LED street lights and Light Pollution Filters
Light Polluted skies 15 replies503 views
Götz Golla avatar
Due to some recent european regulations cities in Europe are obliged to sooner or later convert there streetlights to energy-efficient LED lights. This happend in our village two years ago. Unfortunatelly, the emission spectrum of a white LED light is completelly different from the conventional high or low pressure sodium or mercury lights. For example, there is a pronounced peak at about 460nm.  So, at least theoretically, most astronomical light pollution filters should no longer have any effect with LED street lights.
I wonder if anyone in this group has experience (good or bad) with a light pollution filter in a region where LED streetlights are predominant ?
DustSpeakers avatar
Only bad. Our streetlights were changed to LED lights about 2 years ago and the broad spectrum from these lights is impossible to filter out. I complained to the local council since one of these abominations was right opposite my bedroom window and the 'whiteness' was affecting my sleep and they fitted some kind of a shade to supposedly allow the light to only occur in the downward direction. They also agreed to turn the offending light off between 11pm and 5 am, but not any other street lights further afield. I have noticed that other lights in the area have acquired 'shades' so I'm not the only one being affected.
Niels V. Christensen avatar
Right, also my obs surroundings has changed to LED street lamps & light glow from CPH, DK => not at all good for DSLRs/OSC cams & LPS filters combinations.
For nebulas that contain a lot of Ha/OIII info, the only way forward is to "upgrade" to these kind of filters, one example here,
https://www.teleskop-express.de/shop/product_info.php/info/p12253_Optolong-2--L-eXtreme-Narrow-Band-Nebula-Filter-DSLR-and-Color-Astro-Cameras.html
Even better & much more expensive, to use this filter,
https://optcorp.com/products/radian-telescopes-2-inch-triad-ultra-filter
Tareq Abdulla avatar
Mono + NB filters [5nm or 3nm]
Tom Gray avatar
I’m currently using the new Baader UHC - L Ultra L- booster which is supposed to remove blue light pollution - the most common form in LED street lighting. It is a ‘broad’ NB filter with normal star colours and not too much halo around brighter stars. It gives emissions a nice lift.
Alexandre Salvador avatar
My municipality has adhered to LED street lights. Of course, they took the chance to the increase the Lux output.
One day they were doing maintenance on the lamp opposite to my flat, and I approached the team, if they could do something about reducing the strong lights in my street, and also the lamp that shone directly into my bedroom. They almost laughed. They said they'd never had anyone complain about "too much light".Apparently, it just gives more votes, to try to turn the night into day.
Before they went, the team leader instructed the guy up there to make the lamp point as far downward as it would go, and more away from my window. Truth be told. smile
Pirate Mike avatar
Happy message of the day… smile
It won't be long, in the scheme of things, before there is no night on earth… just a brightly lit "LED Blue" hell.
Read noise Astrophotography avatar
As far as I remember the spectrum is too broad
It’s not an improvement for astrophotography as others have pointed out. The best you can do is to work in narrowband or in the near IR as much as possible. One thing I have noticed is that the overall lighting levels you see in the US are much higher then I was seeing in Italy for the last few weeks. Most of the lamps are not as high up and the overall wattage seems lower. Just enough lighting to get the job done.
BlackStarsAstro avatar
l.e.d. lights also effect electronics in close proximity. I switched to led in my garage/shop and my transmitters stopped working until I removed them. Not sure if this effect extends to a larger scale.
BlackStarsAstro · Dec 6, 2025, 03:36 PM
What do you mean?
SonnyE avatar
Hi Tareq,
Seems we cannot change “Progress”. In my little corner of the world, they put up LED streetlights, but they are directed (Shielded?) to only light the street and a little spill onto the sidewalks. So, not too bad. The old HPS fixtures were horrible and just generally shined everywhere.
Behind me and across a drainage channel is a condominium complex. They changed their outside area lighting to LED bulbs. So, their light pollution went way up. On our back wall (concrete block) I put up a fence topper so effectively I have an 8-foot fence.
My previous neighbors moved away and we got a couple who seemed to delight in being female dogs with their backyard lighting. I asked them to turn off their lighting when they weren’t using their backyard. That only served for them to be even more obnoxious. I told him I would put a wall topper on my wall. And in two days the same company was able to do it.
So, at first, we felt like we were living in a Bin Lauden compound, our backyard surrounded with 8 high fence all around. His wife had a hissy-fit when the guys were putting the topper on their side. They are horrible neighbors.
