Celestron GOTO Accuracy with StarSense
3 replies59 views
Mark Bowles avatar
Hi there,
I have the StarSense auto align system fitted to my C8 AVX rig. Last night I set the telescope to 2 targets - the Horsehead nebula and the Orion nebula.
Whilst the flame nebula was near the centre of the captured image it completely missed the Horsehead. The Orion nebula was  not centred either and I had to use the N,S,W,E control pad in PHP 2 to centre the image before capturing with BYE.
Whilst these work arounds are ok, they are very time consuming, I have been unable to capture any target in the centre of the camera or eyepiece for 2 years now using StarSense!
I have tried using calibrate centre,  but after the mount is turned off it does not seem to retain its calibration anymore.
Any ideas? I have updated StarSense to version 01.20.19207 and I am using a Canon 750D.
Thank you.
Timothy Martin avatar
I have a C11 with StarSense. It’s okay for visual, but not for astrophotography. I’ve used BYE, but I switched to NINA for AP. It can use ASTAP for plate solving. Using NINA’s Framing Assistant with plate solving and manual rotation, it’s easy to get the target perfectly framed every time very quickly.
Rich Sky avatar
For AP, Starsense is not needed, get SGP or any plate solving software.
Clear skies
David Redwine avatar
Try CPWI.  Do a three star alignment then do an "All Star" to correct your polar alignment, then add another star to the model.   This should get you to about 10' of pointing accuracy.
If you own a Celestron mount, CPWI is a free download.
