How's my driving? Dial 1-800......
16 replies313 views
Scott Badger avatar
Sorry, maybe that's just an American joke..... Anyhow, I'm about a month into my first scope and so far, so good. Slowly, but surely (I like to think...), I’m ascending the various learning curves and, being in northern NH where clear winter nights generally mean cold nights, learning lots about layering too!... Gear-wise, the next step is to add guiding, but after the scope and mount, a little financial r&r is needed first. So in the meantime I’m working hard at optimizing my tracking and would greatly appreciate any hints or suggestions.
I’m using a C925 (usually with a reducer) on a CGEM mount and a Canon 5D IV. Last time out, after a 2 star alignment plus 3 extras and polar alignment, I pointed the scope at Bodes with a little jiggering to get the Cigar galaxy in the frame as well and started imaging (FWIW, I also used the Precise GOTO function which fine tunes the alignment on a nearby star before slewing to the object, but don’t know if that adds to the general  alignment, or not). Anyhow, I let it go for a bit over 6 hours with no alignment adjustments (only stopped the imaging once for a battery change) and over that time the total drift was approximately 7.5’ (about 10% of the fov). So, first question, is that reasonable or can I do better? I'm afraid I don't know if the drift is strictly RA, Dec, or a combination of both.
The images were 120s exposure (iso 2500) and about 2/3 have reasonably shaped stars. For the most part, the third of the images with more noticiceable star distortion don't show smearing or egg shapes, but imore like a double, mostly overlapping, exposure. So maybe not as much a 'tracking' issue, but instead the mount making larger scale adjustments mid-exposure which, in effect, slightly shift the star position relative to the frame? Does the Celestron's periodic error correction process address this, or is there something else I can do? And will guiding help or is this something different?
I've attached auto-stretched jpegs of a relatively good image and a couple with more pronounced star distortiuons. Happy to make the raw images available if that helps.
Scott
Lynn K avatar
Hi Scott.  I think for a C9.25 with 2 min unguided subs, you 1st two subs look very good.  The drift is caused by mis-polar alignment and will always be in DEC.  RA error will be a back and forth motion caused by the imperfection in the worm/drive gear.  If you look through  a 10mm or so eyepiece at F10 at a star, you will be able to see the back and forth motion of the RA drive.  As the star slowly drifts up or down (it will go one or the other, not both) that will be in DEC caused by mis-polar alignment.  Periodic Error Correction (PEC) is a programed over ride of the RA drive that is designed to speed up or slow down the tracking in order to correct the periotic RA tracking error.  As for as know, Celestron does not pre-program PEC into its mounts.  You will have to do that yourself.
Starting out with a long fairly heavy scope such as the C9.25 is pretty bold.  Starting with a small refractor it much easier.
I think you can expect to loose a certain amount of your sub frames to bad tracking, flexure, wind and so worth.  That is just part of the dynamics of and unguided long focal length scope.  Auto Guiding will eliminate that for the most part.
I am surprise you did not have to refocus over a 6 hr period.   Since the session was 6 hr. the angle and weight of the C9.25 probably shifted.  That can cause flecture during an exposure.  That may be the cause of the double star images.  But it can also be wind or cable drag/hanging.
I hope this helps some what.
Lynn
Helpful Respectful Engaging
Scott Badger avatar
Yeah, I knew the scope was a big first step, even compounded the risk by giving up on a 3 months and counting back order and bought a used scope on eBay instead… But so far, things have actually gone smoother than I expected. For sure, not always smooth....; ). And the months of backorder were probably a good thing as it gave me time to do a lot of reading and to get started learning the software using data I got on itelescope. Anyhow, after sending my post I mostly worked my way to the gist of your explanation regarding RA and Dec tracking but I really appreciate the detail you provided. In essence, star alignments get the scope there, and polar alignment keeps it there, right? FWIW, I noticed that the direction of the star distortions was generally not in line with the overall drift, which I think is consistent with what you said. You're correct that the mount's periodic error correction function is a record and playback process. I'll play with it next time out, but at the moment I don't a have a cross-hair eyepiece and using the center ring on my camera screen as a reference won't be very exact.
