Moving from stock DSLR to dedicated astro camera, need some help
21 replies522 views
Paolo avatar
Hello all,
I'm getting ready to move from my stock DSLR to a dedicated astro camera. I'm planning to buy it in a few months, around early summer.
As I've never seen and used such gear (only in online reviews, LOL), I have some questions for you before hitting the buy button.Let's first start with my current equipment:
  • iOptron CEM70
  • TecnoSky AG70 F5 quadruplet APO
  • RPi 4b with Stellarmate OS
  • ASI290mm Mini
  • APM Image Master 50mm f/4.1 guide scope
I like shooting nebulae, but what I really love are galaxies and planetary nebulae. Therefore, I need a long focal length scope, and that's what I'm planning to buy in a year or two. I guess it will be an RC12 or similar.About the imaging location(s):
  • I will image 85% of the time from a Bortle 7 led-enabled zone (SQM 19.10 during new moon, on very good nights)
  • I'm planning to drive occasionally (5-10 times/year) to a Bortle 4 location
  • Very rarely (1-3 times/year) I'll drive to a Bortle 3 location
About questions:
  1. the million dollars question: mono or OSC? I have to say that I'm very intrigued by mono imaging, but I'm also afraid about the additional complexity (e.g. dealing with filters, flats, etc) and higher costs associated with it. And we all know that more complexity means more risks that something can go wrong.
  2. which camera would better fit my current & future equipment? I know about camera-scope matching (e.g. resolution, seeing, pixel scale, etc), but I'd like some opinions from the experts The budget for the camera itself is around, for example, the asi2600mm.
  3. I was looking at the ASI2600MM-Pro and QHY268M. What do you think about them? Would an APS-C sized sensor makes sense for me?
  4. The QHY here in Italy is around 450 Eur/540USD cheaper than the ASI. Why's that? Is the ASI better somehow?
  5. which LRGB and HaS2O3 filters would you suggest, in case I should go mono?
  6. do you think I should buy a "middle scope" between my 350mm quadruplet and the future RC12? Or maybe should I just buy a 0.67x reducer for the RC12?
Thanks a lot!
D. Jung avatar
Same question here.
if you add costs for filter wheel and filters, you can add an extra k$…
SemiPro avatar
Paolo:
Struggled with this recently myself.  I am no means an expert and I implore more experienced members to correct me but:
As far as I know everything else being equal, mono will beat OSC every time in terms of SNR and detail. Mono cameras do not have to fight the bayer grid that OSC's have.  I'll let others go into the more detail in terms of acquisition and processing mono vs OSC since all I do is OSC so instead I will focus on the cost. Let's go head to head; ASI 2600MC vs ASI 2600MM just to give you an idea of the cost difference. I hope you don't mind if I use Canadian dollars because, ya know, I'm Canadian.
First, the 2600 MC and accessories:
ASI 2600 MC: $2,589.99 (You'll need the camera, obviously)
Filter Drawer: $109.99 (Somewhere to swap out filters makes things much easier)
2" Dual Band Filter:  $384.99 (A nice duo band filter for emission and planetary nebula, given your bortle 7 situation)
Light Pollution Filter 2": $269.99 (For those broadband targets in bortle 7)
UV-IR Cut Filter 2": $84.99 (The 2600MC doesn't have a built in UV/IR filter so this is the "base" filter you'd need if you are not using any other)
All in all the cost for this OSC setup is $3,439.95 CDN and outside of the UV/IR filter the other ones are debatable. I just used them for examples.
Now, lets go mono! The most basic setup would be the following
ASI 2600 MM: $3,199.99 (Yeah, you'll still need the camera)
5x2" Electronic Filter Wheel: $389.99 (Gotta put your LRBG filters somewhere!)
2" LRGB Filters: $389.99 (The filters to get a nice colour image)
So, this most basic of mono setups is $3,979.97 CDN, only 500 dollars more right? Well with this set up all you will able to do is color images, not any narrowband palettes such as the much adored Hubble SHO palette. Also, there is no electronic focuser here. With mono, every time you change filters you will have to refocus. In this set up that means you have to physically get out there and refocus the imaging train whenever you change filters. Maybe this is a problem for you, maybe it is not; but it will be very costly in terms of efficient imaging time.
