Noise Reduction in Workflow
14 replies573 views
Mark Germani avatar
Hi folks:
This question has the potential to generate a wide range of responses, but whereabouts in your workflows do you guys like to reduce noise (if you do) and if so, how do you prefer to go about it?
I ask this because recently, while processing some imaging I'd done of galaxies that are rather small for my FOV, I discovered that by reducing noise earlier in my workflow (before any sharpening/high-pass/unsharp mask) I was able to get much better results than by noise reduction as a final step.
This got me thinking; should I be doing some mild noise reduction really early on, perhaps even while stretching or to my linear data? Am I exaggerating noise by stretching it before reducing it?
I have Topaz Denoise AI, but I'm liking it less and less - Adobe Camera Raw seems to generate fewer artifacts, and the Deep Space NR and Space NR from the Astronomy Tools Photoshop action set are pretty useful.
Any input is appreciated here. Thanks!
Mark
astropical avatar
Hello Mark,
Just for reference, this is what I am doing in Photoshop:
Moon images
Apply a Gaussian Blur (0.5) before unsharp mask, but after a high pass.
DSO images
Duplicate the layer and apply a Blur/Average filter, then blend the layers with Lighten.
Robert
Fritz avatar
I do it very early in my workflow and definitely before stretching as I have learned, that it is much harder to control stretched noise. Sometimes, if necessary, I do a very light noise reduction as a final step, but usually I try to avoid this.
Generally I try to make my noise reduction as light as possible.
Fritz
dkamen avatar
Hi Mark,
I find that it depends on the noise reduction algorithm and your workflow.
For me:
- If I have DSLR images and I do the nonlinear workflow, then applying a modest denoising with Rawtherapee even before the individual subs have been stretched is a must. Mind you, if you are just curious you can actually extract a crazy amount of signal from the sub using other tools in Rawtherapee e.g. with Retinex. But the subs become less "integratable" (not sure that's a word, smile ).
- If I do a standard calibrated workflow:
-> SCNR helps removing excess green. Sometimes it works better if you apply it before stretching, sometimes afterwards. Sometimes it is even needed before any kind of color calibration. I guess it depends on the amount of excess green.
-> MultiscaleLinearTransform works on a linear image. MultiscaleMedianTransform works on linear and non-linear. But I haven't been using any of those two for years.
-> I find that ACDNR works better after the image has been stretched, but you have to raise the star protection thresholds because the defaults are for linear images where star brightness begins at 5%. I do not use that process too often.
-> Darktable's Astrophoto Denoise reigns supreme, but obviously it is applied at the very last stage, after the integrated image has been stretched exported from PixInsight as a 16 or 32-bit TIF.
Usually with Pixinsight I do only SCNR at some point that I determine by trial and error, followed by Astrophoto Denoise when the image has been brought into Darktable.
Helpful Insightful
Dominik Sito avatar
My Pixinsight workflow that works best so far is as follows:
Linear Stage
- TGV Denoise - reducing hi-frequency noise
- Multiscale Median Transform - reducing low-frequency noise
Non-linear stage
- ACNR to smooth out any remaining artifacts
All above are done with inverted luminance mask to provide even better detail and HI-snr areas protection and fine gradation of the NR effect.
Daniel Erickson avatar
Hi Mark!
I don't make any claim to expertise, so caveat emptor! At this early stage of my AP development, I tend to do whatever I'm going to do quite early on. I do an SCNR almost immediately to get rid of the noisy green pixels. I do that in Siril. Once I'm in PS and quite early on in that workflow,  I do some minor NR using ACR--specifically the 'Texture" slider and then I pop into the Detail tab of ACR and make a few additional adjustments there. I rarely go more than '10' on the NR slider and sometimes as high as '50' on the CNR slider. These are global changes, of course. I find I rarely need anything more, but if I do I can mask and adjust as needed.
I have also used Topaz Denoise, and sometimes still do, but that would also be early on in the flow.
In any case, I figure that noise needs to go as early on as possible, before I start enhancing and modifying it and getting it confused with real signal.
Daniel
Daniel Pázmán avatar
Hi Daniel,
i am with Dominik. So i use the same techniques and they works super for all of my images. In some cases a final low MMT after your processing Workflow. There are some good tutorials on YT.
