Having strange Color "waves" across my image, where do the come from and how do I fix them?
10 replies681 views
Jens avatar
My Gear: Asi 2600 mc Pro
WO Zenithstar 61 with flat61 fieldflatener
Optolong L-enhance
So I edited my photos in pixinsight and always had problem with colors because I skipped color calibration (yeah stupid me)
So I started colorcalibratin my images with Auto color script in PI.
It was fantastic with all the colors I finally was able to work with.
Now I streched my data and ran it through my photoshop workflow and realized there is some weird color banding that was happening.
It kind of looks like two sheets of glass being put ontop of eachother, kind of like moiree.
Do you guys know where that comes from? I havenßt had this problem without the color calibration.
Thats what it looks like:
Streched to oblivion to see it better
Poor calibration is usually the culprit for this sort of things.
Mo avatar
Go back through your same processing and leave a different step out each time,  Process of elimination will hopefully show you the problem.
Jack Groves avatar
Have you ran a background extraction? Sometimes that can leave some strange artifacts if done incorrectly. Try running DBE and review the background image and see if you have some similar patterns.
My other guess would be something related to your flat calibration. Do you have an example of a master flat you could share?
Well written Helpful Respectful Concise
James avatar
Agree that this is likely a calibration issue.  I have seen this exact pattern a few times over the years.  A fresh set of darks or flats will probably correct the issue.
Well written Concise
Jens avatar
calibration wasn't really on my mind when I saw that.
Here you can download the master flat:
https://www.swisstransfer.com/d/b7255483-6933-4078-917b-0ae979c9ad4b
How do you see if the flats are good? I use a LED Panel to take those flats, no diffsuion or anything inbetween. Has worked great so far.
I also realized that when I'm not doing the color calibration, the color banding is reduced a lot but the still appear when the image is streched to far.
churmey avatar
I have had similar,  although  slightly different result, due to the following reason.  I shoot my flats at the very end of the session. I was bringing my flat panel out of a warm house / car and directly onto the top of my scope. Since it didn't have time to temperature equalize, fog/dew was instantly creating a thin layer of moisture across my flat panel (resulting in similar effects that I see in your image).  This was difficult to catch because you can't necessarily see it that easily when you have the flat panel on. Since I realized what was going on, I now leave my flat panel outside so that it's at the same ambient temperature as my scope. Since I began to do this, these types of issues went away for me.
Well written Helpful Insightful Engaging Supportive
Wei-Hao Wang avatar
I agree that calibration (the processing part) isn't likely to cause something like this.  It must be something else.  I think it may help if you tell us more about how the images were taken (optics, camera, filter, Bortle scale of the site, integrations, etc) and what processes have gone into this picture.  Is the stacked linear image very dark?  Have you run ABE or DBE?  A very dark linear image plus ABE or DBE can sometimes trigger something like this.
Well written Helpful Insightful Concise Engaging
James avatar
I had to go back through my history to find this.  Here's what I saw.. now its with a mono camera but as you can see the banding looks very similar.  The banding was only  seen after running DBE or ABE.  The issue was with the dark frames.  A fresh set of darks resolved the issue.
Helpful Concise Supportive
Jens avatar
that does look very similar, I'll keep my eyes pealed in the next project, if it's still there i'll have to get to the bottom of this. I managed to edit the Orion image without it showing up to much (I just uploaded it to astrobin) and I'm quite happy with the result. I really hope it's the same problem as you had.
Rodrigo Roesch avatar
What gradient removal did you use? I have had similar issue with some pictures when using  DBX.  So sometimes I used SPCC instead. In addition, how long were you flats? very fast flats could introduce artifacts due to capturing the shooter of the camera, so make sure your flats are around 3-4 s
Does anyone know what causes this?
While I was checking a photo I took a few months ago, I noticed this strange pattern in this star… Is this caused by some kind of aberration? It does not worry me at all, just for curiosity Equipment: Radian AP 61/275 Raptor OTA + ZWO ASI 533 M...
Strange color/wave patterns in images; similar camera and troubleshooting focus.
Apr 7, 2022
Hi all from Gloucester UK.
Hello all I’m stuart and from Gloucester in the uk. I have owned my scope William Optic ZS 81 about 3 months but only had a couple of chances to use recently due to constant clouds. Have had a couple of good nights imaging the heart nebula and Androm...
Shares same camera (ASI 294mc) and struggles with PixInsight processing issues.
Jan 26, 2022
Stuck in a rut looking for some inspiration!!
Lately, I have been just kind of “down in the dumps” about the quality of the images I have been producing. I feel like no matter how I much try and learn or try to pay extra attention to my data when processing, The results haven’t been satisfactory...
Author seeks inspiration; post describes technical processing problem, not motivation issue.
Nov 17, 2025
Latest WBPP Results with ASI2600 MCP (Celestron 9.25" Edge HD) seem to Indicate a Problem - What am I doing wrong?
Hello- I am imaging at F10 with Celestron 9.25" Edge HD, ASI2600 MCP and EQ6 R Pro mount with Celestron OAG from Bortle 4-5 skies. I use ASIAir Plus, a camera gain of 100 and BIN 3 normally with this set up. Previously I had no issues with the a...
Shares ASI2600 camera and PixInsight workflow; discusses color/processing issues with similar equipment.
May 31, 2025