So the first thing we tack on to this set up is an electronic focuser for $259.99. We are now at 4,239.96 CDN. If you want to do narrowband, we have to tack on some 2" SHO filters for $916. This brings the cost up to $5,155.96 CDN. Now, maybe you don't want to be swapping filters out of your filter wheel all the time, so lets trade that 5x2" filter wheel for a 7x2" filter wheel for$ 519.99. The total cost of our mono set up is $5,285.96. That is about two thousand more than the full OSC set up. The cost comparison can change wildly based on the filters you choose. I used the fairly cheap ZWO filters for mono costing, but the higher end ones start to get up there.
The mono set up can also get cheaper if you go with 36mm filters, however with an APS-C framed camera like the ASI 2600 MM, from what I read on the ZWO website, 36mm filters are only good for F ratios 5.5ish and slower or else you will be fighting vignetting which might be bad news for your fast f/5 scope. But just for kicks, with 36mm filters and a 36mm filter wheel it would be like $4,726.96 CDN which is 1300 dollars more than the OSC set up. Again, depending on the filters you go with, the price difference can go up or down.
So is it worth the extra cost and effort? Well that is your call. You have a lot of pictures you can compare here on astrobin. This is entirely subjective on my part, but I think as an astrophotographer's skill increases they have no choice but to move to mono to really push things to the limit. For me, the cost did me in and I am now expecting a 2600 MC since I already have the filters from my ASI 533 MC. But even I know that the more I dive into this hobby, all roads will eventually lead to mono; even mine. Just when I am not a starving university student!
Paolo avatar
Thanks @SemiPro for your feedback, really appreciated
Ah, bad news for me about the 2" filters! I thought I could use the 36mm ones, but apparently that's not the case (at least for my quadruplet)
Hehe, I feel your pain as university student, been there, done that!
I still have to make a detailed cost-comparison with my dealers, better if I start asap. But it will be more or less as you mentioned though.
What worries me the most, is that in the future I may decide to move to mono because I would like to improve even more, and then I'd be back at sqrt(1).
Well, it seems that I've already auto-answered my #1 question: mono will probably be my choice (at least as of today the I tend to have preference for mono). Let's first check the overall costs here in Italy though...
When all is said and done (and there will be a LOT to disagree with) if you want a simpler, easier life go OSC (with LP filters). If you want to squeeze out every single photon out of your kit and don't mind the cost and added headaches go mono+filters. I imaged for over ten years with mono cameras in my Bortle 6/7 skies and then decided to go OSC. I am NOT looking back.  As for the cameras, I am very pleased with ASI. I reckon QHY had issues with software/drivers in the past but I'm not sure it does today. If you can return the camera if not satified go for the cheaper option.
Dave B avatar
I’ll follow this on thread as I have same scope , bear in mind this scope can take full frame sensor obviously you’ll need to find out if this has enough room to fit a filter wheel , maybe techno sky can tell you what it can take , this scope is same as a Meade 5000 , astroaddict on YouTube has same scope I seen a zwo camera on it so maybe he may be able to shed some light on this .
I have a deepskydad autofocus unit fitted to mine too.
dave
dkamen avatar
Hi Paolo,
I think you should use the search function and see what other galaxy people are using, especially those imaging from light polluted areas and generally skies with less-than-observatory grade. My impression is it's mostly focal lengths around 1000mm (maybe 1500mm, maybe 700), apertures between 5 and 10 inches (usually 6 to smile and cameras with sensor size smaller than APS-C. In my opinion there is no way you'll be able to utilise the focal length of the 12 inch RC in city skies (it will probably prove unworkable) and the 2600 is too large a sensor for all but a handful of galaxies.
So you can reduce your camera and scope budget significantly which will give you much better results for what you want to do and leave you with enough extra $$ to go mono, which I highly recommend.
