Ideal subjects for antlia triband filter
5 replies452 views
Alfontheroad avatar
I recently bought the Antlia triband filter and beyond the characteristics praised by the manufacturer I would like to understand which are the ideal subjects on which to use these filters and on which ones it would be appropriate to use other ones such as narrow band filters for example
Clear skies!
Itto Ogami avatar
Check out my last few images in my profile. I have used this filter for my last 6 images and have given my thoughts on this filter in the descriptions. I have done both broadband and narrowband targets. Be Well and clear skies!
Regards,
Itto (Jim)
Miguel T. Acosta avatar
I recommend checking out @Itto Ogami  posts, he has great work with the Antlia TriBand filter.
Mark C. Helton avatar
I am pretty much using this filter exclusively now for general nebula imaging.  I am having great success with it.  My only observation is that I seem to have to edit some of the green left over after processing.  I use SNCR in PIX to get rid of the final green tint left over.  Not sure if that is the filter, or the way that I process the image.  Other than that, I am very happy with it.  You can check out my page Great Neck Observatory to see examples of targets that I have gotten in the last half a year since I got the filter.  Clear Skies
Mark
Monty Chandler avatar
I have also gone to the Antila Broadband light pollution filters. I use the quadband with my ar sensor on the 071mc pro.  I use it for reflection nebula, galaxies, and star clusters.  I have yet to try it with emission nebula as I generally image those with the radian ultra quadband narrowband filter.  The Antila are really nice light pollution filters!
Jon Bryan avatar
I was using the Triband for everything for several months (Bortle 4). It works really well for me to bring up the Ha and OIII significantly while still working with reflection nebulae. It helps significantly with my doublet's chromatic aberration to cut down on blue halos, as does the Astronomik L-3 UV/IR cut that I've been trying out the last couple of weeks. Here are some Triband examples:
IMX410 or IMX455 for Samyang (Rokinon, Walimex) 135mm f2 + filter choice
Hi, I recently bought a Samyang (same as Rokinon or Walimex) 135mm f/2 lens. Now, I need a camera to go with it. I definitely want a full-frame camera so that the field of view is significantly different from what I get with my Tak FS-60 paired with ...
Camera selection for lens doesn't address filter subject suitability questions.
Jul 22, 2025
Combining dual telescope setup data for narrowband imaging efficiency (Mono Ha/OIII + OSC L-Extreme)
Good morning, For some time now, I have been experimenting with how to get the most out of my dual setup. Basically, I have the following instruments mounted in parallel on my mount, which capture the same subject synchronously: 1) A WO FLT 120 with ...
Narrowband imaging efficiency directly relevant to filter selection comparison.
Oct 11, 2025
Advice on duo-band filter selection for astrophotography setup
Hi, I am looking to expand my astrophotography setup with a duo-band filter. Well, possibly two depend on how the pricing goes. I’m looking to have my feel-pinions validated and possibly a correction from someone who knows what they’re talking about....
Duo-band filter selection advice relevant to triband filter applications.
Aug 31, 2025
No signal in my new filters
Hello, I have recently bought a new set of filters. Antlia V-Series LRGB and 7nm HSO. I recently installed everything and had "first light" last night from my DIY remote observatory. When I remoted in to the PC and started imaging I noticed...
Antlia filters troubleshooting relevant to understanding new Antlia filter usage.
Aug 17, 2025
