Greetings Community,
I just ran my new ASIAir for the first time two nights ago. No problems. Last night I went out again, but this time–aside from the constant connectivity problems–my auto run of 90 subs worked fine for the first 11 subs. From subs 12-43 an empty file (0 k) was created. No file was created for subs 44-90 (I don't even know if the subs were taken). I only discovered all this when I checked the thumb drive this morning. No log files were created for the Auto Run last night at all, not even for the files that were correctly written. It is almost as if there were a thumb drive failure…but I don't know for sure.
This leaves me with a few questions:
(1) Once the Auto Run has started, is there any reason (other than to check progress), to continue using the iPad or iPhone? In other words, is a connection between the AAP and other device necessary? Could a lack of connectivity cause this issue?
(2) If not, what could cause this issue where files aren't saved and written to the drive? Advice on how to proceed would be most appreciated!
Thanks for any help you can give and CS to you all!
Daniel
Daniel
