Focal reducer for GSO RC 8".
Gso 8 RC Telescope Images 4 replies337 views
Marcelo Alves avatar
What's the best focal reducer for RC8? My camera is Canon T5 modified with APS-C sensor.
                  I only used my RC8 for 2 nights. First night only camera and telescope. Second night  I used with flattener 1.0x for refractors and the field improved a lot.
Ron avatar
I just began using the Teleskop Services 2" flattener for RC scopes.  It seems to work well as I am happy with the stars in the corners.  I chose it over others because of the long distance between the flattener and sensor.  With others, I would not have been able to fit my existing OAG and filter wheel in the required spacing.
HTH,
Ron
Thanks, Ron!
Jim Carroll avatar
Marcelo Alves:
This seems to be the most common focal reducer used by other RC 8 users. I just started using it.
https://www.astro-physics.com/ccdt67
Yes, I bought this one last year. Thanks!
Celestron Edge + Reducer - some experiences and experiments
Dear friends, spoiler alert: if you have a Celestron Edge + the Celestron LF reducer, and you are thoroughly happy with the results you are getting – think about not reading further: artefacts you recognize once you will see forever. No way to get ba...
Discusses reducer performance with similar telescope and optimization concerns.
Oct 23, 2022
Fixing the dreaded tilt and backspacing error in optical systems with objective analysis.
Fixing the dreaded tilt and backspacing error in optical systems with objective analysis. The curse and blessing of modern CMOS cameras is that amateur astro-imagers have easy and relatively affordable access to extremely high resolution detectors bu...
Addresses backspacing and optical system issues relevant to focal reducer setup.
Jul 29, 2022
Searching for a galaxy season telescope
Hello everyone! I am currently researching for a good match for my ASI533MC pro for galaxy season (it is early I know) and I am overwhelmed with all the information as always…I own an SWEQ6R pro and given my weigh limitations I am between a new...
Explores telescope and camera matching for astrophotography, similar equipment consideration.
Sep 6, 2022
