New wide field rig - vixen fl55 vs. Sharpstar 13028/ts hypergraph 13028
7 replies624 views
New Wide field setup for nebulae season W/ mono camera
Multiple choice poll 19 votes
16% (3 votes)
84% (16 votes)
Leonardo Landi avatar
Hi guys. I'm thinking about putting together a new widefield setup for the upcoming summer season. I focused on two instruments: Vixen 55 fl and Sharpstar 13028/TS hypergraph 130. The first is a refractor with a fluorite doublet with a focal length (with flattener/reducer) of 236 mm f 4.3. The second is a Newton f 2.8 astrograph with a focal length of 360 mm. The instrument will initially work with my current Asi 1600mm and 31mm Antlia filters, but in the future I plan to move to the 2600mm. In the case of the Vixen 55 I would have a wider field and greater ease of use at the expense of speed. In the case of the reflector I would have a focal ratio practically twice as fast at the expense of the FOV and simplicity. However, I really like my current Skywatcher 200/800 f4 and couldn't help but consider buying another newton. The setup would work mainly in a little ROR shed, under a bortle 6 sky. Since I have two very young children, the idea of ​​traveling astrophotography is out of the question for now. If anyone has any good advice or considerations that I missed, I would be more than welcome.
Brian Puhl avatar
My vote between the two was for the Hypergraph… aka the Sharpstar HNT130, purely because (even though it's noted to have issues), it will still be better than a doublet.
The Hypergraph/HNT caught my attention when it was first released.  There's alot of great photos produced by it, but I've also been reading alot of folks having issues keeping it collimated.  F/2.8 optics are not forgiving.   I tried running an F/3 newt at one point and kinda gave up.    Looking back I probably could have collected some patience and got it working, but it wasn't for me.   I like the turnkey, no frills ready to go aspect of my triplets.
Doublets in general are frowned upon for astrophotography.
Mike Hamende avatar
I have the HNT 13028, it's a nice little scope.  It is a little tricky to collimate but when it is service I keep it in an observatory so I don't have to worry about collimation shifting.
Collimating the primary with the included cheshire can be difficult because the corrector is not removed and my eyes have a hard time focusing through it.  My method now is to align the secondary with a laser, get a rough alignment of the primary, then mount the camera and fine tune the primary with a bahtinov mask.  I made a zone mask for the bahtinov so you can work on one collimation screw at a time.  Like this.
I'm a proudly owner of a FL55ss but I don't use the focal reducer. I use it in his native focal leght and I must say: The craftsman quality is the best that I saw so far which only can be matched by the Takahashi. I must say: Despite been a doublet (as most of the old school Takahashis are), that natural crystal flourite lenses are the best that humans made so far on the planet.
Observatório Astrográfico do Boqueirão:
I very much doubt that transparent "natural" CaF2 can be found in sizes large enough even for a 55mm lens in nature. Never mind the other requirements.
Thank you all for the replies. I have owned several refractors in the past, and they are undoubtedly easier to use than a fast newton. @Mike Hamende  how often do you have to recollimate? I practiced with my Newton f4 and the Ocal collimator. The 130 f2.8 will certainly be more demanding, but I hope it is compensated by the better mechanical quality. My skywatcher four was a nightmare at first, I solved it with the new spider and the Esatto focuser from Primalucelab
David Elmore avatar
Yes, you have narrowed your search to the two scopes mentioned, but consider the Borg55FL F/3.6 Petzval refractor.  No spikes.  With blurXTerminator it will nicely handle a full frame sensor.
Well Written Concise
Mike Hamende avatar
Leonardo Landi:
I collimate once when I set the scope up in the observatory and I don't need to touch it after that unless I take it off the mount.