Dimitris
Helpful Insightful Respectful
Björn Arnold avatar
Hi Paolo,
If I had to start all over again, I wouldn’t by optics with focal lengths beyond 1000mm since the current cameras have pixel sizes that will give a better resolution than average and often even good seeing conditions. So, IMHO, don’t invest in a large optics that requires a new mount. From my experience with my iOptron CEM40, I‘d say that you have a great mount. Money can be invested better.
To the actual question: I went for a mono camera although I was pondering if I should go for a OSC and yet, I‘d say that I couldn’t definitely say if my decision was completely right.
What I can confirm however is that a dedicated camera has the large benefit of being more sensitive than a stock DSLR, especially if you buy a camera with back illuminated sensor. Also the increased Halpha sensitivity compared to the stock DSLR is a significant point.
Hence, what is certain IMHO is that you gain quite something by adding a dedicated astro camera to your portfolio.
Why did I go for the mono in the end? Simply it feels wrong to me to shoot narrowband with an OSC. There are people doing it and seem to be happy but it’s somehow not what the inventor had in mind I guess… andI am pretty sure that one day,  e.g. when the moon bothers you enough while you wanted to shoot that nebula tonight, you‘ll put the narrowband filter in (besides all the other good reasons for narrowband).
The learning curve is indeed more difficult with mono. Nevertheless, there‘s apparently already a road behind you, where you mastered a lot of difficulties. You‘ll also master the mono if you do it step by step.
hope that helps a bit!
CS!
Björn
Paolo avatar
@dkamen thanks! good point about using the astrobin advanced search function to gather data and make some stats out of it
@Björn Arnold  that's true about resolution when using, for example, 12" RC. But I could, for example, bin 2x2 right? This way I could resample the data and increase the SNR by ~x2. And also get a nice close up of the galaxy, which I wouldn't have at, for example, 1000mm. Or am I missing something here?
There indeed is a road behind me i had lots of fun with my SkyGuider Pro, and pushing that little beast to the max has taught me quite some stuff!
I'm not really afraid of mono per se, I'm afraid about myself being too lazy sometimes and mono requires more effort than OSC, but it also gives so much flexibility...
BTW, thank you all guys for your feedback(s)!
dkamen avatar
A 12 inch RC is the size of a small couch and weighs maybe 25kg. It is not very portable or easy to collimate (I am not talking about the geometric aspect of collimation, I am talking about handling it as a large heavy object). It is meant for a permanent installation, spend a lot of effort to set it up and then just leave it operational for years.
Yes, theoretically if you bin 2x2 it will be pretty much the same as a 6 inch RC which you can carry in one hand but this seems like taking an awful large detour to reach the same spot. If you had an observatory up a mountain where the 2.3m FL can be put to good use (and I think there are providers that rent such space), that would be a different story.
As it happens, you are limited by seeing and light pollution so the image from the larger scope will have to be scaled down and end up just like what the smaller scope would deliver (sane SNR and same detail), at the cost of extra weight, reduced portability and of course actual monetary cost smile. No extra detail, only extra trouble…
It is pretty much the same with the camera, except you are underutilising sensor area (hence wasting storage, tranfer time and processing time).
cheers,
Dimitris
Helpful Insightful
Lynn K avatar
I disagree with some of the comments regarding mono vs, OSC.  As for a ease of use, once all is set up it does not take long to click on a few buttons an set up the imaging sequence for the night.  There  will be  more work in stacking/calibrating each channel. The cost will be more and some filters such as Astrodon are expensive. BUT, because you live in an light polluted area, you will find the mono image easier to post process. That will be due to being able to take advantage of narrow band filters.
I live in a bortle 6/7 skies and I personally think OSC is very limited to short exposures and bright objects.  For me galaxies or out,  except the very brightest.  Planetary nebula can be bright and done only using Red/Green/Blue filters.  Since the detail is small, one needs all the resolution you can get.  I would do a search on a few planetary nebula and see what equipment is being used for the best results.
