Question about optics : Barlow and extension tubes
4 replies99 views
Jérémie avatar
Hi All,
I hope some people having good knowledge in optics will help me : I have bought a 4x Powermate and need to use some extension tubes to be able to focus.
On my setup I have connected the Barlow directly to refractor, and then the filter wheel and camera : that’s how I saw I could not focus (except when removing the camera and handling it further away from the Barlow), and needed some extension tubes.
But then I saw several setups where astrophotographers put the extension tubes first and then connect the Barlow, and then the filter wheel and camera. See picture below.
My question is : is that the right setup, putting extension tubes between the refractor and the Barlow ? I have read the magnification of the Barlow increases when you put extension tubes between the Barlow and the eyepiece (or the camera I guess ?). See this website : http://w1.411.telia.com/~u41105032/barlow/Barlext.htm
What is the right order ? Extension tubes first, between refractor and Barlow, or extension tubes after the Barlow, between the Barlow and camera ?
Any explanations or advices ? (Of course, I could try myself both but (i) I did not receive my extension tubes yet and (ii) I ordered M42 extension tubes while my Barlow is threaded M48, which force me tu put the tubes between the Barlow and the camera... but I can return them and order M48 ones if that’s the proper setup !)
Thanks fot tour help !
Jérémie avatar
Extension tubes before or after the Barlow ?
Brian Boyle avatar
It appears to depend a.lot on the Barlow.
FWIW I have a Barlow with an RC8. The achieve focus the Barlow sits in the extension tubes I already needed to get a 254mm back focal distance for my camera - but at a distance that is slightly closer to the main mirror (about 245mm behind the back of the mirror).  My camera is attached to the focusser behind the Barlow, about 65mm from the back of the Barlow.
If you don't want to change the amplification factor of the Barlow you need to put the extension tubes AHEAD of the Barlow up to the point where you achieve focus with the camera attached  to the Barlow. If you want to increase the amplification factor then add extension tubes after the Barlow and before the camera. Depending on the Barlow, you might still need extension tubes ahead of the Barlow too.
Well Written Helpful Concise
Jérémie avatar
Thanks guys !
CC6 + adapters
Hi, Does anyone in here have a CC6 and could tell me how you solved the adapter/extension part to achieve back focus? My current setup is by using all three (3) M90 extension tubes that came along with the telescope, which gives me merely 100 mm of o...
Discusses adapter and extension solutions for achieving proper back focus.
Sep 10, 2022
ZWO OAG, ZWO helical focuser, ZWO EFW 8 filter wheel, ASI290MM mini guide camera and ASI1600MM Pro imaging camera
Just wondered whether anyone is using the above combination and how it is working for them when connecting to a coma corrector with 55mm back focus? I believe that it would work as follows: * The OAG would connect to the coma corrector directly * I&#...
Addresses back focus challenges with filter wheel and camera combinations.
Apr 12, 2022
Find the good backfocus with my 200/800 SkyWatcher
Hello guys, I have a Newtonian SkyWatcher 200 Quattro P (200/800) with the SkyWatcher Coma Corrector GPU 4-lenses and ZWO ASI 1600 MMC Pro. Filters are ZWO LRGB SHO 31mm with 1.9mm of thickness. However, I'm getting some troubles in order to find...
Covers back focus issues with coma corrector and camera setup.
Nov 24, 2022
