ASI2600MC pro compared to ASI294MC pro. I am thinking of trading up.
8 replies736 views
Tim Song Jones avatar
I currently have an ASI294MC Pro camera and am thinking of trading up to the ASI2600MC Pro. Would there be a significant improvement in my images? Would I have to get a different filter drawer?
Mike H - Sky View Observatory avatar
Tim, go to ZWO's web site and do a side by side comparison. The 2600 has an APS-C chip so a larger field. No amp glow and 26mps as opposed to 11.7. Kind of depends on what you mean by "improvement." 2600 users put just as much work, planning and processing in as a 294 user.  If you're currently using a filter drawer that holds 2" filters, they will work fine.
Mike
Rodrigo Roesch avatar
It will depend on what type of telescope you are using the camera. The 2600mc  has smaller pixel  which will give you  better sampling in widefield images. To me, the main advantages of the 2600mc over the 294mc that make the replacement worth are:
  • Much easier to calibrate. The 294mc tends to produce weird patterns mainly when the Peltier usage is high or doing long exposures  (longer than 5 min). This is more relevant when used dual band filters.
  • The 2600mc does not have amp glow, so the need of darks may not be as critical
  • You have much larger field of view.
  • 16 bit vs 14 bit. This will give you more flexibility at higher gain  since dynamic range tends to drop
I should have listed my scopes: a Celestron 8" RASA and a TS Optics 8" carbon fiber Newtonian.
For the RASA, you will have to buy a different adapter since the filter drawer is too thick to get the spacing. Starizona sell those, but filters need to be installed in the back of the adapter.
It will give you better sampling too.
I was afraid of that. THANK YOU AGAIN.
Stargazer66207 avatar
Tim,
Go for it!  In addition to all of the advantages listed by Mike and Rodrigo, it ALSO has the newest technology: back illuminated chip design, where all the circuitry, etc., is on the BACK side of the chip, so you get better light gathering and resolution.
Also, the 2600MC Pro is now on sale at several vendors.  I've had mine for 3 years and LOVE it.  Some of the finest images on AstroBin have been done with the 2600MC Pro.
Ron Abbott
Thank you!
Brian Diaz avatar
Tim Song Jones:
hi
tablet with proper filter size
zwo 294 mm or mc   filter 31mm (min)  format 4/3
zwo 2600mm or mc  filter 36mm ( min) format APS-C
zwo 6200 mm or mc filter 50mm ( min) format full frame /aps-c
36mm filters in 2" filter wheel?
Hi all, I was set on moving from DSLR to mono this year but I think I will go with and ASP-C OSC(2600MC pro) in the end. There hasn’t been a fully clear night since the end of September and I’m not sure if I would be able to make the best use of Mono...
Discusses ASI2600MC Pro camera and filter wheel compatibility directly.
Nov 9, 2025
Combining OSC 2600mc with 2600mm Mono Data
Hello, I have the following camera systems that cover 3 scopes and 2 mounts. ———————— Camera 1 system: 2600mc Pro ZWO EFW Antlia ALP-T 3nm HaO3 Filter Antlia ALP-T 3nm S2O3 Filter L-Quad ———— Camera 2 System 2600mm Pro ZWO EFW Antlia LRGB + 3nm SHO F...
Covers ASI2600MC Pro camera setup and filter configurations.
Dec 27, 2025
