AstroCapture325 avatar
Question for the community on whether flats can successfully remove tree obstructions from light frames.
I recently planned an imaging session and believed that my entire session would stay above the tree in my yard, but I was wrong. About two thirds of the way through the session I started to see subtle, dark, finger-like shadows on my light frames that was caused by the tree in my yard partially obstructing my line-of-sight to the target. Since there aren't leaves on the trees yet, the shadows were relatively narrow and marched across my frames as I tracked the target. There was no wind so the trees limbs were not in motion.
The next morning I captured 20 flat frames. Does anyone know if DeepSkyStacker can use the flat frames to subtract out the shadows (fooling the program into thinking they are just dust and dirt on the sensor)? I would try the experiment myself, except I figured the data was no good and deleted the affected light frames.
Well written Engaging
Björn Arnold avatar
I think it’s not working:
Flats remove static dirt in the optical train. Your tree is moving (w.r.t. sky, telescope etc.). (Besides that usually only the dirt in the optical train is considered and not the stuff outside)
However, depending on size of the tree and the exposure times of the lights, I could imagine that the sigma clipping of the stacking application could catch it. Think of the tree as satellite tracks but just opposite intensity. You might need to play (likely reduce) with the sigma. Just a guess. Didn’t have that case myself.
CS!
Björn
Helpful Insightful Respectful
Norman Hey avatar
Ha! Didn't think of trying as Bjorn suggests–the concept seems sound. I have large maples that cut off my southwestern sky completely when in leaf, but in the winter, like golfers say, "trees are mostly air"… Next clear night, I will give it a shot and report. The key will be having enough unobstructed frames to be the base to which the obstructed frames are compared…
Jérémie avatar
Norman Hey:
Ha! Didn't think of trying as Bjorn suggests--the concept seems sound. I have large maples that cut off my southwestern sky completely when in leaf, but in the winter, like golfers say, "trees are mostly air"... Next clear night, I will give it a shot and report. The key will be having enough unobstructed frames to be the base to which the obstructed frames are compared...
Rejection algorithm could work only if the tree is present on a part of the image only for a very a few frames, - which is unlikely as the motion of earth rotation is low compared to satellites for example - otherwise, its « distribution » among the frames will be closer to the average +/- a few sigma... and it won’t be rejected. You would need to to set rejection aggressively... which will likely reintroduce noise in the final master.
I have had the problem with buildings and antennas, imaging from the city : rejection algo do not work well with static objects present in many frames...
At some point, I was even thinking of aligning my frames, and for the ones that were obstructed, use the data of an unobstructed one - or from an integrated one based on all of the unobstructed ones, to have a better SNR - just for the obstructed part (easy to create a mask by hand or playing through levels in Photoshop) and use Pixmath in Pixinsight to composite these frames. And reintegrate the bunch of frames (unobstructed + « frankensteined » frames).
Of course it would introduce bias and kill the nice effect of increasing the SNR on the part that were « Frankensteined », but would still be better than a few minutes of antennas, trees etc... in the data.
Didn’t have time yet to try though :-)
Happened to me few times in the past. I had to chuck the affected frames.
Nick Ambrose avatar
If you use Pixinsight, this might work for you. You'll get lower signal in those areas you mask off so it will be a tradeoff
https://www.youtube.com/watch?v=ZZVJKo47Ctk
Hey everyone,
Thanks for the additional insight/comments.
Norman Hey avatar
Nick Ambrose:
I had that in mind as a fall back try--neat trick that looks like it might have a few applications.
Cleaning Optics of Celestron Edge HD 8-inch SCT
Can anyone advise on cleaning optics for a Celestron SCT Edge HT telescope? I had a couple of imaging sessions somewhat ruined when my flats didn't work out too well. Some dust/dirt or pollen moving around during the imaging session I suspect so ...
Discusses flat frame calibration issues; directly relevant to author's obstruction problem.
Nov 23, 2022
Gain settings for Flats vs Lights
A basic question, but one that I can't find a consistent answer to: Do Flats have to be made with the same gain as the Light frames they are correcting? On the usual forums there are several threads on this topic, and in most of them the camps se...
Addresses flat frame settings and calibration; relevant to correcting obstruction artifacts.
Jan 3, 2023
Why Sii frames have this ?
Hi, Why my Sii master frame have this weird black ring and how I can remove it? is it because of light pollution or issues with flat frames? this is total integration of 270x180" I'm using Antlia filters 3nm, the frames were calibrated with ...
Discusses flat frame problems causing artifacts; relevant to author's shadow removal question.
Dec 22, 2022