Best regards
Daniel
Mark Germani avatar
Hi folks:
Thanks for all the responses! I should have added, I'm not using PixInsight, so all the PI-specific workflows are a bit outside the realm of possibility for me right now. I'm renting Astro Pixel Processor, which currently doesn't have any NR functionality. I guess what I was wondering was more theoretical and less application-specific.
I just finished reading the post-processing chapter in Michael Covington's Digital SLR Astrophotography, and he claims that it doesn't make much difference to reduce noise in linear before gamma-corrected, but I'm sensing from your responses that it helps to get it in, at least minimally, early on in post-processing and I'm inclined to agree.
If we are being application-specific, I do have Siril, which I used before getting APP, but I find I can't shift FITS files between the two, so Photometric Colour Calibration & SCNR is off the plate at least until I get that figured out. Opening a FITS file in APP which it didn't generate itself, or which was edited in another app, produces a black image which cannot be stretched. I've been approximating SCNR with Star Colour Calibration & by reducing green saturation in Photoshop using the Camera Raw filter.
Thanks to everyone who has chimed in!
Mark
Jerry Yesavage avatar
Hi, in PI I "take the fuzz out" at a non linear level since that will just get stretched into a mess later.  I am using Topaz AI in the stretched images and very happy.
Please note that I destar my stretched narrow band images before noise reduction and stretching… this is essential.  Then put them back.
Wim van Berlo avatar
I have the advantage of reasonably datk skies (mag 20.4), and I do most of my noise reduction early in the process: I gather more data. During post processing I hardly do any noise reduction, except for removing a green cast with scnr in pixinsight. On occasion I remove chrominance (colour) noise in the rgb image prior to lrgb combination.
Mark Germani avatar
I'm reading a lot about SCNR on this thread, which is not available in Astro Pixel Processor - and HLVG is PC only (I'm on Mac). Is excess green signal as much of an issue when using drizzle, which I almost always do as I am slightly undersampled? I know the SNR on the green channel is nearly always better than the other two channels (I'm using a DSLR).
Mark
Lynn K avatar
Hi mark, I also use Photoshop ( v5) for my post processing.  The main PS tool is Filters-Noise - Reduce Noise.
Your question was addressed to when to apply noise reduction and you got a lot of responses to that question.  But I would like to be more general in my response.  I looked at some of your images and see you are using a non-cooled un-modified Canon 3Ti on and iOptron Sky Guider.   Most of your images seem to be in the 1 to 3 total hour accumulation range.
You mentioned your post that you might get varied responses, so, here it goes.  Signal/Noise ratio will vary based on acquisition approach and equipment used. Not to mention the most important, the level of sky glow.  Your question is more directed at short acquisition using a non-cooled un-mortified DSLR.  Your acquisition will render a poorer S/N ratio than someone using long total exposure time with a less nosier system.
So yes, if you S/N ration is poor, then stretching it early in post processing will likely create a S/N problems making it difficult to bring out the signal latter.  IF your S/N is very good, then doing a early noise reduction may be counter productive because you may over soften the fine detail and not be able t recover it latter.
I have learned that one size does not fit all with image post processing.  Data can vary a great deal and will demand different approaches.  It can vary even with the same equipment at the same site based on transparency and seeing.   But given different equipment, different acquisition techniques and different sites, what works for one may not work for another.
I have used a DSLR rarely and use a modified Canon T3.  So, I am fairly un-familiar with processing OSC DSLR data.  I use cooled CCD cameras and primarily use narrow band filters.  But some general approaches may apply.   If the S/N is very poor them one must accept that the data will not allow much stretching of the data, and you discovered early noise reduction may help.  If the S/N is good then the data may allow aggressive stretching and little noise reduction latter in the post processing steps.
BUT, I would like to rephrase you question to not when, but where.   The S/N will not be equally distributed throughout the image.  The stars will likely have much better S/N, as the brighter areas of the subject.  The fainter/darker areas along with the background will likely have poor S/N.  By processing all equally, you are trying to turn right and left at the same time.  You want to stretch/bring out  the better S/N and smooth/hold back the poor S/N. The image must be thought of in zones and each zone processed differently.    Certain algorithms in Pix Insight and other software can do this.  The  PS action plug-ins do this.  But you can do very effectively yourself using Mask in Photoshop.  Mask can seem overwhelming, but is actually fairly easily ones you get the hang of it.  Mask allows you to selectively sharpen areas of the image and smooth (reduce Noise) in other areas.
