Hi Trana, welcome to this forum!
I started out with an ETX 105, which is quite similar.
First of all, you are going to need one of each of these to mount your camera to the back of the scope: I would recommend getting one of these, because it will give you more freedom of movement for the scope:
https://www.ebay.com/itm/Teleskop-Direkt-Foto-Kameraadapter-1-25-auf-Canon-EOS-TS1-EOS/371740834342?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D225074%26meid%3D729d4d73b4ab4ab890d9f5455f8d0b70%26pid%3D100970%26rk%3D1%26rkt%3D4%26mehot%3Dag%26sd%3D371740834342%26itm%3D371740834342%26pmt%3D0%26noa%3D1%26pg%3D2380057&_trksid=p2380057.c100970.m5481&_trkparms=pageci%3Accbea118-2b13-11eb-96c0-76e41147b221%7Cparentrq%3Ae502b1671750acc6e18c239efff0b13e%7Ciid%3A1The other way to attach it would be using the following two items to attach the camera to the back of the scope, but this will limit you to altitudes of about 30-40° because the camera touches the base of the Scope at some point.
https://www.meade.com/accessories/meade-64-t-adapter-for-photography-with-etx-and-starnavigator-ng-mak.htmlhttps://www.meade.com/accessories/meade-canon-eos-t-mount.htmlAnyway, the EOS 5d is quite heavy, so it will be best to put some weight on the front end of the scope to balance it out. Filters won't be necessary as an unmodified DSLR has an UV-IR cut Filter in front of the Sensor anyway.
Otherwise, the process would be: Do a star alignment using the eyepiece, goto to the object you want to shoot, switch the camera+1,25" adapter for the eyepiece, refocus using liveview.
As for the image capture and processing, there's loads of tutorials out there like this one:
https://www.youtube.com/watch?v=Nbaw-5Kj1IIHope this helps and clear skies!
