Subframe selector process alert
PixInsight Addicts •4 replies•161 views
Dave & Telescope avatar
Hi folks,
I just encountered this issue recently which applies at least to version 1.8-8-7. If you have been scratching your head why your subs are coming out way undersampled or just plain wrong, this could be the reason. I was concerned about this as I use this process in PI a lot. When you open SFS, go to the bottom and click on the wrench icon. This opens the "Subframe selector cache preferences" (attached image). By default the box next to "persistent file cache" is checked which does not make any sense but it is. You need to uncheck it as is shown in the image attached. Apparently it does not recognize any changes you make to the parameters in the process as long as this box is checked.
Anyway just an FYI
Happy processing!
Regards
Dave
Alex Woronow avatar
Thanks. I have not noticed any problems, but a "heads-up" always appreciated.
Alex
Gernot Schreider avatar
Thanks Dave for this tip.
Cheers
Gernot
Mark Wetzel avatar
Dave,
Thanks. I changed the setting and I'll give it a try.
Mark W
Richard Francis avatar
Thanks! I haven't had any problems, but had never noticed the wrench icon, so it's good to know about it.
cheers,
Richard
PCC Changed after the Spectophotometric CC???
Hello guys, Hey question, I just updated my PI and noticed the new Spectrophotometric Color Calibration process was added along with a couple of updates. I went to do the PCC process and noticed that the "Image parameters" where you put in ...
PCC Changed after the Spectophotometric CC??? — Updates to PI processes may affect subframe selection and calibration workflows.
Nov 25, 2022
