I am using the uncooled ASI178MC with a Rpi4 and have noticed that it delivers consistently two kidns of subs:
-A "normal" one
-A more glowy one with a very visible dark band at the top.
Attaching two subs that were taken consecutively (less than a few seconds apart) for you to understand what I am talking about:
"normal" sub:
"bad" sub:
The behavior is consistent in the sense that it appears to be happening regardless of sensor temperature (seen it from 2.5 degrees up to 35), sub duration, gain, offset, cabling, USB speed and bin level (although the band is a significantly wider at bin 2x2, that is it consumes a bigger percentage of the frame). It happens with the mono and the osc version of the sensor. It is pretty much random whether a light will have it or not. It does seem to be completely absent from darks which is very unfortunate as it makes it impossible to calibrate away. Both the dark band at the top and the glow at the bottom.
Anybody seen this before?
Thanks,
Dimitris
-A "normal" one
"normal" sub:
"bad" sub:
Thanks,
Dimitris
