FRWiltshire avatar
I have seen the impressive KL4040 images posted on this forum and read many of the discussions that they generated. I am considering a KL4040 for DSOs but am confused as to how to integrate it into an automated imaging session given the three channels generated for each exposure.
I presently use:
MaximDL and FocusMax to control a FLI ProLine
TSX to control a Paramount MEII
CCDAP to automate  imaging sessions including acquisition of calibration frames and flats
TSX and  @focus to perform TPoint mapping and to occasionally perform PEC Training  within TSX
Is anyone using a similar setup  with the KL4040 or do you see issues with this approach?
Could anyone comment on the software and strategy that they use with the KL4040?
Is FLIPilot required for imaging just used for setup?
Thanks in advance,
Frank
John Hayes avatar
One suggestion:  You might call Tolga at Tolga Astro.   He has experience with that camera.
FRWiltshire avatar
Thanks John,
That is on my to do list.
Frank
Mosaic problem! Help!
Hello! I am doing a mosaic of the Sadar region, hoping to go from the crescent nebula all the way to the North America Nebula using the redcat 51 and asi1600mm. Im approaching 30hrs total integration time of just Ha data, but Im having some annoying ...
Not relevant - focuses on mosaic imaging with different equipment (RedCat 51).
Jul 16, 2022
Fixing the dreaded tilt and backspacing error in optical systems with objective analysis.
Fixing the dreaded tilt and backspacing error in optical systems with objective analysis. The curse and blessing of modern CMOS cameras is that amateur astro-imagers have easy and relatively affordable access to extremely high resolution detectors bu...
Not relevant - addresses optical tilt/backspacing issues, not multi-channel integration workflow.
Jul 29, 2022
