Artifact? Reflection? What is this in my IC2118 (Witch Head Nebula) Image?
5 replies319 views
David Fercho avatar
I shot 265 60 second subs of the Witch Head and Rigel last night.  I used my Rokinon 135 f/2 and ASI294MC Pro, with an Optolong L-Pro filter.  All of the subs have a bright 'blob' not far from the center of the image, in the middle of the 'witch'.  The first image below is a single stretched sub.  The 2nd one is a stack of 90 subs with basic processing.  The location of the blob was very constant through the whole session, but I do see a tiny amount of shifting around (just a few pixels) with respect to the nearby stars.  After the meridian flip, the blob was still in the same spot with respect to the stars. Anyone have any idea what it is?
There shouldn't be anything there. So either is an artifact or is a discovery.
Oscar H. avatar
Might be a new faraway supernova; I don't think that was there before.
Oscar H. avatar
For example, there is nothing like that in that area of the Witch shown in this top pick https://www.astrobin.com/5bfryz/B/?q=witch%20head&camera= from 19 days ago.
If anyone is interested, these are all the Witch Heads taken in the last month https://www.astrobin.com/search/?q=witch+head&d=i&subject=&telescope=&camera=&date_published_min=2023-11-05&date_published_max=2023-12-05&sort=.
David Fercho avatar
Thanks - I really think it is an artifact, especially because I could see it move around a little bit as I blink through the subs.  If it were a deep-space object I would expect it to maintain a constant position among the nearby stars. On the other hand, I  think if were something in our solar system like an asteroid or object in earth orbit, it would move through the star field in a constant direction.  It does not have the central brightness that I would expect of a supernova.
I am just really curious  about what type of artifact would look like this one.
Jens avatar
The bright star next to the whichhead might cause lensflaring in your telescope. If you dither it should move around a little bit. but it does look weird, not very flare like.
AstroNikko: Witch Head Nebula (WIP)
Hi folks, I started a new project last night. Going after the Witch Head Nebula. Wanted to share my progress here, and hopefully get some feedback. I'm not sure exactly how long this is going to take. I'm guessing maybe 20 to 30 hrs total int...
Directly addresses Witch Head Nebula imaging with similar equipment and filters.
Jan 21, 2022
ZWO ASI 2600MC producing doughnut artifact in center of images
Hello everyone, I have had a ZWO ASI 2600MC for about a year now, and I have noticed that all the images I have taken with it since then have a strange artifact in them. Basically, it looks like a doughnut in the center of the image. This is particul...
Bright artifact in center of images similar to doughnut artifact with ZWO camera.
Nov 27, 2025
Do you know what is wrong with my image capture?
I've been troubleshooting my imaging on the Lobster Claw Nebula over a few sessions now. I have an artifact that I'm stumped as the the problem. 1. Collimation has been verified to be good 2. Tilt has been verified to be little or none 3. Foc...
Troubleshooting imaging artifacts that appear consistently across multiple frames.
Aug 15, 2025