Regarding focus over the 6 hours, to be honest I just got it going and went to bed (other than a groggy 3am battery change in my bathrobe...). At the moment it's still more about working through everything than the data. In any case, the sample images I chose bracket the session to show the overall draft; the first (best) image was taken about two thirds of the way through, the second image near the beginning of the session, and the third towards the end. I don't think I see much of a deterioration in focus, but maybe more experienced eyes.... Also note that at the start the moon was out at a little more than 40% and less than 60 deg**** from my target and then set a couple hours into the session.
It was a calm night and my only cables are the power and handset cords, so probably not much drag to cause the double stars, though I'm curious if the worst, where there's clear separation between them (not shown in my samples), correspond to the 3am battery run.... Until the snow melts, I use the scope on a wooden deck so vibrations can be an issue.
Anyhow Lynn your reply really helps my understanding and is very appreciated!!
Scott
****Side note: Where can I find the angle from the moon for a particular object? I know telescopius lets you filter viewable objects with an minimum angle setting, but if it also gives the angle for an object, I'm not finding it.
Scott Badger avatar
Forgot to add that, regarding focus and scope angle change, at the start the scope was nearly as far over to one side of the mount as possible (I had to set the RA limit to its max so I wouldn’t have to go through a meridian flip during the session) and at the end it was pretty much directly over the mount. Is that an angle change likely to effect focus?
Lynn K avatar
Scott, where the scope is pointing in the sky is not a factor for focus.  However, the atmosphere can effect focus.  As the target moves through the sky it can go trough thicker or thinner atmosphere.  Target closer to the horizon are in thicker atmosphere.   This is why imagers, like myself, like to image near zenith if possible.  The largest factor in change of focus is the scope itself.  During warmer temps physical elements of the scope will expand and as temp cool they will contract. Different scope designs can be effected more or less by temp changes.  The smaller the F ratio the more the scope is effected by temp change.  Lets say that over the night a scope contracts 1/10mm (I have no ideal how much a scope contracts).  That's like you moved you focuser 1/10mm.  A F5 scope will have a short light cone and be effected more than a longer F10 light cone.  The different seasons and weather effect this a lot. A warm humid summer night may see little temp change but a Spring/Fall night may see several degrees change.  This is also effected by climate.  The western desserts will see a big difference.  Different focal ratios also have different focus zones.  Your C9.25 at F10 has a long focus Zone ( the focus distance a scope can achieve good focus).  Where the new RASA scope have a very short focus zone and the in-focus distance is very small and critical.  I did  F2 Hyperstar imaging with a C11 for years.
However, where the scope is pointing does effect tracking greatly.  Picture the latitude lines around a globe.  Imagine moving your finger around the equator and covering the entire circle in 30 sec.  Now do it around the most northern latitude.  Notice the difference in speeds needed to cover the entire circle.  Your mount has to do the same thing.  The equatorial design of the mount adjust for this, but it can cause problems with auto guiding.  M81 & 82 that you were imaging is close to the pole and very forgiving of RA/DEC error.  Imagine imaging the pole.  The mount doesn't have to do a thing, It just sets there.  If you image a galaxy in Leo you may fine the mount is having a lot more tracking error and loosing a lot more sub frames.
Periotic error correction is not really necessary unless your mount worm gear has a bad spot/spots that causes sharp erratic jumps in tracking.  If the was the case, you would have seen a periotic lost of every other or every third sub to streaked stars.   If the the periotic error is smooth, it can be auto guided out.  It can be necessary for imager doing long guide exposures (10sec) to combat seeing.
