Brian Boyle avatar
I have been the very happy owner of a SkyWatcher EQ6-R Pro for the past 4 years.
Until now it has served me well, driving my Esprit 100 and RC8 all round the Southern Sky, on typically one night every four.  The mount is remain fixed between sessions - bolted onto the pier in my observatory.
Rms guiding has been about 0.5 - 0.6 arcsec rms using an OAG with the ZWO taking care of the guiding at 3-5s integration and binx2.
Over the past month, the guiding errors have started to show a signifciant period of high oscillation [amplitude 4 arcsec] in RA only, with a periodicity of a few secs [around the OAG camera integration integration time].. This oscillation usually lasts for about 30s-60s, but then disappears for periods 1-5 minutes, only to start again.  As far as I can tell, there is no  pattern to it.
The telescope is well-balanced on the mount (at least in RA).   I also check to see if anything had come loose [counterweights] pier/mount connection,OAG assembly, but nothing had loosened off.
My diagnosis is that the RA drive belt may be wearing or slipping, but before I open up the hatches on the mount and start to fiddle with the insides of the mount, I thought I would just ask  a) whether anyone else has experienced the same problems b) whether the diagnosis is accurate and c) to what extent it is fixable
Note that the mount has never been "tuned" as I was quite happy with the guiding performance in my typical seeing conditions of 3-4arcsec.
Many thanks
Stitching due to ageing lubricant. Clean and re-lube.
Tim Ray avatar
I agree with @andrea tasselli
You are due for some mount love!
CS Tim
CEM120EC real-world review with actual guiding metrics
CEM120EC — Real-World Review (With Actual Guiding Metrics) I realised something: there is almost no modern, accurate, real-world information on the CEM120EC. Most people only post when something breaks. So let’s correct the record because this mount ...
Real-world guiding metrics comparison for alternative mount consideration
Dec 7, 2025
Stars deformation
Hello all, Since I have my EQ6R Pro (3 months) on all my subs I have deformed stars. They're all in the same direction, I conclude that there is a guiding problem. But my process before shooting is as follow if I consider only parameters which ca...
EQ6-R Pro mount oscillations directly relevant to deformed stars issue.
Aug 9, 2022
Guiding RMS What gives?
I have been tweaking guiding settings the last week and have recently become a bit obsessed with the numbers. Ultimately I landed about 0.4RMS on my AM5 and this seems to be OK, But…. There is something that does not quite add up, I am going to...
Direct relevance to troubleshooting increased guiding RMS errors
Jun 4, 2025
(Worm Gear) Mount Advice
Recently had to do some maintenance to my EQ6-R Pro Mount due to guiding issues and thought I'd share for anyone who may be struggling with similar issues. ———— I’m using an EQ6-R Pro with an EdgeHD 8, OAG, and ASI2600MM. Mount is about 2 years old a...
EQ6-R Pro maintenance guidance for guiding issue resolution
Dec 16, 2025
My typical setup sequence in the backyard
Just sharing for any beginners out there. This is typically how I go about setting up and capturing for the night from scratch: 1) Take the tripod out, put it on my patio and point it as near to north as I can 2) Level the tripod using it's leg e...
Relevant for understanding mount performance and potential oscillation problems.
Jul 14, 2022
