72ED Guidescope + OVL Field Flattener Distortion Issues
6 replies87 views
Evan Boyle avatar
Hey guys,
I'm quite new to this hobby so I'm still trying to sort a few things out.
I currently have the SW 72ED with the OVL field flattener mounted on the Star Adventurer and I'm imaging with a Canon EOS 800D.
I'm struggling a bit with the distortion at the edges of my images where the stars are elongated away from the centre. This distortion can be seen most easily in my horse head and Orion Nebula image (both of which were cropped pretty aggressively). I've seen that graphic showing what differently distorted stars at the edge of an image means regarding back focus and, based off this, I should try increasing the back focus distance to get rounder stars across the entirety of the image, would this be correct? And if it is, does anyone know by how much I should increase this distance (I'm guessing only a few mm)?
I know with my current beginner setup I'm putting a bit of strain on the poor Star Adventurer but the distorted stars don't seem to be from bad guiding or bad polar alignment on my part, at least I don't think so, perhaps I'm wrong here too?
If anyone has any suggestions or has experienced a similar problem I would be extremely grateful for any help.
-Evan
Evan Boyle avatar
I'm not using any filters atm, and the stars are all good in the centre of the image, just around the edges they become distorted :'(
Evan Boyle avatar
Ohh ok good thinking, I didn't consider my eos adapter, now that you mention it thats just a cheap one off ebay so that could be the culprit 🤔
Víctor R. Ruiz avatar
I was told to use add an extra 10mm spacer to get rounder stars with the OVL flattener, so the total backfocus would be 65mm instead of 55mm, but I haven't tried yet.
Shooting at a bortle 2 at almost full moon, should I use a filter?
Hi! I have a little dilemma right now, I have the chance to shoot tonight at a Bortle 2, but I don't have the necessary things to power up my regular rig, so I am thinking of just taking my Canon T7, a tripod (and maybe my star adventurer) I plan...
Discusses filters and light pollution; author may need filter advice for better results.
Jan 7, 2023
Weird Guiding Issue with OAG/Asiair Plus
I am quite new to the whole astrophotography thing, and have put together a fairly sophisticated system that I am perhaps a little under-skilled to use properly. It's been a few months since I had a chance to use my gear, since our Southern Hemis...
Addresses guiding issues with similar beginner-level sophisticated equipment setup.
Apr 12, 2022
Refractor/OAG/flattener combo anyone?
Does anyone out there have a functioning setup (refractor) that includes an off axis guider paired with a field flattener requiring either 45mm or 55mm to the camera's plane? If so, I would love to know what products you have that achieve this. t...
Directly addresses field flattener with refractor; likely contains relevant spacing solutions.
Feb 2, 2019
