Hand Controller Time out
9 replies295 views
Aumarina avatar
Hello all,
recently I purchased an ASIAIR and have been trying to use it in conjunction with my IOptron GEM28 mount. However, after focusing and polar aligning, when I go to slew my mount to an object the hand controller will shut down for half a second, causing the slew to stop, and then turn back on as if nothing happened. There's no issue in any other part of the workflow, and the mount will work without issue if I use the arrows to do everything maually. I was looking into EQMOD cables to bypass the hand controller entirely but I'm not sure which would be compatible with the mount. Any advice is appreciated, thanks.
Wolfgang Martin avatar
Hello,
I use the GEM28 with ASIAIR Mini. After switching on all devices, I no longer use the HBX on the GEM28 and only work with the Asiar app. Everything works fine.
Greetings Wolfgang
Andrew Ford avatar
You're not powering the GEM28 from the ASIAIR are you?
The ASIAIR is renowned for not being able to supply enough current for mounts. it is possible the mount is losing power for a split second due to the power port on the ASIAIR giving up and resetting.
Try powering the GEM28 from an external power supply brick
I supply the Asiair mini with the 12v output on the GEM28, never any problems.
The GEM28 is powered directly via the power supply unit.
Justin avatar
Hello Aumarina,
I have the same mount connected to the ASIAir Plus. I had similar connectivity issues with one specific USB cable. After switching to a new cable, the problem went away. So, I'd check the cables first. Even when I was using a laptop, I'd have intermittent issues depending on the cable and USB port I used. I think the mount is definitely sensitive to bad cables. I hope you get it figured out.
Clear Skies,
Justin
Well Written Helpful Concise Supportive
Rob avatar
I have had something similar happen to me when I used the ASIAIR Plus with my GEM28.  The mount would become unresponsive and I'd hear the mystifying beep from the hand controller if I was nearby.  I would go out and check the equipment, and the hand controller would be on but the mount would not respond to even its commands. For me, the quick fix was power cycling the mount.
Well Written Concise
Aumarina avatar
Thank you all for the responses. I think I've tracked the problem down. I've been using a different power cable than the one that came with the mount and im assuming that it has to do with this. Going to put it to the test tonight. Thanks guys.
merrill love avatar
Hello all,
i have that issue if one of the power cables isnt snug with the box.
Rajat Kumar avatar
I have a miniPC mounted on my scope to control my imaging run so cannot say anything about ASIAIR. I use GEM28's inbuilt WIFI to connect the mount with the MiniPC. Initially, I use to connect HC with the PC using the cable which came with the mount but soon enough connection problems started showing up. A change of cable definitely helped but then later I changed the connection to wifi and it has worked flawlessly for me. I use a small USB shaped WiFI adapter which is connected to my MiniPC that connects to the mount's WiFi. The native internal wifi card in the miniPC is connected to my home wifi so that I can control the sequence remotely.
The other benefit is that you have one cable less which would normally run from the hand controller to the miniPC. The mount is connected to the power supply directly through 12v power adapter which came with the mount. The miniPC is powered by 12V output supply from the mount itself. Cable management is lot easier that way. For GEM28, I do not think there is any way to bypass HC to make it work normally.
Just my two cents.
CS!
iOptron Skyhunter and ASIAir support
I've an iOptron Skyhunter with iPolar, I am planning to get ZWO ASIAir Mini computer to control my set up but unable to get any resource saying if it is compatible with the mount or not. I've checked ZWO support website and this mount is not ...
iOptron mount with ASIAir compatibility and control issues.
Jun 11, 2025
How do I connect AISAir to 10 Micron GM1000 HPS?
I have a 10 Micron GM1000 HPS with either a Orion Optics ODK-10 or a Takahashi FSQ-106. So far I have used only the hand control to find objects to photograph. The 10 Micron GM1000 HPS is pier- mounted in my backyard observatory about 20 m from my ho...
ASIAIR hand controller timeout issue with mount connection directly relevant.
Jul 5, 2022
DISCONNECTION WITH IOPTRON COMMANDER
HELLO EVERYONE I have an ioptron cem 120 EC2. Randomly the ioptron commander application disconnects saying that it can't find any devices anymore. Looking in the USB peripherals I see the mount connected. The only way to reconnect the applicatio...
iOptron hand controller disconnection problems similar to yours.
May 22, 2025
ASIAIR Mini and ASI2600MC exposure failures despite troubleshooting attempts
Hello, I have been using the ASIAIR Mini coupled with the ASI2600MC camera. My current set-up has been working flawlessly for a long while. Last night I had a little initial trouble with the start-up, the camera advised an exposure failure while I wa...
ASIAir exposure/control issues that may relate to your problem.
Oct 11, 2025