Flats will be necessary with both mono & OSC under bortle 7 skies.  You might get away with out them using narrow band.  The lighter the background, the more necessary flats are.
One thing I have learned, your sky is the last determining factor.  You will not be able to achieve more detail that the seeing will allow.   Consider that when you determine your camera/scope arc/sec per pixel ratio.  Also, LRGB will not go deeper or brighter that the sky glow will allow.  You will need narrow band filters to do that.  I have no experience with the new Tri-Narrow Band filter for OSC.  But they will not work on galaxies, because it will be filtering out most of the galaxy star light.
Invest in the mount.
I'm a Sony CCD imager and have no experience with the CMOS cameras. However, I see very impressive results with them.
I will end with this comment.  I have been imaging under light polluted skies for 15 years and have concluded that mono narrow band imaging is the only way one can achieve good to very good images.  Also, one is limited to mainly nebula.  If I want galaxies, I have to travel 5 hours.  I prefer fast refractors such as the Tak FSQ106ED at F3.64.  But other less expensive brands have shown great results. When I have done planetary nebula I use a C9.25 or C11 at F10 using RGB binned 2x2.  But I must confess my result have been limited.
Lynn
Michael Caligiuri avatar
Valuable information in the earlier replies.  This is a topic that can easily overwhelm as astroimaging is multidimensional, which is what I love most about it.  it's always changing.  There is no single optimal set-up that is ideal for the wide range of  DSOs and sky conditions.
But I do have a few comments from lessons learned from over 20 years of imaging:
1. Consider whatever you decide to purchase within the next 6 months to be a "starter set" for learning the craft.  Changes are good that you'll be upgrading within 2 years and the direction this upgrade takes will be based on what you have learned.
2.  Don't forget the CPU demands.  As camera resolution increases along with larger pixel sizes, file sizes become astronomical.  On a given night of imaging you can easily collect 20-30 subexposures and perhaps 2-3 GB over a weekend.  The ASI2600 camera (26 Mp) produces 52MB file sizes; for the the ASI6200 (62 Mp), each file is 128MB . You see where this is going. Calibrating and combining this many large file subexposures requires a hefty computer with a lot of RAM.  File management is not trivial.
3. And yes, as others have suggested, go with a mono camera and filters.  Under urban skies Ha imaging is extremely rewarding.  can't do this with a color camera.  No reason to pay a lot at this stage, 1.25" narrowband and LRGB filters are more than sufficient.
4.  Pay close attention to image scale.  Just match the focal length of the OTA to the pixel size for DSOs and you'll be happy.  Also, consider your local seeing conditions.  For example, if you cannot get better than 2" seeing where you are, there's no point in using a scope/camera that yields a 1" image scale.  I always try to match my camera + OTA pairing to my seeing conditions.
5.  Buy used and don't spend a lot of cash. Then sell it for close to what you paid after a few years and leverage the cash and all your acquired knowledge toward an upgraded camera.
-Mike
Helpful Insightful Engaging
Paolo avatar
haaa…I'm starting to finally understand all this binning thing. Basically, taking into consideration the sony imx571 sensor and a 2032mm tube (e.g. 10" RC) vs a 1200mm tube (apo/newton) :
6248x4176 px, 3.76 um
    -> 2032mm, bin 2x2, no crop: 0.76 "/pixel
        -> 3124x2088 image size
    -> 1200mm, bin 1x1, 50% crop: 0.65 "/pixel
So yep, it seems that a big RC might not be a good idea after all smile
BTW, I have no idea how to measure my seeing. I usually just look at how much stars are twinkling, but that's all! Is there a way to get a number?
Brian Boyle avatar
I was in exactly the same position as you six months ago.
 I went the OSC (ASI2400MM) route, and it was great.   However, I am now moving onto a mono camera (ASI1600MM + 7position filter wheel).   LRG/NB imaging isn't really any harder to learn than OSC processing, since most of the post-processing steps are common to both.  And I am loving the greater creativity and artististry putting together colours gives me.
