10 MICRON - GM1000HPS controlled by ASIair Pro?
4 replies271 views
TOM DAIGON avatar
I am thinking of upgrading my mount to a 10 MICRON - GM1000HPS. I noticed in a Facebook post that someone was using ASIair Pro with the Micron  GM1000 successfully.  Does anyone here have the same setup? Do they work well together? Any issues? I am thinking of upgrading my EdgeHD8 rigs EQ6 but want to make sure the Micron works as seamlessly as the EQ6 does with ASIair Pro. Thanks!
Michel Audette avatar
Hi Tom;
did you find out if they are compatible with the ASIPro?
Michel
TOM DAIGON avatar
Nope.
AstroRepublic avatar
I am using the ASI Air Pro to control my 10 micron GM1000 and it works fine. The only thing I haven't managed to do is a meridian flip. Also if you plan to get the most out of your mount, I would think carefully about a mini PC or some other way to perform a pointing model as using the ASI Air pro is tedious and time consuming to do even a 20 point model. To expand on the point, I have the mount on a permanent pier…no dome and just cover up but remove the OTA (looking for a solution for this).
I mount the telescope and perform a polar alignment using AAP which usually gets me within  0"30. Once that's done I'm in the house from then. I have the mount connected to the AAP and the AAP is connected to a WiFi extender. I connect my PC to the mount and the AAP on my iPad. Connect to virtual keypad and perform a 3 star alignment. This usually records the same PA error as the AAP. On each star I perform a go-to and the virtual keypad asks me to centre and confirm. I take a 3 sec exposure on the AAP and then perform a go-to on the same star with the crosshairs turned on. AAP platesolves and centres then I confirm on the virtual keypad. I add as many refinement stars as I want and watch the RMS drop quick.
I then perform a polar alignment on the virtual keypad and centre the one polar alignment star mechanically - with the 10micron it does not have to be polarissmile. Once done I then clear the alignment and then run a 3 star alignment again and usually up to 20 refinement stars then I'm done. I use a Rasa 8 and use short exposures to beat light pollution from my bortle 7 skies so no more than 30sec exposures…probably overkill on the alignment given the short exposures. I have tried a 10min exposure and there were no star trails.
TOM DAIGON avatar
Thanks. After considering ASIair I decided almost immediately  to shift gears and use NINA on the Eagle 4 computer. ASIair is great…but NINA is better.  smile.
My current EQ6-R (just finished 10 min.. exposures on the Pacman) will be relegated to the RASA 8 and ASIair. And the EdgeHD 11  will go on the 10 Micron (expected in February) and will be controlled by NINA.
How do I connect AISAir to 10 Micron GM1000 HPS?
I have a 10 Micron GM1000 HPS with either a Orion Optics ODK-10 or a Takahashi FSQ-106. So far I have used only the hand control to find objects to photograph. The 10 Micron GM1000 HPS is pier- mounted in my backyard observatory about 20 m from my ho...
Directly addresses ASIair Pro compatibility with 10 Micron GM1000 HPS mount.
Jul 5, 2022
EQ6R stops Tracking with ASIAIR PLUS
Hi everyone, i have an issue with my EQ6R-Pro+ASIAIR PLUS setup. Everything is working fine except one thing: the mount stops tracking in various situations, e.g. when a plan has finished or was aborted. Sometimes it feels just randomly. When navigat...
Discusses ASIair compatibility issues with mounts, relevant troubleshooting reference.
Sep 21, 2022
EQ6-R vs CEM60 for an 8" Newtonian
Hi, so it's that time of year again, the nights are getting longer (in the Northern hemisphere anyway) and I am thinking about buying astro gear At the moment, I am using a 4" APO on an older NEQ6 - which works fine'ish, although I am ge...
Relevant - author considering mount upgrade; discusses advanced mount options for astrophotography.
Oct 17, 2019