But it serves to block much of the direct idiot light pollution. For the rest, I have an Antlia Quad LP filter, and a newer Svbony SV220 light pollution filter I can use in a filter drawer on my telescope. I like it because I can experiment shooting with one, then the other, like I did last night. (Still stacking, so sorry no examples as yet.
I used to use filter wheels and shoot 7 different filters. But now I’ve just resigned myself to an ASI2600MC Pro camera, and LP filters. I’m really happy with my simple, fast imaging results.
Anyway, you can compare these two filters and see if they might help you where you are. They help me, although the SV220 seems to be quite red for me.
📷 Horsehead and Flame Nebulas w/ SV220 LP filterHorsehead and Flame Nebulas
https://app.astrobin.com/i/pytjxh/
Hi Sonny,
Thank you very much for your post, nice to read about what you are facing and i understand.
I live in a city, but i can’t describe about my area is it an urban or town or suburb or what exactly, in the past we had those yellow lights which were so noisy and spread everywhere, then they changed it into LED, the lights in my street is almost shielded as well but not fully, it is not lighting the whole sky or a lot, but it is lighting my yard because the lights are in front of my house towards North direction, so Polaris and around are affected, but all around are ok, my house is covering the South direction, and by East or West the neighbors houses without much of light, so i know i can get signal but not that great, and zenith is nice, but i stopped doing imaging since they placed and operated LED lights 5 years ago.
I keep thinking about that Antlia Quad LP filter for my OSC camera, while for dual band i already have L-Ultimate but still didn’t test it since i stopped, for me narrowbanding isn’t a problem, only broadbanding, i need to do imaging to see how bad it is nowadays, i might have good conditions really, but i really gave up mainly because of gear rather than LP, but i am preparing my new gear to be back and test, i have different plans but i also do planetary and solar, DSO is a bit headache, once i am ready i will do DSO hopefully as it should be despite the light pollution.
SonnyE avatar
Tareq Abdulla · Dec 6, 2025, 08:13 PM
Hi Sonny,
Hi Tareq,
When I first purchased my ASI2600MC Pro I tried it without any filters. Then decided to get the Quad filter. My first ever multi-band filter.
I got the usual panic by others about the IR cut filtering, but honestly, I don’t see any detriment to my images with the Quad filter.
My SV220 2” LP filter is fairly new to me. So, I’m still experiencing what it can do. But I like it. And I like having the option of trying them with a simple filter drawer change.
At this point Light Pollution is about all that bothers me in my imaging. I can’t do much about the Moon, which is being obnoxious right now. Except aim Northeastward tracking to Northwestward. 😒
But for me, the LP filters fit quite well for my LP woes. I use 2” because my camera has an APS-C sized sensor. So, I err towards a bigger filter with a bigger “sweet spot”.
Back when I was thinking about trying Astrophotography, I looked at the different disciplines and decided I wanted DSO and Nebula specifically. I’ve never changed, although I have used my equipment for occasional clusters, blood moon, and on very rare excursions some Planetary. (We got the biggest reactions the first summer when I stacked two Barlows and everything I had into the eyepiece holder to fill that 80mm Triplet telescope with Saturn.) First time any of us saw the planet and the rings. But the telescope looked hilarious with all that stuff hanging out of the eyepiece holder.
Over the years I’ve played with this so much has changed and improved. After 11 years with my ED80T CF, I finally stepped into my AT 130mm EDT. Brought everything closer.
I have no idea if any LP filtering works for visual, or if it would be terrible. I started out for AP and here I am still deeply engrossed in my quest.
Leonardo Ruiz avatar
Light-pollution filters worked well with sodium and mercury lighting because those older lamps emitted in narrow, well-defined spectral lines. Filters were designed to block those specific sodium and mercury emission bands while allowing the rest of the visible light through. LEDs, however, emit white light with a continuous spectrum, just like stars and the Moon. This is why you cannot filter out LED light without also filtering the astronomical signal. Only very narrowband filters for Hα, OIII, or SII can block most of the visible light while still letting those emission lines pass.”
If your sky is heavily light-polluted, Bortle 8 or 9, you will get the best results with ultra-narrow filters between 2.5 and 3 nm. For RGB imaging, you’ll need to focus on very bright targets, capture them when they are near the zenith, take many short exposures, and apply careful processing.
Well written Helpful Insightful Concise Supportive
Leonardo Ruiz · Dec 7, 2025, 05:02 AM
I shoot in B8 and that sums it up very well.