I live under Bortle 3, but had I lived under Bortle 7 I think would have gone mono (for NB imaging) straight away.   Yes its more expensive, but in terms of $$/SNR then I think mono/NB wins hands down in light-polluted skies.
Whatever you chose you will have a great time!
Helpful Insightful Respectful Concise Engaging Supportive
Paolo avatar
I'm more and more convinced by the mono route.
Now I only have to decide which camera (or, better, which sensor)
About mono, I was thinking I could buy these filters:
  • LRGB => Baader planetarium parafocal
  • H-alpha => Antlia PRO 3nm
  • SII, OIII => Chroma
This way I can buy this year LRGB+Ha, and next year SII and OIII.
What's your take on those filters?
On the filter question, again consider your conditions,  3nm NB filters might be too strong for Bortle 6-7 skies, cutting out too much emission.  I would go with 5nm or 6nm to bring in more data.  Also, consider keeping all filters within the same manufacturer - they are more likely to be parfocal.  Chroma will be expensive.  I have 2 cameras: one uses Astrodon 2" (for travel to dark skies) and the other Astronomik 1.25" (for suburban backyard imaging).  Both sets work beautifully while the Astronomiks were a fraction of the cost for Astrodons.  Filters are reasonably parfocal within each camera.
If I were in your position, I would consider an imaging system I used a few years ago; ASI1600mmPro + 7=pos filter wheel + OAG.  Readily available on the used market.  If you like the small pixels (ideal for short focal length OTAs) , this is a sweet low-cost system.
-Mike
D. Jung avatar
When you get the 1600, don't forget that you are buying yourself some nice micro lensing artifacts.
Paolo avatar
@Michael Caligiuri ah thanks! I didn't know that there was a "better band" depending on the Bortle scale. I have to investigate more before doing anything
@D. Jung nah, I will not buy such old camera! I prefer to start with the latest and greatest! Currently, I'm thinking about ASI 294/2600 MM and the QHY counterparts. I have a small preference (based just on feelings) on they QHY268M, but I'm still not sure about those 3.76um pixels.
D. Jung avatar
@Michael Caligiuri  not sure I understand your argument here why you would want to use wider filters for more light polluted skies. Intuitively I would go even narrower to get better snr by removing more unwanted light pollution.
Paolo:
Completely understand.  However,  the prudent decision to select a dedicated astro-camera should consider other factors such as cost, computer support, sky conditions, and where one is along the learning curve.   There's also the possibility that the hobby may grow stale within a few years or life circumstances will change.  I'd rather be swimming in the shallow end than the deep end if or when this happens.
Well Written Insightful Respectful
D. Jung:
The argument is based on integration time not so much light pollution (my bad).  Assuming shorter subs and less overall integration time from typical backyard/urban suburban conditions the wider bandwidth filter lets more light (i.e. nebulosity) in than a 3nm filter would for the same integration time.  Also, the wider bandwidth permits easier framing with shorter exposure times.  Just based on experience.
Lynn K avatar
My experience is that narrow band will let in equal light at a particular wave length as a luminance.  The luminance will certainly be lighter for both stars and DSO, but at a light polluted site, most of that is UN-Wanted light.  One must remember narrow band filters or NOT light enhancers. They are filters that filter out unwanted light.
Some thoughts about filter brands and band widths.  Ha is at 656.3 and NII is at 658.4  A 5 -6nm Ha filter will pick up some NII, which some imager see as desirable.  A 3 nm will be centered from 655.3 to 657.3, and will filter out the NII.  So, a image using a 3nm may look dimer due to that.  Don Goldman of Astrodon claims his filter or centered on the  correct nm.  Some cheaper filter may vary from 3nm to 4nm and may not be well centered.  A cheap 3nm filter may be off from 656nm to 660.  You may be getting more NII that Ha, or the other way.   It is probably saver to go with wider band width with cheaper filters.  This is one of the cost factor of Astrodons.
