Good Day to All!
I live in Providence, RI under Bortle 8 skies
My Equipment:
Meade Series 6000 80mm Triplet APO
Sky Watcher EQ6-R Pro
Canon EOS Ra
ZWO 30mm f4 MiniScope - Guiding
ZWO ASI224mc - Guiding
Notes: I guide usingan ST-4 connection, I use PHD2 for guiding (multi-star) and I use APT for capturing
I dither 20 pixels - 4 in PHD2 and 5 in APT
My main question is do I need to take darks - I have the similar issue as someone else who I saw post a comment saying that with the DSLR obviously I cannot control my camera's sensor temperature. I have processed images in the past - stacking one set with darks and one without and it didn't seem to make much of a difference (then again, it may be my crappy processing skills)
Because I cannot control the temp, I usually take my darks right before it gets dark enough to start my polar alignment - if I am going to use my typical 3 - 4 min exposures I will begin early enough to get that done - Ambient temperature difference between then and the end of my sessions could be up to 4-5 degrees (going from 38 degrees F to 28 degrees F) Celsius depending on how long I go - weeknights I am out for around 4-5 hours, weekends could be an all nighter.
Another Note: I typically take 15-20 darks, 50 flats, 50 dark flats and 50 bias frames. My light subs are 180s if I am not using an L-eNhanced filter, and either 4 - 5 min (typically 4) if I am. My ISO is set to 800 (tempted to try 1600)
I suppose my question is this, since I am dithering sort of aggressively, and since I am using a DSLR, should I even bother taking flats? OR at the very least, maybe take one set of flats for each exposure / ISO set maybe one time a month unless the ambient temperature changes drastically.
I don't get a lot of time, like most of us, to shoot actual data so I am trying to make my data capturing, as well as my processing, as efficient as possible.
Also, if anyone has any other suggestions, please feel free - First though, yes, I know, I should connect to my computer and guide that way, yes, I know, I should connect to my computer and plate solve and do my polar alignment through sharpcap, and yes, I know I really should take the ASIair Pro I bought out of the box and use that. I am currently happy with how my set up is the moment!
Thanks to everyone in advance!
My Equipment:
Canon EOS Ra