I did unguided 1 min sub frames a couple of years or so.  When I finally move to auto guiding it was a game changer.  A lot of beginning imagers seem to be moving to auto guiding right away.  Based on their experience, that can be a larger learning curve.  Like you, I needed to learn a lot of the basic concepts and programing first.  I also started with mono black&white.
Lynn
Scott Badger avatar
Aaahhh….you're right, I misunderstood your comments on focus and scope angle to mean the positioning of the scope in and of itself, not relative to the horizon. Thanks for that clarification and information! I knew that as you approach the horizon, seeing deteriorates due to thicker atmosphere, but didn't realize the focus point also varies. I think Bodes was just about at zenith when I started, close but still a bit above 30 deg when I finished and temps that afternoon through night were pretty stable, mid-30s. How does a reducer play into the light cone length/focus margin issue?
Also thanks for the polar 'latitudes' lesson! I'm sure as I saw different and lower quality results with other objects, there would have been a lot of head-scratching!…. I'm actually very familiar with what you're talking about, though, due to an insane way of tow-launching a paraglider behind an ultralight (which have very different stall speeds) a friend came up with. His plan was to fly the slower paraglider in smaller circles inside the larger circles the ultralight towing it was flying. Makes perfect sense…….in principle. smile
For my mount, a full revolution of the gear is 8 minutes and the incidence of star issues like the second image or worse was just about 1/3rd. I had the shutter remote set at 2min 7s to give the camera time after each 2min exposure, so the math isn't too far off from the bad spot on the gear you mentioned. Especially if that wasn't the only factor effecting image quality.
I think a mono camera and filters is what I'll go to, and the next step after guiding, but I had a decent dslr already and to lessen the initial financial blow….. Like you said, though, keeping it as simple as possible to start, even if not achieving the best results, and layering on the additional complexities as you go is the way to stay–nearly–sane….
Scott
Lynn K avatar
A focal reducer will decrease the focal length and therefore shorten the light cone.  Actually, I think that is how a reducer works.  Its optics change the angle of the light cone.  Some reducers will vary the amount of reduction based on distance from reducer to chip.  The Astro Physic 27TVPH I use on my AP130GTX does that.  It is not a field flattener.  There CCDT67 for SCT is the same.  The Celestron 6.3 reducer/flattener is different and the camera chip needs to be at a certain distance from the chip to achieve best flattening.  That's because flatteners actually have a focal length just like a scope.  But the Celestron non-Edge only flattens a small area and not really aliquant for a DSLR.  I prefer the Starizona brand.  I use the older F7.5 and it will flatten an area large enough for a DSLR.  The newer one is f6.3.  Of course more expensive than Celestron's F6.3 , but not much more that there Edge reducer/flatteners.
Lynn
Lynn K avatar
Also a reducer will have many benefits.  Such as a wider field, easier to guide due to shorter focal length and doesn't demand as large a pixel for good sampling, witch DSLR don't have.  By large I am referring to 6nm or larger.  My Starlight Xpress SX-M25c OSC has 7.2nm pixels and is designed for  longer focal length scopes.  I will be using it on a F6.5 65mm refractor for wide field and will be very under sampled at 3.61 arcsec/pix.  It is best to be at 1.5 to 2.5.
Down load Ron Wodaski's CCD Calculator.  Its free.  It will calculate all that for you and and is a great aid for knowing you image scale.
Lynn
Scott Badger avatar
Thanks yet again! My reducer is the Edge 0.7x  and with it the image scale is 0.672 arcsec/pix. Without it, 0.47 arcsec/pix (pixel size of the camera is 5.36 -- http://celestialwonders.com/tools/imageScaleCalc.html)
Scott
Scott Badger avatar
Sorry, one more question…..remember what they say, don't feed the animals….: )
At the amount of Dec drift I had, 7.5 arcmin over 6 hours, does that also have an appreciable effect on image quality? If my math/understanding is correct, 7.5' over that time is 0.021 arcsec/sec, or 2.52 arcsec per 2 min sub, so 3.72 pixels.
