[RCC] M63 comments requested
6 replies353 views
UlfG avatar
M63 is probably the most difficult object I have imaged so far in my AP "career". With almost 3 hours of integration I still had a poor signal and problems with noise and there was also some disturbing stray light. The color was also somewhat strange when the images was stretched. Among other things I have intentionally reduced a yellow/reddish glow in the central part. Please give me comments on acqusition, processing, color etc.
Link to image:
HR_Maurer avatar
Hi Ulf,
i did the Galaxy myself in 2018, which was the beginning of the time when i started to go one step further with frame numbers, resulting in one level up in my image quality.
You have good detail in your image, but i think you did slightly too much sharpening. Another point is the stars, i think you could improve it by using a ring cover (is this the right word? Ringblende) for your primary mirror, to have the active footprint circular, and see if there are any reflecting surfaces you can cover.
One thing i'm wondering about is the blue-purple gradient - i think this is not real. A related issue is the color of the Galaxy's outer regions - there is this bar-like structure above the galaxy center. Above and close to this bar, the colors are more black/white. Elsewhere there is this blueish hue.
When you're complaining about stray light, this might be the reason. Also affecting the overall color balance. It might also seep into your filter drawer, if you use one. Restoring the original colors from stray light affected data is very difficult. However, my Sunflower had a yellowish appearance, too, and I think in general i like your colors.
CS Hoschie
UlfG avatar
Hi Hoschie,
Thank you very much for your comments. Regarding the star shape I have bought a ring cover, but I did not yet install it. I will look to do that soon, the season is probably over now anyway, because there will be no more dark nights, so I will have time to work on the scope. The blue gradients you mention I did not see so clearly at first, but when I looked at my image on another monitor than the one I did the processing on I immediately realized that the stray light problem was a lot more serious than I had thought. I will try to start over with the processing and see what can be done.
When I looked at your images here at Astrobin, I did not see your M63. That's a pity. Do you have a link to it?
Regards
Ulf
Respectful Supportive
Vasile Unguru avatar
Hi, great result for only 2.7 hr. i would work a bit on the background trying to reduce its brightness and desaturate it a little. sharpness is a bit high .. in my opinion. Of course it will help a lot if you put another 3 hr of exposures on top it, if possible.
Clear Skies smile
Concise Supportive
UlfG avatar
Thank you, Vasile.
This is a new version with different background:
Clear Skies!
Björn Arnold avatar
Link to image:
What exactly do you mean by stray light? I'm just asking to make sure that I understand this correctly.
Most noticeable is the blue gradient. Did you run a gradient removal tool? It also seems that you might have stretched the background a bit too much.
Color calibration, background removal should be done on the linear image. With that you should preserve your colors.
For the acquisition, you should consider reducing the exposure time of your light frames with your f/5 optics and by that capture more subs. By increasing the number of subs you will improve your signal to noise ratio. Also capture a bit more darks. I find 10 a bit low. Usually I take 30 darks, 20 flats and 30 bias. Bias will be captured once and also the darks can be reused if you have lights with the same ISO, exposure and sensor temperature.
Personally, I try to have the background as a faint gray as a deeply dark background has too much contrast.
Clear skies,
Björn
UlfG avatar
Hi, I now have a new version with 2 hours more integration. Any comments on this version would be appreciated.
Regards
Ulf
[RCC] - First year Soul nebula
Dear all, On the first anniversary of my introduction to this fabulously interesting and rewarding hobby (and at times, frustrating / expensive!) I thought I would reach out and request some feedback on my recent image of the soul nebula: https://www...
Shares similar early-stage astrophotography challenges and seeks feedback on image quality.
Dec 28, 2022
RCC - Wizard in Narrowband
I would really appreciate some views/comments on my take on Sh2-142 / NGC-7380 https://www.astrobin.com/v858rx/ I took this from London so narrowband was a must and, yes, there was quite a bit of moonlight about but with so few cludless nights that w...
Discusses narrowband imaging techniques relevant to nebula processing and color issues.
Dec 18, 2022
New Processing Method to Boost a Weaker O3 Signal- Explained
Here is my example image with this technique. The description below can also be found accompanied with the image. I've been working on a new method for amplifying weaker O3 signals in an image that will create a more natural looking O3 while redu...
Addresses signal enhancement and processing methods applicable to weak nebula signals.
Dec 25, 2022
