Getting correct (55mm) distance between field flattener and Camera CCD with ZWO EFW inbetween the two...
Hello everyone, I'm new to the forum so please forgive my lack of knowledge as I am relatively new to astrophotography & setting up equipment.
I wonder if anyone could help with this...
I am trying to get the correct distance between my 0.8x field flattener and the Altair 183m camera with a ZWO 8 position EFW fitted with 1.25" filters inbetween the flattener and the camera.
Now I do have a 1.25" nose piece and the piece that this slides into. These two pieces assembled had M42 male each side, which fitted perfectly between the camera and the EFW, meaning (to my mind at least) that all I needed was an M48 female to M42 male adapter ring.
Sadly though, now knowing that the EFW needs to be as close to the camera as possible to reduce any halo effect, I can't make use of this setup anymore, or can I?
If I can't, how would I go about achieving the correct distance?
I have a Starwave Ascent 80ED field flattener/reducer 0.8x (M48 male) , a ZWO 8 position EFW (20mm depth, M42/T2 female each end) fitted with 1.25" filters and an Altair 183m camera (M42/T2 female).
If anyone could advise, I would be most grateful.
Thanks,
Shaun
Thanks,
Shaun
