astrotelescope (planetarium and scope control) and astroguider:
- all what you need in 3 windows
- integration of guiding and imaging for automatic dithering
- plate solving from astroimager to resync the scope on astrotelescope
- easy sequencer with filter wheel control and autofocus
- deep control of all your equipment through the control panel (you can really dig deep into your stuff settings)
- scriptable
all the softwares are reasonably cheap (20/30 euro each module) and support is really great for whatever doubt or suggestion you might need.
actually the stable version is the 3, but the 4 beta is already very much stable and far better than the 3.
you can try it with a 15dd trial license …
as hardware I suggest a filter wheel and parfocal filters, I use LRGB Baader and all the filters do not need refocus among them.
which also means you can take flats at the start or end of each session just sliding the filters with the filter wheel (if you did not refocus during the night for heavy temperature drops).
Regarding how to batch the single filters sessions, I have an advice by my experience :
if gradients are moving in the night (like the moon does) so keep your sessions as big blocks of subs for each filter to have as much possible constant gradients in your subs stack.
Björn Arnold:
Thanks for this insight - makes a lot of sense. I need to try this technique out next imaging session.
Well written
Acquiring mono RGB data over the city
Total newbie here. I have a mono camera and a filter wheel. First light was an underexposed OIII stack of M 16, 3 days ago. Well, first light was actually 90 minutes of Ha the day before, but so out of focus to be useless! ooops. I have the advantage...
Directly addresses RGB capture technique for mono camera workflow.
Aug 6, 2019
RGB acquisition strategy
That's it, four years after (re) starting astrophotography with an EOS 6D and camera lens, I finally bought a dedicated mono camera (ASI2600) What are the pros and cons of the various possible ways to spread the RGB acquisitions over night: all R...
Directly addresses RGB acquisition strategy with mono camera, matching your current focus.
Sep 8, 2022
NINA vs APT
Hi, This is my first post here and I hope this theme has not already been dealt with (I could not find the Search Forum feature). I have a 6" F5 Newtonian and a Canon 800D DSLR (no mount yet but I'm looking for one). I'm in Europe. I dow...
Relevant to DSLR RGB imaging workflow with Newtonian telescope setup.
Oct 21, 2019
