Star issues with Borg 55fl
1 reply77 views
Seth avatar
All,
I recently purchased a Borg 55fl and am
having star issues.  I recognize that this scope is particularly sensitive to back focus and have incrementally increased and decreased back focus by  .1 increments from the 60.6 required but still cannot get round stars.  I am starting to think that backfocus is not the issue and that there is another problem (coma???).  I have attached a photo taken last night that illustrates the problem.  Any suggestions would be greatly appreciated
Well written Engaging
Torsten Daiber avatar
which version exactly do you have? What camera/weight did you use?
Torsten
Tilt with Skywatcher 200PDS
The 200PDS has a focusser tube, with an adapter ring at the camera end that is larger in diameter than the rest of the tube. This is also true of the compression ring replacement I have bought which also has 2 screws 120 degrees apart to secure the c...
Tilt issues can cause star distortion similar to coma; relevant diagnostic.
Aug 16, 2022
Fixing the dreaded tilt and backspacing error in optical systems with objective analysis.
Fixing the dreaded tilt and backspacing error in optical systems with objective analysis. The curse and blessing of modern CMOS cameras is that amateur astro-imagers have easy and relatively affordable access to extremely high resolution detectors bu...
Directly addresses tilt and backspacing errors affecting star quality.
Jul 29, 2022
Oblong stars with good guiding.
I am using EQR-6 mount with Williams gt81 and asi533 with asi290mm camera with 50mm guidescope. My guiding is very good, I am under .4" for 5-10 minute frames. My stars are a bit oblong streaking to the upper left. Uniform thru-out frame so not ...
Discusses oblong/distorted stars; similar optical problem diagnosis.
May 4, 2022
