Graxpert failing to open after update
9 replies900 views
DavesView avatar
Upon opening PI this morning, I received an update notification for Utilities. I let it update and now Graxpert doesn't work. The following error pops up:
run --execute-mode=auto "C:/Program Files/PixInsight/src/scripts/Toolbox/Graxpert.js" Processing script file: C:/Program Files/PixInsight/src/scripts/Toolbox/Graxpert.js*** Error: Signature verification failed for 'GraXpert': Invalid code signature: C:/Program Files/PixInsight/src/scripts/Toolbox/Graxpert.js
Jure Menart avatar
DavesView:
*Hi David,
I had the same problem. Temporary you can go to:
and rename Graxpert.xsgn file to something else (i am not behind computer but I think this is the filename, its only another Graxpert.* file besides .js). This will disable verification and allow you to use GraXpert.
DavesView avatar
That fixed it! Thanks!
Gaillard Jérôme avatar
Hello.
I had the same problem but I have found the solution with the help of my friend Régis also in Astrobin.
in fact, there’s a new version of the software on the Pixinsight website since January 19.
You just have to delete your old version and to download and reinstall the new one.
After, there is no problem and you can use easily expert and all the scripts of the toolbox.
I hope that will help you.
Sorry for my poor English.
Jérôme Gaillard
France
Helpful Respectful Supportive
DavesView avatar
A moderator moved this to Graxpert forum from PixInsight forum. The software was PI. The notification to update and the update was PI. Graxpert is called from PI. Graxpert worked... PI didn't. The fix was in PI. Not complaining, but rather explaining the error of my ways. lol
Jerry Gipson avatar
Reinstalling the latest version of PixInsight fixes the problem, too.
Well written
Nikolay Bochev avatar
Jure Menart:
DavesView:
*Hi David,
*** very helpful thank you very much***
abdullah alharbi avatar
Jure Menart:
DavesView:
*Hi David,
.js). This will disable verification and allow you to use GraXpert.i
I tried  to change the name, but it disappeared from the toolbox in Pixin. Can you please give an example of your rename?
DavesView avatar
abdullah alharbi:
I have since upgraded PI. Apparently what I renamed it to has been changed back to the original name, and I can't remember what it was that I changed it to. Perhaps Jure can enlighten you. Might be best to just upgrade PI.
DavesView:
abdullah alharbi:
it seems like I was changing Js not the other one that's why it disappeared, it works fine now, thank you 🙏
