Greetings from another NZ astrophotographer
5 replies53 views
Adam Rosner avatar
Seems I'm not the only one on here...
I've only just gotten started on this - I've been doing photography for ages, but I'm new to astro.
I'm on the council for my local Astronomical Society where we are building two observatories, one for Visual and one for Remote operation, in our nearby magnificent Bortle 1 soon-to-be-designated Dark Sky Reserve. So I expect to be posting some images from that eventually, but for now I'm imaging with a more modest setup
That's a Stock Canon DSLR on an iOptron SkyGuider Pro with a 61mm refractor.  I use this in my backyard which is in the outer suburbs of Wellington under Bortle 4 conditions.
Rosette Nebula
Eta Carinae Nebula
I've a special interest in the amazing deep-sky objects that we have in the southern hemisphere and I'll be re-visiting these targets when my camera is IR-modified and as my processing skills improve
Clear skies
I
Brian Boyle avatar
Welcome Adam!  That looks like a great (and very sensible) starter rig.  You will get some amazing wide-fields with that.  Not dissimilar to how I started out about 9 months ago - albeit with a 200mm lens.
I also think you have chosen the right upgrade path, improving red ssensitivity  and (post) processing skills.  These are the two things that have made the most dramatic changes to my images.
Looking forward to seeing your work.
CS, Brian
Well written Insightful Respectful Concise Engaging Supportive
Sean avatar
Hi from the US.  The images you captured with your setup are fantastic.  How do you like your refractor?
Sean
Well written Respectful Engaging Supportive
Adam Rosner avatar
Brian Boyle:
I also think you have chosen the right upgrade path, improving red sensitivity  and (post) processing skills.  These are the two things that have made the most dramatic changes to my images.
Thanks Brian. I've also got the Canon 70-200 lens and I took a few photos with that to begin with but nothing really worth putting on Astrobin. I saw your observatory it looks great. Yeah fingers crossed on the camera IR mod; do you know anyone in NZ that does it? I'm not game to try it myself and the closest place I've found is Melbourne so far!
Adam Rosner avatar
Sean:
Well I don't have much to compare it with since I'm quite new to this... but it seems to do the job nicely and I don't see any chromatic aberrations or coma, so I'm happy about that. Also the total payload my rig is carrying - guidescpe and cam, telescope and flattener and camera - comes to 3.2kg which I'm happy with since the mount's max payload capacity is 5kg.
Without a  GoTo mount it can be difficult to aim but since I started using Astrophotography Tool to run my sessions, it's relatively easy to aim in the general direction, take a test shot, plate-solve, then re-aim, rinse and repeat, until on target. Prior to doing that, I had a devil of a job to align, but that's a factor of the focal length not the refractor in general.
Brian Boyle avatar
Adam Rosner:
 No, in the end I just bought a ZWO OSC - and kept my Cano n 5D unmodified. Expensive, but wasn’t prepared to take the risk!
Going mono: advice on filter set selection
Hi all, I've been using OSC cameras only (EOS 6D & ASI 178 MC) since I've re-started astrophotography four years ago, first with a Samyang 135, and then with an ESPRIT 100 ED. I've definitely not yet exploited that relatively modest g...
Relevant for equipment setup discussion as author is building imaging capability.
Aug 21, 2022
Just one of those nights !!!
Anyone else had a night like this? I'm sitting here at after 1am having only just got my imaging capture going. It went like this: 1) Got the scope set up during the day: levelled, balanced and all the cables run back to the house and checked. 2)...
Relevant for troubleshooting imaging sessions; author is new to astro imaging.
Apr 22, 2022
