Yay…It is coming…Before I order one the following must hold
1) The sensor window MUST be coated throwing no diffraction patterns like the ASI 1600
2) Can use 36 mm filters
3) Can use the same filter wheel that I use with ASI 1600
4) Must have 2 USB ports on camera; 1 for Filter wheel and 1 for guide cam
5) Supports hardware binning.
Preferable
1) the camera has the same back focus as the ASI1600–so all I need do is switch cameras with no thought of figuring out spacer requirements
2) Can do ROI so I can use the camera for lunar work (Planetary too).
Does anyone know about these things? If these hold, its dooable.
Preferable
