Takahashi FSQ-85EDX- 1.0X Flattener and Chroma 3nm SHO Filter HALOS -SII
7 replies241 views
Brian Diaz avatar
HI
here are  my first masters of HA , SII and OIII  with my new setup (Takahashi FSQ-85EDX- 1.0X Flattener  and  Chroma 3nm SHO Filter)
for my surprise in the SII  master there are two stars with HALOS ( Tejat and Propus ) any ideas
i would appreciate any suggestions
just stretched, not DBE or anything else
thank you
Bob Lockwood avatar
As I stated in the other post about the FSQ-85EDX, mine was an earlier version, just the FSQ-85ED, and I never had any issues with halos or the hourglass effect
on any stars. I also use Chroma 3nm SHO filters as well with no halos, so it must be in the design of the EDX, and or the flatteners or reducers as I can also see the hourglass effect on the two bright stars in your image as well. I don't think the halos are filter related.
Just a thought.
Brian Diaz avatar
thank you for you help
Ted Mickle avatar
I have the same setup with FSQ-85 ED, 1.01 reducer and Chroma 3nm SHO filters, and get the same “inverse lighthouse“ effect.  I contacted Takahashi America in Houston, spoke with a gentleman who owns two FSQ-85s and was told that pattern is due to diffraction and is intrinsic to the Petzval design.
milkywayrod22 avatar
I also have a Takahashi 85 ED FSQ.  The hourglass appearance on very bright stars is present on all my images using Astrodon LFGB filters.
Brian Diaz avatar
yes the light house  on very bright stars is a takahashi signature or pattern
 the problem is with the halos around the bright stars only SII
Dunk avatar
Brian Diaz avatar
thank you dunk
Guiding issues or something else?
Hi all, Yesterday I finally assembled my setup after 2 months - nice feeling to be with rig again Unfortunately the real night here starts only at 23:00, so it's quite though to do all normal tweaking of the setup. After the normal setup (polar a...
Star halos could result from guiding issues affecting image quality.
Jun 17, 2025
Narrowband Filter Shootout - Chroma 3nm vs Astronomik 6nm
I tested these side by side and posted a review: LINK: https://astrogeartoday.com/narrowband-filter-shootout-chroma-3nm-vs-astronomik-6nm/
Documents Chroma 3nm filter performance; directly relevant to author's tested equipment.
Aug 3, 2022
