I have run into this very bizarre flat calibration issue in Pixinsight.
Just some background, I imaged a target with my Luminance filter on my 6200mm pro last night, 60s each frame, for a total of 250 frames, at gain 100, default ASIair offset (50), -5c, using the AG Optical Convergent FA12. I captured 30 flats using a Primalucelab Gitto 430mm flat field frame generator. I set the brightness of the flat panel to take 1.4s Luminance Flat frames to achieve just over 20000 ADUs.
I calibrate my flat frame with bias frames (being the shortest exposure possible for my 6200mm pro).
So after calibrating and stacking all 250 light frames in WBPP, I get this:
So multiple issues with this frame. There was undercalibration of the flat frame patterns. The second more strange issue is that not only was the dust mote on the right not calibrated out, but the dust mote on the left is something that did not exist at all in the light frames or the flat frame.
I really was sctratching my head, thinking maybe I got that dust later in the imaging session, but blinking through the images did not reveal that much. And then I realized, if I flip flat frame 180 degrees, the same dust mote on the right falls exactly in position of that *new* non existent dust mote on the left.
I then further looked into this. My imaging session of 250 frames, had 184 frames before the meridian flip, and 66 frames after the meridian flip. My theory was that the flat frame calibrated in the wrong orientation for the second half of the light frames, or something to that effect. To test that out, I just stacked the calibrated first 184 frames before the meridian flip seprately. This was the result:
The image is still under corrected. The large ring artifacts are still present, but the dust mote that was created to the left upper corner completely disappeared.
I have now taken flat darks to match my L 1.4s flats, and will try to stack and calibrate with WBPP again to see if it will fix the undercorrection, but at this point I do not have any faith in what is going on with my flats.
Any idea what the problem is here?
