This is my best image yet. https://astrob.in/j39mte/0/
All processing was done in PixInsight. WBPP with CosmeticCorrection was used with 30 flats and 30 flat-darks.
25 600s exposures were taken using the L-extreme filter. RGB channels were extracted from the stacked master. A color image was then made using PixelMath as follows:
R: .917*R + .071*G + .0336B (simulated Ha channel)
G: .083*R + .929*G + .9664B (simulated OIII channel)
B: .083*R + .929*G + .9664B (simulated OIII channel)
The idea here was to do a quasi-HOO palette. I'm not sure if I did it correctly but the resulting image was a bit better so I went with it.
Thanks,
Casey
Thanks,
Casey
