Strange star flares
7 replies327 views
Jordan Morley avatar
iv been using my 10" f4 newt for quite sometime now with no hassles, last night i fired it up to image and iv got these odd V-shaped flares. my colimation is slightly off but its never caused odd looking v-shaped flare stars before.
any idears?
Something extraneous is in the light path.
James Ross avatar
Common culprits are the mirror clips although that usually looks symmetrical. If your collimation has slipped far enough (secondary mirror rotation?) it might be making the effect from the clips worse. Focus tube protruding into the light path can also cause something similar but I expect you'd have seen that before now.
If you can't find any obstruction to the light path I'd check for condensation on a coma corrector face if you have one. Warm air rising from the ground or from within the tube is another option - you can easily check this by looking at the orientation of the artefact with respect to the ground, if it is a thermal effect the artefact should usually be pointing vertically up.
Helpful Insightful
spent the afternoon patching up my focuser  internal area with sticky flock I remembered that I moved to a new compression ring for my correctors. I believe the colprit may of been the rack slide as it's quite shiny. I cut a 2" circle in a quare piece of flock to hide it. Its worked and I'm back to regular stars in my images! Thanks for the input it helped (:
Jord
Alejandro Navarro avatar
Hi, you just need an aperture mask
greets!
Alejandro Navarro:
greets!
*** iv got one, very important to have on a skywatcher newt***
merrill love avatar
Is there a smudge near one of the clips? something similar happened to me and the got a closer look and it was when I tried to clean a hair off the primary. It could also be the focuser tube.
Nikola Antonov avatar
Jordan Morley:
Jord
Hi Jordan, could you please explain in more detail what you did and what was the cause of the issue? I think I have the same problem with the same model telescope.
Help, strange artefacts in my images…
I just got a new camera (6200MM, use to have the 2600MM) and never noticed something like this before. It seems at the beginning of a session it starts to show this weird blob, and it gets worse as it gets cooler, if i turn the cooler off it gets bet...
New camera may reveal previously unnoticed artifacts in imaging.
Aug 3, 2025
Mysterious star trailing solved: a cautionary tale of fan vibration with a fan cooled (especially ZWO) camera.
Suddenly after no problems with star shapes, the next night out they were just terrible! Below I show a gif comparing two 2 hr stacks, one with the good stars, and the next with elongated stars. In this example the distortion was vertical. But later ...
Fan vibration causes star shape problems similar to described flares.
Nov 18, 2025
Unable to achieve focus after reflector modifications
So last week I received my new spider, primary mask and rear plate(?) off AliExpress (link for reference - https://www.aliexpre....51d31802lnldIB) for my Sky Watcher Quattro 250P F4 My steps so far as follows: I installed the spider and mounted the s...
Reflector modifications can affect collimation and star appearance issues.
Aug 10, 2025
