Hi All,
I received 2 weeks ago a TS Optics 8'' Ritchey Chretien, and tried to collimate it (out of the box, the stars were just horrible...). I plan to use it first with an AstroPhysics 0,67x telecompressor (reducer) to get more light and less guiding troubles.
Therefore, I will use it only with a 25mm M90 extension tube (not the 50mm), a M90 tilting adapter flange and focuser (in that order, to be able to access collimation screw of the primary). And therefore, this is with this "short" optical train that I have tried to collimate it (without the focal reducer during the collimation process of course).
Until now my procedure has been :
- Remove the "top" part of the central baffle - without opening the telescope, just by unscrewing it, passing my hand between the spider - in order to be able to see the reflection of the doughnut of the secondary mirror on the primary.
- Using my Takahashi collimation scope, I have carefully adjusted the primary mirror so that thin circle of light around the bunch of reflections is concentric to them and even. I can barely see the circle of light because of my short optical train. I have also tried with a 2'' 80mm extender tube between the focuser and the collimation scope, but results are similar in the end.
- Then I performed a first adjustment of the secondary so that the doughnut appears to be concentric with the collimation scope center black hole / spot (where we look at).
- Then I fitted my Howie Glatter 2'' laser (just the spot) in the eyepiece holder of the telescope to adjust the M90 tilting adapter until the laser hit the doughnut (it was already within it, but touching it on one side). So minor tweaks. I have used my DSLR and a 105mm macro lense to use my liveview to be as precise as possible. I also checked the Howie Glatter was calibrated by turning it on itself within the eyepiece holder, and the spot did not move and remained almost exactly in place.
- Then I adjusted the secondary mirror until the laser beam hitting the doughnut was coming back to itself (again using the DSLR and playing peekaboo with the laser to see alternatively the emission spot and the sum of the two).
- Then I mounted the holographic attachement to the Howie Glatter to get the circular pattern projected : some say you need to re-adjust the secondary until you have concentric circles on the primary (by focusing more or less until one of the circle is on the edge of the primary, then adjusting the seconday to have the full circle on the edge); others say you only check the projection on the wall, and adjust the primary until your circles are plain and not half there. I have chosen this option, doing minor tweaks only to the primary.
- Then reiterated the process a few times : tilt ring to hit the doughnut, check that the spot is coming back to itself (alignement focuser / secondary) and then again adjusting the primary with the concentric circles.
- I also checked if the infinite reflections between the 2 mirrors were good : and they were, straight to infinity, looking from just above the secondary (no right or left deviation) and the same when looking just on the left of the secondary (no up or down deviations).
- Screw back the top part of the central baffle, trying not to touch the secondary (thought it shouldn't move that easily...)
THEN : the truth. The test under the stars.
As you can see below, it went wrong.... My stars are in really bad shape (compared to what I was expecting from the books).
I thought I could finalize from there. I understood I would see the shadow of the secondary mirror more or less centered in the star, and adjust the primary just a tad to make everything perfect and symmetrical.
But playing with the primary had some effects, but not enough to make thing well. I did not want to screw my initial collimation and stopped after making more than a 1/2 turn of screw (I did that once, and when looking through the Taka collimation scope, I saw the primary was completely off).
Maybe I should have ?
Then I tried to play a bit with the secondary : almost nothing changed (with 1/4 turns of screws... that's big). Then thought about the tilt ring (more weight ?), but the same, nothing improved really.
From where I left, given the strange shape of the star, what should have been my next step ? Primary ? Secondary ?
Thansk for your time, again...
Nota Bene : below there is only 1 serie of shot on a bright star (500ms exposure) with various focuser position. I just duplicated it and make one of the series bright to better see the shape of the star / stain...