My suggestion for handling the noise in your images is to first, if possible obtain longer  total session data.  Second, I would suggest learning to use Mask rather relying on when to apply a noise reduction to the Whole Image.  Adam Block's PS tutorial are excellent.  I know it is hard to lay out $100 on a download, but it may be the most beneficial thing one can do to improve image processing.
I hope this helps some, Lynn K
Helpful Insightful Respectful
Mark Germani avatar
Thanks Lynn!
Without a good CLS filter, I'm pretty much limited to short exposures for broadband targets at the moment, and I'm starting to get a feel for how much noise light-pollution actually adds. When analyzing subs, light pollution seems to be counted as signal as it's not dark or read noise, so the numbers are a little misleading. I discovered this recently when stacking my M51 image - Astro Pixel Processor gave higher quality scores to a session where I had terrible seeing and was limited to 20s exposures than I suspect those subs deserved, and my SNR improved significantly when I manually removed them from my stack instead of having the program automatically remove the poorest 10% of all subs across all sessions. I'm going to have to use a bit more common sense when selecting which subs to stack.
I come from a design background, so I'm pretty comfortable with PS & layer masks. I usually process to a certain point, then split my image into background & target layer groups, and I mask out the background in the target group and apply separate NR, stretching & sharpening to each. Your comment about SNR being different for different areas of the image is really intriguing - I hadn't considered this, but it makes sense considering this is how I tend to approach processing.
Ultimately, though, I just need to pony-up for that Optolong L-Pro.
Mark
Jared Holloway avatar
I use PS, my workflow usually looks like this in some fashion:
Initial levels
Levels with threshold mask
Curves
Gradient (maybe a level adjustment)
RAW Camera filter (minor adjustments)
Noise (Topaz Denoise)
RAW medium adjustments
Space & Deep Space Noise (Astrophotography Tools Actions)
then I check star reduction, star color, etc
So.. I typically do noise reduction early but always after my initial curve adjustment. I also use layers so I sometimes go back and start over and use noise earlier and later just to see if there is a major difference
Lynn K avatar
Mark, your graphic design experience is a real advantage.  I come from a Fine Arts background (painting/drawing - retire art prof.)  My 70s education lacked any computer training. Yes, the stronger signal area need to be dealt  with differently that the nosier poor S/N areas.   I use to rely on Curved to isolate those areas, but have found that mask does a better job.  I pretty much always use a mask in Curves.  And I always use a mask with reducing the noise, because I do not want to soften the sharp signal.  And Visa Versa.
There is an out of date book , The New Astro Zone system for Astro Imaging by  Ron Wodaski.   It's all Photo Shop directed.  One would have to fine a used copy.
I have to admit, I only read the 1st couple of chapters.  The problem I found with his specific PS recommendations was that the data needs to be very good S/N to work.  One would need to adapt his recommendations to a poorer S/N data.  But the basic approach would be near the same.
I currently need to perfect the process of removing the stars, and process the nebula separately.  I often mask the stars or cut them entirely to do High Pass Filtering.  You may already be a aware, but the image itself makes a great mask.  From there you can alter the light/dark areas with levels or invert it to block the stars and brighter parts so the background can be smoothed (reduce noise).  I use to use the Magic Wand Tool to select areas, but now rely on altering the image pasted in to a mask.
Lynn K.
Tell us your Gimp secrets
If anyone has any secrets as to how to process in Gimp, put them here! I'll start: G'MIC is a great add on for Gimp. Iaian's noise reduction and Iaian's fast noise reduction are great.
Directly addresses noise reduction in workflows, matching author's G'MIC interest.
Apr 16, 2020
Criticism and Pointers needed!
Hello; I recently acquired first darksite'ish data with my Hyperstar4 setup and pretty pleased with it. I acquired M42 data with different exposure lengths on a plan to do a composite. I created the composite and was able to get decent data on th...
Noise Reduction in Workflow — addresses noise management in processing pipeline decisions.
Nov 30, 2019
