currently in the process of collecting data on M101 and it has not been without issues! Dealing with learning how to focus my new GT81 and weather its been challenging to add hours on this galaxy!
I had setup last saturday but i think my focus was slightly off so i'm forgetting those and starting over. setup last night but only got about 1.75 hrs before i pulled the plug due to wind and clouds. this image is from last night. at least i know this setup will handle 24mph wind gusts! but i had to throw out several subs due to clouds.
I'm wondering if this image looks focused properly, stars etc.? I'm using the built in bahtinov mask to focus by along with BYE. I've read that with BYE to use the least FWHM value as the point of critical focus. but doing that still seemed the center diffraction spike was a bit off. so i had to take pics and look at them in PS to figure out which way to turn the focuser to get it centered. took some trial and error but i got it to where it looked centered. at least i hope it looks focused!
Also, do the stars look too hot, or blown out or bloated? I used a mask in PS to bring the values down a bit a that reduced the size some. still think they could be a bit smaller but not sure if reducing the highlights is the right way to go. still new to astro processing! Thanks!
mount: cgx, unguided
scope: WO Gt81 with 0.8 field flattener
cam: canon 6d unmoded, no filters
exposure: bulb, iso 800 80s
Lights: 61/79 subs
Darks: none
Flats: none
initial processing in APP
touch up and noise reduction in PS
heavy crop from the full frame
Lights: 61/79 subs
Darks: none
Flats: none
