I am about to switch from APO to C11Edge and was wondering if I would see much benefit from imaging at the native 2800 mm focal length as opposed to the .7x reduced 1,960 mm focal length. I am not one to change the imaging train once I start–so I tend to stick with a configuration for extended periods. So I would like to avoid the "try and see" approach. I have imaged with the C11Edge and .7x reducer. But I have not yet imaged at the native F10. I will be primarily imaging galaxies. I have played around with the FOV calculators and a good argument can be made for either. Part of me says use the reducer, dummy, duh….but part of me says folks like Gary Imm and Chis Lichblau get amazing images seemingly breaking every rule in the book (shooting at a pixel scale of .2 arcsec/pix, and Chris using a guide scope!)
The question is, would I see much difference between a non cropped image taken at F10 compared to a cropped version on an image taken at F7? It might be that I won't see much difference between the C11Edge image and a cropped TOA 130 image on account the seeing is typically poor (I hope to though,. otherwise no sense keeping the big boy).
So 2,800 mm (F10) or 1,960 mm (F7)? In either case I will be using the STT-8300 with a self guiding filter wheel. (like a OAG).
