A.D.Ben avatar
Can someone tell me if it's possible to use a Celestron focus motor with an EQ6-R PRO? It's not working here.
David Redwine avatar
It should work,but you will need to use the USB connection.
Michel Makhlouta avatar
It's also much more stable if you connect 12V to it, the USB port is not enough sometimes to drive it.
Also make sure you're sure the focus motor ascom driver, not the celestron unified driver. The latter only works if you have a celestron mount with the focuser conencted to its aux port.
A.D.Ben avatar
It doesn't work with only the USB cable but I have it with the Celestron driver. I figured that it wouldn't work but I couldn't find an ASCOM driver.
A.D.Ben avatar
I am waiting for my "Pegasus pocket powerbox advanced". Today I will look for an ASCOM driver.
@Bernard Dube  here you go http://software.celestron.com/public_release/Focuser_USB_ASCOM_Setup.exe?_ga=2.109260032.48670476.1613601099-1295685490.1566731419
12V connection and a direct USB cable from it to your laptop and you should be fine.
A.D.Ben avatar
Thanks for the link, the focuser works now.
Carlo Colombo avatar
vorrei sapere se  c'è tra noi qualche vecchio astrofilo, che pur usando fotocamere digitali, usa ancora la guida fuori asse e oculare con reticolo per guida? forse è una domanda arcaica, ma io non riesco ad usare il computer perché mi infastidisce quando sono sotto un cielo
pieno di stelle, salvo quando devo fare i pianeti, scusate ma sono curioso di sapere se sono rimasto solo, ciao a tutti voi e cieli pieni di stelle.
Strange mount behaviour while guiding
Hi out there, I need some suggestions or possible solutions for a strange problem I had during the last weeks. I while ago, I bought a Skywatcher EQ5 Pro mount for a second setup beside my EQ6-R and for about 6 months everything seems to work fine. I...
Strange mount behaviour while guiding — discusses EQ5 mount issues, similar equipment troubleshooting.
Aug 10, 2022
Sky-Watcher EQM-35 Pro Not slewing
Hello this is my first post here and I'm hoping you folks can help. If this forum is not for equipment discussions I completely understand and please delete it. I bought my EQM-35 Pro brand new April of 21. I used it with no issues several times....
Sky-Watcher EQM-35 Pro Not slewing — mount equipment malfunction, relevant troubleshooting experience.
Oct 2, 2022