Scott
Lynn K avatar
The over all drift is not important regarding resolution.  The drift in each particular sub frame is.  The overall drift will result in some of the image becoming cropped after stacking.  Only the area where all sub frames overlap will be shown/usable in the final stacked image.
As for drift in one single sub frame, the signal as not remained centered on a select group of pixels, but as shifted across a wider range of pixels.  The result is the pixels got lest light because the light was spread out.  As in a traditional photo were the camera moved, you end up with a blurred image.  This is called motion blur as opposed to blur caused by optics or focus.
However it is desirable to NOT have a star/signal on the same pixel in every sub frame.  This is due to pixel bias.  Not all pixels are created equal.  Some are more sensitive than others.  Some or dead/black.  Some or hot/white.  This is increased by shot noise ( the random nature of light hitting the chip due to atmosphere.   Imaging a number of buckets set out in the rain.  Some have big holes in them and all the rain leaks through. Some have small holes and hold most but not all the rain, others or good and catch all the rain and some are covered and catch no rain.  Now the rain is rather random and does not accumulate in all the buckets equally. Light in the same way due to the atmospheric  turbulence.  Imagine that a large sheet of plywood, with holes in it, is put over the buckets with the desire to fill some buckets more that others.  And one of those plywood holes is right over the bucket with a hole in it, and it not gathering any of the rain coming through.  SO, the random quality of the rain and the poor consistency of the buckets render pretty poor signal or a poor measure of the rain fall into particular buckets.  The same kind of things are going on the the way pixels are able to collect light.  So your drift is kind of like the plywood keeps sliding off the buckets.   The smaller the holes and the larger the buckets the less that madders.  That is why large pixels or easier on tracking than smaller ones.
Imagers will combat pixel bias with Dithering. That is a process of deliberately moving the mount/camera a couple of pixels between each sub frame.  That way a light pixel or a dark pixel doesn't always end up gathering the same signal.   The signal is then deposited in a number of different pixels over the session.  Some more sensitive that others.  The signal, NOT THE PIXELS, is then aligned and stacked averaging out the pixel bias.  A stacking program aligns on the stars.  It could care less which pixel the star is centered on.
The irony is, the better tracking the mount, the more likely dark/bright pixels will stack on top of each other.  With your image drift, you got natural dithering.  That will greatly improve background noise.  As your tracking improves, dithering will become more necessary.  You will need Auto Guiding to do that.
Lynn
Scott Badger avatar
I used dithering with the itelescope data, but now I better understand why! Ha! So, if I'm not yet able to automate dithering, and not sure I want to spend hours making a small manual adjustment between each frame (if even possible?…smile, it sounds like drift is my poor-man's dither…..which brings it back around to my question about drift in a single sub and the consequent blurring/light loss. By my math, it works out to be 3 to 4 pixels per sub and wondering if that's a lot, or a little?
Scott
Scott Badger avatar
Also, if in 6 hours my drift was 7.5 arcmin, does that mean my polar alignment was off by something like double that i.e 15 arcmin?
Scott
Lynn K avatar
Scott, your estimate of that is better than mine.  I am weak in electronics and math.  My background/trade is Fine Art/Teaching, which maybe explains my visual explanation.  But obviously you polar alignment was off, and will probably vary every time you set up. The free app
Polar Finder is a real help in knowing where Polaris in on your polar scope reticle.  A lot of imager really like the QHY PoleMaster.  I still use a traditional polar scope.  But mostly image with a permanent set up.
Your question about drift, It would more likely effect the resolution.  How much, I don't know.  But I doubt it it is a good thing, so, better polar alignment is needed.
