Full frame sensors with Hyperstar
HyperStar Lens Astrophotography 2 replies250 views
Matt Stahl avatar
Is anyone using an unmodified full frame DSLR with Hyperstar and C9.25 Edge? An APS-C sensor would be perfect since the image circle is 28mm; but what if you also image at f/7 and f/10 and don't have the luxury of having more than one camera? A FF frame camera covers the 44mm image circle at those ratios, with good stars to the edge (with the Edge :-) ), even if it's wasted with the Hyperstar.
How 'bout Hyperstar LRGB with a FF mono astro cam?
Rick Veregin avatar
Hi MattI have been using a Canon 6D full frame DLSR as well as a Canon t3i APC DSLR with a 9.25 and Hyperstar.  Both my cameras are modified to get more Ha. My 9.25 is not an Edge, but that should not matter, the same Hyperstar works for both (for the 9.25 only), and the extra optics in the Edge are not in the Hyperstar light path. The imaging circle of my version of Hyperstar is about 25 mm, so covers APC, but vignettes the corners on the full frame.  I would say that stars are quite good out to APC size plus a little more (on my 6D), as long as you collimate the Hyperstar well (same problem whatever camera you use). I do find the mirror box in the DSLR really intrudes into the light path at f/2, so it is extremely difficult to use the edges of the frame, very difficult to make flats that can compensate. Also, with a DSLR you will get odd diffraction effects off of every edge, so you need to make a smooth oval shade to hide the DSLR, which cuts into the light path a lot in front of the corrector. But absolute must do otherwise stars will have all sort of weird shaped spikes. This shade also causes problems with flats, but with some work it is possible to get decent flats, aside from the edges of the image.You can look at some of my examples on Astrobin @rveregin .  I have  m31 and the Cocoon Nebula with my full-frame 6D, as well as for example  M45 with my T3i. All  images were been cropped, in the area I show stars are generally quite good to the edge--if they are not it is my fault for not better collimation. The FOV is quite large with the Hyperstar, so that is not such a big limitation to have to crop.There is a must article on optimizing the Hyperstar, and the challenges with a DSLR, by John Hayes:Hyperstar optimization Bottom line is I would not recommend that a DSLR is by any means the best for a Hyperstar, if one was going to buy a DSLR just for that, as it creates many issues. But with care and patience it can work very well, with the limitations above, if that is the camera you have now. And even with the obstruction of my camera shade, the difference in capturing nebula and galaxies at  f2.2 vs. f6.3 is amazing.Rick
Matt Stahl avatar
Thanks, Rick. I may hold off on the hyperstar, then, until I get my astrocam, and in the interim, get a 0.7x reducer. I appreciate the input.
Need reviews of the Sky-Watcher Quattro 150P with f3.45!!!
So far I have taken a few test shots with the Sky-Watcher Quattro 150P and the supplied coma corrector. I use a Canon 6Da with a full-frame sensor to shoot. In the edges of the image, it looks like the coma corrector doesn't work at all. Can anyo...
Full-frame DSLR use in astrophotography; discusses Canon 6Da sensor coverage.
Jan 18, 2023
Edge 8" Image Train with OAG and ASI2600MC Camera
Dear Astrophotographers, I recently bought the Celestron Edge 8 and am waiting for the OAG. I have no idea what the backfocus should be when I use this scope with the ZWO ASI2600MC camera. ZWO recommends a backfocus of 55mm, but I am not sure that ap...
Celestron Edge 8" telescope setup; directly relevant to C9.25 Edge discussion.
Dec 23, 2022
RC8/RASA8 or EdgeHD8 + Hyperstar?
Alright fellas, Here is the situation; as of now I have an RC8 and RASA8 as my two major telescopes. Lately I have been thinking of trading them out for just an EdgeHD 8 system. I won't consider any larger aperture so there's no point trying ...
Hyperstar with EdgeHD8 comparison; directly addresses Hyperstar and Edge telescope use.
Jun 14, 2022
