Recalibration after Meridian Flip
12 replies575 views
Jerry Gerber avatar
I'm using ASIAIR Plus along with the AM5 mount.  Do you re-calibrate guiding after the MF or do you not, and if you don't, is your guiding unaffected by the flip?
It seems counterproductive to finish the flip and then move to a star near the celestial equator to do a calibration routine, and then move back to the object you're imaging.  Kind of defeats the purpose of the flip.  The other option is to re-calibrate, but do it on a star (after the flip) while centered on the object or region you're imaging.
What are your experiences with this?
Jerry
Well written Engaging
Alan Brunelle avatar
Hi Jerry,
I would have to ask if you are having problems after your flip?  If not, then I think you have your answer. See below about PHD being able to do a mathmatical inversion of the model.
I always calibrate in the frame of my target, typically after centering for the first time.  First, I believe that it is best to calibrate within the field that is being recorded anyway.  Someone can correct me if I am wrong, but when you see the calibration process working, it makes perfectly good sense that this is best.    Only exception is that I know that I have failed to get PHD Guiding to calibrate close to the pole, but I am not sure going to the the ecliptic is going to help in that situation.  Luckily, I have gotten decent guiding even in the event of a failed calibration near the pole.
Second, if you look at the calibration model, it becomes clear that the math during a flip to invert the model is pretty trivial.  So PHD Guiding does not normally even ask to reboot the calibration in that case.  The problem is that some peoples' mounts have issues in the flip.  That can be evident after the mount flips and the frame rotation is not a true 180 degrees inversion or close to 180.  If you have that as an issue, by experience, you should determine whether a recalibration really offers any real improvement in your guiding.  I wouldn't waste time redoing a calibration unless it is required for your situation.  Always best not to fix, which is not broken rule.
So how can a mount not get a perfect 180 inversion between flips?  Beside thinking that a polar alignment is perfect, I think that most people forget that you can get a good polar alignment even if you mess up the level of the mount.  In such a case, an unlevel mount means that the polar alignment only looks good.  People who have a permanent pier typically don't have to worry about that!  Except once.  I just saw a post regarding poor flip numbers because the mount was poor.  So not all mounts are perfectly orthogonal in construction.  That is one reason, other than level issues.  In my case, I get good guiding without recalibration through the flip.  And my AM5, which has two bubble levels is the only way I level my mount.  With my bad weather and short windows of opportunity, I have no time to fool with perfect level, and the crappy levels that are on my AM5 do not even agree with one another!  Like, which one am I supposed to believe.  Given that situation, I know that one level is wrong, and that is the best case scenario.  The other scenario is both levels are wrong!  I know that my levels are off because when I do my polar alignment, if perfectly level, adjusting Dec should have zero effect on  effect on Az and visa versa.  That never happens for me, so it can only be level being off.  But it is never that bad, so I let PHD do the job of corrections during the imaging.  Thats what I pay it for!
Richard Carande avatar
I'm pretty sure that a ZWO AM5 and ZWO ASIAIR understand each other well enough that you don't need to re-calibrate after a merodian flip.  Several years ago, when I got my first ASIAIR and was using it with a Celestron AVX, I did need to recalibrate after a meridian filp, otherwise the guiding would immediately go crazy.  But then at some point after a software upgrade a few years ago, that became unnecessary.
Mark Germani avatar
Hi Jerry, I’m using a iOptron CEM26 and I only calibrate when I make changes to the telescope and anything connected to it (adding/removing/repositioning components). I’ve tried recalibrating other times to see if it has any impact on the guiding, and it never has. I feel like I’m the exception to the rule here - maybe it’s a CEM thing? Just my two cents.
Mark
Edit: I should add that I’m imaging at 360mm FL with an error rate of 0.4-0.6 on a good night.
If I wasn't clear when I said the math that PHD needs to do to flip the calibration model, what I meant was that your sequencer and PHD should easily take care of the flip and do the math automatically.  I know in NINA that, 1. NINA tells PHD to stop tracking just prior to flip.  2.  Then after the flip, I believe NINA tells PHD to select a new guide star.  3.  Then it tells PHD to start tracking.  PHD in that situation never has asked me to recalibrate.  Ever.  Yet if I move to a different part of the sky, PHD will sometimes warn me about calibration.  I think for NINA, it's plainly obvious that flipping initiates a mathematical carryover of the current calibration model to the other side of the pier.  I assume that any sequencer does this, including ASIAIR.  Otherwise what's the point of automating a flip?
Oh.  And if you work the same area of the sky multiple nights with different sequences and PHD asks to do a recalibration, you can tell it to use the previous calibration.  I do that all the time and it works great.  That is with same rig.
I wouldn't be surprised if you can  name and save calibrations and load them later to reactivate them.  But I've never done that.
Jerry Gerber avatar
Thanks Alan, Richard and Mark for sharing your thoughts and experience with me.  Next time I'm imaging I'll uncheck "re-calibrate after Meridian Flip" and see what happens..
Well written Respectful
Stuart Taylor avatar
Jerry, I don't use ASI Air, but rather a mini PC and NINA. But I never recalibrate after a flip (as you say, it would rather defeat the object!). My guiding numbers stay the same.
You don't mention if your guiding deteriorates post-flip. Unless it does, I can't see any reason to recalibrate.
Well written Concise
Quinn Groessl avatar
Alan Brunelle:
Well that's going to depend on a few things though. If you take everything apart each night you probably wouldn't want to do that because your guide camera probably won't be aligned the same throwing the calibration off.
Lynn K avatar
Hi Jerry, I don't use ASIair or own an AM5. I think the question you are asking is ,does the ASIair automatically reverse the DEC drive for peir flip, OR do I need to do it manually. There should be no need to recalibrate a mount of any design. Your mount calibration for Ra & DEC drive speeds should have not changed. Also the guide scope angle should not change either, even though the image will rotate 180. Guiding software, knowing there has been a peir flip should accondate for the 180 guide image rotation.
With other guiding software, one may need to check the "Peir Flip" box.
1Lynn K.
Quinn Groessl:
Alan Brunelle:
Agreed!  Typically, if I'm not rushed to start, I will always do a calibration after target centering and framing is completed.  But sometimes I am late and cheat!  Never takes that much time.
winestein avatar
I use an Asiair mini with an AM3 mount.  I calibrate at the celestial equator, then goto target.  Then start guiding, and then I stop near the meridian.  After the flip, I just hit guiding and it has worked every time, without re-calibration.
Jan Erik Vallestad avatar
I don't re-calibrate after the flip, seems to be working just fine. I use the AA+ and I use the same calibration for consecutive nights as well. I don't necessarily re-calibrate unless I see an issue or I'm setting it up after some time off.
