What prog. do use for Pre processing
ZWO ASI 2600MC PRO 10 replies483 views
Ali Alhawas avatar
Hi all,
For ASI2600MC pro.. what program do use for stacking and calibration ?
and do you notice any weird colors around the stars or any stars distortion ?
Thanks
Bruce Donzanti avatar
I use SharpCap and PixInsight and sometimes AstroPixel Processor.  I have had no issues with star colors or  distortion using this camera except for using the Celestron .7x reducer on my C11" EdgeHD.  However,  that  is not specific to the ASI2600MC pro.
John Favalessa avatar
I solely use AstroPixel Processor, APP, to integrate and then use it's remove light pollution tool.  then Pixinsight to process.  colors around stars are more than likely from the glass in the scope.  I've seen issues even with high end Takahashi's.   distortion is more than likely guiding issues.  I've found ez processing suite's ez decon for Pix to be helpful with distortion.
Ian Dixon avatar
I use John's method above (APP to stack and stretch, remove LP, and then Pixinsight).   Another great feature in APP is the star calibration tool, very easy to work with once you have taken out the light pollution, by selectiong the entire field (boxing it) and activate.  It provides a much more corrected field of colour.  This is testable by using the calibration tool in PI in a parallel process - and I have found the two to be very similar.   In series eg APP's calibration followed by PI's version, the second calibration is asked to do almost nothing, ergo the correction is already optimized.   You can PM me if you like with any questions.
Ian
Ian, I seldom use APP's star calibration tool, but will have to work with it more based on your experience.  THANKS!   Oh, now that I've got a mono camera, ASI2600MM, and LRGB and L2P filters (astrodon), I find APP even more valuable.
Roger Menard avatar
I use PixInsight for all of my image processing including calibration, stacking. etc.
Terry Doran avatar
I use Pixinsight for all calibration and stacking.  Most of the post processing is done in Pixinsight also, with minor touch ups done in Affinity Photo.
Rick Veregin avatar
I have the same camera and a C925 with f6.3 Starizona reducer. I use DeepSkyStacker for calibration, registration and stacking. It is easy (if you want you can load all your darks, lights,flats, etc and click stack to do everything, no other input needed), version 5 is super fast (200 large images takes maybe 10 minutes from calibration to stacking) compared to other software I have tried. This means if there is a problem very easy to adjust and rerun). It also has nice features like sigma-kappa rejection, etc, hot pixel removal, and comet stacking. It handles meridian flip with no problem, you don't need to do anything. I have noticed no issue with stars due to DSS. Here is a recent example:
https://www.astrobin.com/full/yzxzpf/0/
Other nice features it provides offsets, number of stars, background level, FWHM for all subs that are registered, so you can use that to screen out bad images, and you can click on any sub to preview what it looks like.
The only thing I know it can't handle is different plate scales.
Rick
David Moore avatar
I have the same camera and use Pixinsight for stacking and pre processing and Photoshop for final tweaking. I have not noticed any odd star shapes or colours with these programs.
Jim Case avatar
I  have been using APP for stacking, light pollution removal, star color correction, extraction of HA, OIII, & SII and then recombining them to produce OSC SHO images from dual narrowband filters. Photoshop is also used extensively in finishing, as well as the Apple image tools on the MAC. ASTAP is also useful, especially for tilt analysis. StarXterminator and NoiseXterminator are also very useful.
Roger Menard avatar
I use PixInsight for all my processes chores.
Roger
Recommendations for Astrophotography Lenses/Equipment (DSO specifically)
Hi All, I am really excited to be a part of the Astro-photography journey that I started a few weeks ago. I recently got a Star Adventurer Pro tracker (not 2i) and tried my hands on with it and was able to get comfortable with the wide-angle lens set...
Author uses ASI2600MC; seeking equipment recommendations relevant to their camera.
Apr 11, 2022
ASI2600MC combined with QHY268M
Hi everyone, I have the following question: The ASi2600MC delivers 6248x4176pixel subs, the QHY268M 6252x4176subs. I would like to use the ASI OSC to get subs for stars in RGB and combine that stack with my Ha, OIII, S2 subs from my QHY258M - but: Th...
Directly discusses ASI2600MC specifications and processing workflows.
Jul 10, 2022
¿Do you use dark-flats in WBPP?
Hi, I’m taking lights, darks, bias, flats and dark-flats but when stacking with WBPP I don’t know how to use de dark-flats. Maybe I have to upload them with the other darks and WBPP will understand that they will be used to callibrate flats? Many tha...
Addresses stacking and calibration processes author is asking about.
Jun 17, 2022
ASI2600 File Size Management
So I just upgraded from the ASI533 mc pro to the 2600 mc pro and just to be able to run WBPP on the 1st light image, I had to run out and get a 5tb external HD. I had a 1tb Question is: going forward, what can I expect? What do you all use? Any file ...
Discusses ASI2600MC pro file management and WBPP stacking software.
Dec 1, 2022
