A silk purse from a sows ear? A PI and BlurXt 'fix' for poor colour as well as star shape using an old refractor
3 replies456 views
Tim Hawkes avatar
I am the owner of an old F7.0 WO 110 mm 'apo' triplet.  It is a great scope for visual - and I am fond of it -- but when taken down to F 5.5 using a FLAT III6A 0.8X reducer/ flattener it doesn't yield an entirely flat field for astrophotography.  Not bad but no cigar.  There is still some recalcitrant coma around the field edges -  that I can't remove by varying flattener spacing to the sensor - and also some slight astigmatism.  When you pixel peep it is clear that these diffraction differences create 'rainbow' effects that are evident in the colours of larger stars nearer the edge of the field.
Rather than just replace the WO scope I have been interested to see how far software only solutions can improve things to a level that I am happy with.
It will be no news to anyone that BlurXt AI version4  does an excellent  job of sorting star shape -- as well as providing some interesting options for tweaking star and halo size which can help with colour.
What I did find however was that while applying the Blur Xt correction to the luminance the shape is improved but the irritating colour aberrations still remain.
Here is a fix - using PixInsight and Blur Xt - that worked very well for me  (could well be well known to experts already but I thought to post it up in case useful)
My particular example here was from 133 x 20s exposures using an ASI 294MC camera observing a field of sky around M38.  1.55 arc sec/ pixel dithered.
Processing steps were ..
1) 2X drizzle integration
2) ABE background removal
3) SPCC colour correction
4) Channel extraction  into R, G and B followed by BlurXt correction only of the three channels
5) Then use 'star alignment'  to register the Blue and Red channels to the green  (I used max distortion 0.7 and always for PSF fits)
6) Then equally combine the three re-aligned channels into a single RGB image again using Pixmath
7) Then optionally apply star reduction, noise reduction et etc
The star alignment seemed to do a good job of aligning the three corrected colour channels and at least - in my set up and for this starry subject -  the improvement was really quite dramatic,  Picture below is of a highly blown up part of the field  showing a distorted star very close to the edge of the field.  The first image is as uncorrected, the second after applying BlurXt correction to the luminance and the final picture after carrying out processing as above.
The final wider field looked good enough  - for me anyway - to be happy with the current setup and not hanker after more expense and kit (yet)  :-). Tim
Oscar H. avatar
Hope you don't mind. I just thought I might make the colors look a little better.
(possibly irrelevant) note:
There is no way a person could mistake a pig's ear for a silk purse
Mike Hamende avatar
Very cool! I'll have to try this with my Edge+Reducer.
Tim Hawkes avatar
:-)  Indeed not.  The phrase comes from an old Scottish proverb as in "you can't make a silk purse from a pig's ear"
Looking for a small (60-110 mm) refractor to piggyback on a C11" for Imaging
I currently have a Stellarvue 80mm apo triplet (old version) piggybacked on a C11" EdgeHD to image from my observatory. I am not pleased with its performance, so I am looking for a new scope to replace it and pair it with my ASI2600mm. Weight is...
Old triplet apo performance issues; author replacing underperforming triplet apo.
Aug 10, 2022
[RCC] NGC 7000
I created two versions of this image, one with fewer stars than the other and have otherwise been struggling with narrowband. I got this data from Telescope live and thought it should be a good test of basics so I thought id give it a go and ask you ...
Narrowband imaging techniques may address field flatness issues in astrophotography.
May 27, 2025
Mysterious star trailing solved: a cautionary tale of fan vibration with a fan cooled (especially ZWO) camera.
Suddenly after no problems with star shapes, the next night out they were just terrible! Below I show a gif comparing two 2 hr stacks, one with the good stars, and the next with elongated stars. In this example the distortion was vertical. But later ...
Optical aberrations like coma can cause star trailing and distortion problems.
Nov 18, 2025
Help processing my data - specifically star colors
Hi everyone, I am processing my first broadband target m81 and m82 which I shot in the last couple of months and I am looking for help to process my star colors. My initial 120s bin2 LRGB subs appeared too saturated and I again imaged a set of 60s bi...
Discusses star color correction and processing techniques for improving star appearance.
Jun 26, 2022
Dark halos around stars - what are your best techniques to remove them?
Alrighty team - An image popped up recently that was very well done, but - there were dark halos visible around the stars, which was a distraction. This led me to ponder…hmmm - what's the best way to remove these? Specifically, we're ta...
Addresses star shape issues and color correction techniques using processing software.
Jun 11, 2022
