Problems with my 2600MC Pro?
14 replies856 views
David Ebbecke avatar
Last night marked my 3rd night out with my new 2600MM Pro.  During each night I've had issues with what appears to be condensation
 First night:  I made the following post.  Chalked up up to failing to switch on the camera's dew heater.  Prior to going out for a second night I inspected the sensor (removed EFW) and it was spotless. https://www.cloudyni...worried-newbie/ Second night: Started off with similar issue but different pattern in the image.  Camera's internal dew heater on the entire time.  The issue seem to resolve rather quickly.  I didn't get any images from the second night. Last night: 30 minutes prior to imaging I set up the scope.  Temp:40 deg. F.  When I was ready to image I switched everything on and noticed the same issue, however this time, the problem worsened over the next ~1 hour until I decided to end the evening in frustration.  Camera cooling set to 0 deg. the entire time.  It was approx. 38 deg. F when I started imaging and 35 deg. F when I quick after about an hour. Below is the progression.   Do I have a problem with this camera or is it me?  Looking to the collective wisdom of other.  Thank you!
Greg Erianne avatar
Hi.  I offer this since I see something similar if my target is low and there are tree branches in the FOV.   What was the altitude of your target when you captured these frames?
Honestly, I'm not sure that's your problem at all, but I notice the same pattern of shifting dark areas when there is something (like a tree) interfering.  Once the target gets high enough, that dark pattern disappears.
I was using an ASI2600MM (dew heater on, temp around 15 deg F, no visible condensation/dew on 107PHQ objective lens).  After about 10 subs once the target got high enough, the frames looked perfect.  Time to trim that tree!!
Oh wow!  I actually was shooting in between some trees to PA and I can see how I may have had obstruction in the FOV.  I did return the mount to home position and shot a final image (last one in the series in my post).  It looks different than the others, so that still has me wondering?  But, if the issue turns out to be what you're suggesting, boy am I going to feel silly (and embarrassed)!!
Really appreciate your reply, Greg.
David
Respectful Supportive
Greg Erianne avatar
I lost count – a LONG time ago! – of the silly things I've done, David!  LOL!  Fingers crossed that it's something simple and easily explained.
Greg
Glad to hear it's not only me!  Yes, fingers tightly crossed.  Thanks again, Greg!
Dave
Leonardo Ruiz avatar
[pre] [/pre]
Harry Karamitsos avatar
Seriously, when I got my edge 9.25, I was setting up and testing it out inside because it was cold. I looked through the viewfinder and I could not get the image to focus no matter what. After a while I realized that I was looking through  a clear stained glass window. Never felt stupider…
Gary JONES avatar
I deebbecke,
IMHO that is definitely not dew - it's almost certainly an obstruction such as a twig or branch of a tree.
The shadow appears to move upwards and to the left in the first 3 images, suggesting a fixed object in the field of view, and the stars in the shadowy areas are crisp and round, although not as bright as in other areas.
Dew generally causes a 'hazy' appearance across an area of the image, causes halos around bright stars, and tends to fade away from the edges as the dew heater does its job.
Attached is little movie showing a good example based on a series of 3-minute exposures - you can see the margin of the dew fading to the right after frame #20, until it disappears completely at frame #36.
FYI - I accidentally bumped the telescope at frame #22, which caused 2 offset images to be captured in the same frame - but note how the edge of the dew progresses smoothly from frames #20-35.
I think it's safe to say that your 2600 is working OK, but I suggest the following :-
1. Set up your gear well before dusk - to give your camera and OTA time to stabilise;
2. Switch on your dew heater and cooler when setting up, well before you start imaging - 30 minutes is definitely not long enough;
3. Keep good notes about the temperature, humidity and dew point - that helps a lot when troubleshooting.
I hope his helps
Gary
20 40 43 = NGC 7184 - Barred Spiral Galaxy 720p.mov
JohnAdastra avatar
Those longish dark spots do look like branches. Test again in clear sky.
Some early 2600MMs had some issues with silicone leaking from the heat transfer pad, but I think that bad component had been replaced. But that would be in every frame.
With all my ZWO cams, I take them apart at least once a year and nuke the desiccant pellets in the microwave. That will help with any condensation inside the sensor cover.
Good luck.
Helpful Concise Supportive
I appreciate all the responses!  Feeling a little better about the state of my camera now.
Gary - Yes, I see how these images resemble tree branches.  The 4 image is notably different though.  Not sure if this pattern can still represent an obstruction in the FOV.  I'll get back out there this weekend to retest and provide an update.  I will definitely start putting into practice your recommendations for set up.  The movie you attached provides a nice example of dew and the characteristics it had as the night progressed.  Very helpful!
John - Thank you for your recommendations as well!
Gary JONES avatar
Hi deebbecke,
Many thanks for your kind comments smile
I think a case can be made for leaves to have caused those dark areas … as I mentioned, the telltale sign for dew is halos around bright stars, which are not evident in your images.
I've fallen afoul of trees many times. It's extremely difficult to tell by eye whether a branch (or my roof) might be in the way - this is one of the main reasons I fitted a laser to my telescope - now I can be 100% certain when my FoV is approaching an obstruction, before it spoils an image.
Gary
Oscar H. avatar
Harry Karamitsos:
You remind me of something:
One night I tried to focus my guide scope, but the image was all black; I repeatedly tried focusing both ways, but couldn't see a single star; I thought "what's going on? Why is my guide cam so out of focus?" I even increased the gain to try to help me see stars.
Well, then I saw that the dust cap was on the guide scope...
Louis Fico avatar
Is this frost?
Gary JONES avatar
No, I don't think so …
Frost typically causes loss of detail and the appearance of halos around bright stars, neither of which is evident in the 4 original photos.
You can see a good example of the effects of dew/frost in the movie attached to my post above smile
Gary
Well Written Concise
Great idea with the laser, Gary!  I'm dodging trees where I live (as you have already witnessed), so I don't see this problem going away unless I take steps to mitigate.
I really appreciate your recommendations.
Clear skies!
David
Pegasus Issues of Late
Recently, I updated the software on my PPBA Gen2s to version 2.8.4693.435 of Unity. I immediately started having issues with the devices connected to the USB2 ports. They would just randomly disconnect during the night. Sometimes it happened after fi...
Software update issues unrelated to dew/condensation problems.
Jun 8, 2025
2600MC Pro disconnection issues
Hi all, Having an issue with disconnects every since getting a new 2600MC Pro. I am using an ASIAIR Plus and have had over a year of use with a DSLR without this issue ever occurring. This my 3rd night of using a new 2600MCP and on each night have ha...
Different camera model; disconnection issues not condensation-related.
Nov 25, 2025
One dew solution that may not be for everyone.
I live in coastal Southern California and I have always struggled with dew prevention on my 10” DIY newt… I’ve tried dewshields, dew heaters, burning sage, shamans, you name it. Dewshields are ungainly and huge. Dew heaters would generally overheat t...
Directly addresses dew prevention solutions for imaging equipment.
Nov 28, 2025
Focus cube running to zero with out of focus camera issue
I’m using N.I.N.A./Skywatcher Esprit 120 ED/Pegasus Focus Cube and a ASI533 mm camera. I’ve used this setup for a long time with good success. Last night when trying to focus I’m running to 0 and the focus program shows an error. If I disconnect the ...
Different equipment focus issue; not related to condensation.
Sep 12, 2025