I do not think the amount of light overwhelms narrow band filters.  So, I don't think light pollution has any affect on the ability of a narrow band filter to filter out out-lying band widths.  The narrower the band width, the darker the background.  And to be redundant, it's all about contrast or signal/noise.
If you look at filter choices on this site, you will see a number of imagers using 5nm Ha and 3nm OIII.  I do this also.  The reasoning is that  even a 5 to 6 nm Ha is effective at filtering out light pollution and moonlight.  On most emission nebula the Ha is fairly strong and renders good S/N.  It also captures NII.  However this is not true of OIII.  OIII 5nm can let in moonlight.  OIII is usually dem and renders poor S/N.  I have found a big improvement in my OIII S/N sense using the 3nm.  That is NOT due to more OIII but a darker background.
Another issue with narrow band filters in reflection off the filter and sensor window glass.  Cheaper filter of more prong to this problem. The problem increases as you decrease the focal ratio.  I other words, it more an issue with F5 that F7.  It is a large problem with F3 and Hyperstar F2.  I have had issue with Astronomics 12nm at Hyperstar F2 but little at F5.6 to F7.  The Astrodons have eliminated it at F3.64 wik a Tak FSQ106.
Most filters claim to be Par-Focal.  They work well at longer focal length, but even the Astrodon OIII has the refocused at F3.6.  When I did momo filtered Hyperstar imaging, every filter had to be refocused and the Hyperstar had to be recalibrated even though the time was only 30 min in between with little summer temp change.
Having said all that, I still thing mono is the way to go.  And in a light polluted area, it may be the only way to go.
If you want traditional LRGB you have it or you can go RGB.  You can also go with Bi-filtered with Ha +OIII + Synthetic green and get similar looking traditionally looking images.  Or you can do the Hubble palette. Or all the above on the same object from the same session.
Consider the cost of filters when choosing a Camera.  Large chips require large filters and the price jumps a lot.  Not to mention a larger filter wheel.  I recently acquired a used Starlight Xpress SX46 at 1/2 price (21.8 x 27.2 size chip)  I need the filters to work at F3 with a Officina Stellare Veloce RH200 ( also good used price).  Astrodons and Chroma filter are the only filter that will work with a F3 cone.
I will need 50mm.  The new filters will cost more than the scope or camera.
Lynn
Narrow band with full spectrum DSLR
Hello all My question is this. Can you do narrowband imaging with a full spectrum Canon T3i. Is it better than a un modded DSLR ? I’m thinking being my camera sees the entire light spectrum narrowband should come out pretty good. Another question is ...
Discusses dedicated astro cameras versus stock DSLRs for astrophotography imaging.
Oct 3, 2019
Where should I go equipment-wise now?
I have stuck with what my wife bought me as a 59th birthday (a few years ago) present so far: An 8" Newtonian on an HEQ5 Pro mount. I've added cooled mono camera (ASI1600MM Pro), filter wheel, OAG guiding, coma corrector, autofocusser (ZWO E...
Seeking equipment upgrade advice similar to your camera transition planning.
Jul 31, 2022
First tip: Buy Narrowband filters and go mono
Hi folks, I should make the first post myself of course. My "backyard" balcony is in Utrecht, the Netherlands. In terms of light pollution: a red zone, bortle class 8. After four years of DSLR photography, I made the switch to mono and was ...
Transitioning from DSLR to dedicated astro camera; author's mono switch experience relevant.
Oct 10, 2019
Advice Needed - To jump or not?
I've been doing astrophotography for a number of years. I started with OSC and then switched of Mono. I'm under Bortle 4 skies using a 120mm refractor. I doubt that I'll ever be good at processing but I seem to get reasonably good data. I...
Discusses OSC to mono camera switch, directly relevant to your decision.
Feb 26, 2023
Advice me for next equipment plan
I want to plan wisely for a serious next purchase so i don't regret and i can calm down and stop buying more for a while, so i am not sure how it should be if it was you. Let's assume you have about $5000 maximum, which one of the following p...
Planning next equipment purchase wisely, matches your pre-purchase research phase.
Mar 20, 2023