Lynn
Scott Badger avatar
Assuming I've got it straight, here's my visual….. If polar alignment is off, then the angular distance between the mount's pole and the target is going to be different than it is between the celestial pole and target. This results in two nested but non-concentric orbits** around the two poles that have different radii but share a single point (the point when the telescope was slewed to the target initally). As the object traces its path along the two different orbits, its actual position (celestial orbit) starts to drift away from the position along the mount's orbit and reaches a maximum drift at 12 hours and that difference is equal to the polar misalignment of the mount. The two points then start to drift back towards each other until they're lined up again at 24 hours. So, long story long, the amount of drift at 12 hours is going to be greater than at 6 hours. I'm not sure it's linear difference though (i.e. at 12 hours, double what it was at 6 hours) since we're dealing with curves, but then I'd have to dust off my own very old math skills…..
Don't have a polar scope, but I have a clear view of Polaris from my location and use the finder scope for a rough initial alignment. After star alignments, I then use Celestron's All-Star Polar Alignment process. Next clear night I'll try the drift method too. Is that in addition to, or in place of? Wasn't sure if the mount being synched to the first polar alignment means a second would make things worse, not better….
Regarding drift and dither, it sounded like, lacking proper dithering, drift can be beneficial to some degree as a stand in. So maybe a better way to ask my question is, is that benefit worth any amount of resolution loss?
Enjoying the conversation and lessons! And it'll be a while before I get the image of rain buckets and plywood out of my head….but in a good way!
Scott
**edit: changed ‘concentric orbits’ to ‘nested orbits that are not concentric’
Lynn K avatar
As I mentioned, I prefer a traditional polar scope.  I guess Celestron no longer includes one with the mounts.  They claim the user should use the polar align routine in the hand controller.  Theoretically, that should work well.  The problem is that the tolerance in the mount needs to pretty high and the star alignment needs to good also.  Rather than going into how that works, I will let you read the manual.  But at any rate I think it will be better than using the finder scope.  It is unlikely the finder in parallel with the scope axes let alone the RA axes of the mount.  The DEC would also need to be at exact 90 degrees.
When I started astrophotography. I was using a Celestron fork mounted C8.  Another member had a Meade LX200 fork mount 8"SCT.  We would discuss to length the problems with obtaining good polar alignment.   Difficult with a fork mount.  Visual club members would make fun of us, saying what is so difficult about doing a simple polar alignment.  They had no idea how accurate we needed to be for unguided multi exposures.  It would take us 30min to an hour to drift align.  We both moved to GE mounts with polar scopes and we were well polar aligned within 15 min.  We could only count on 1 min unguided exposures to be predicable.  We eventually started auto-guiding and getting round stars in 5min exposures easily.
Lesson I learned.  Make it difficult and you will do it less and less.  One becomes more reluctant to drag out every thing and spend an hour or more setting it all up, only to get poor results or clouded out.  Each of us has a different level of tolerance and patients with this stuff.  One has to make the set up compatible with that tolerance level.
Lynn
Scott Badger avatar
i agree, take it as far as it’s fun….On the other hand if it was just a point-and-shoot probably most of us wouldn’t be doing it…: )
BTW, I’m not using the finder scope to do a polar alignmen, just to roughly get the mount physically aligned to start. The polar alignment process i use is based on aligning the mount  to the position a star would be at if the mount were accurately polar aligned. that comes after 4 or 5 star alignments.
cheers,
scott
BackyardEOS/APT using Canon T6 DSLR
Morning all, Has anyone out there tried connecting their Canon T6 to a PC for DSO imaging? I haven't been able to get BackyardEOS or APT to recognize my camera properly, it appears to be detected and in APT it shows the name of the device but wil...
No relevance to camera connection or DSO imaging software issues.
May 11, 2019
Advice me for next equipment plan
I want to plan wisely for a serious next purchase so i don't regret and i can calm down and stop buying more for a while, so i am not sure how it should be if it was you. Let's assume you have about $5000 maximum, which one of the following p...
Author planning next equipment purchase; mentions needing financial break before adding guiding.
Mar 20, 2023
